RB751V-40WS
Taiwan Semiconductor
Small Signal Product
Low VF SMD Schottky Barrier Diode
FEATURES
- Low power loss, high current capability, low VF
- Surface mount device type
- Moisture sensitivity level (MSL): 1
- Packing code with suffix "G" means
green compound (halogen-free)
SOD-323F
MECHANICAL DATA
- Case : Flat lead SOD-323F small outline plastic package
- Molding compound, UL flammability classification rating 94V-0
- Terminal: Matte tin plated, lead free,
solderable per MIL-STD-202, Method 208 guaranteed
- High temperature soldering guaranteed : 260°C/10s
- Polarity: Indicated by cathode band
- Weight : 4.6 ± 0.5 mg
- Marking Code : S8
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS (TA=25℃ unless otherwise noted)
PARAMETER
SYMBOL
VALUE
UNIT
PD
200
mW
VRRM
40
V
Reverse Voltage
VR
30
V
Mean Forward Current
IO
30
mA
Power Dissipation
Repetitive Peak Reverse Voltage
Non-Repetitive Peak Forward Surge Current
60Hz for 1 Cyc.
IFSM
0.2
(Note)
RθJA
500
TJ ,TSTG
-40 to +125
Thermal Resistance (Junction to Ambient)
Junction and Storage Temperature Range
PARAMETER
A
o
C/W
o
C
SYMBOL
TYP
MAX
Forward Voltage
IF = 1 mA
VF
0.37
V
Reverse Leakage Current
VR = 30 V
IR
0.5
μA
VR = 1V , f = 1.0 MHz
CJ
2
pF
Junction Capacitance
UNIT
Note: Valid provided that electrodes are kept at ambient temeprature.
Document Number: DS_S1411002
Version: C14
RB751V-40WS
RATINGS AND CHARACTERISTICS CURVES
Fig. 2 Admissible Power Dissipation Curve
Fig. 1 Typical Forward Characteristics
300
100
250
Powe Dissipation (mW)
IF, Forward Current (mA)
TA=25oC
10
1
0.1
200
150
100
50
0.4
0.6
0.8
1
60
80
100
120
140
Ambient Temperature (oC)
VF, Forward Voltage (V)
Fig. 4 Typical Reverse Characteristics
Fig. 3 Typical
Junction
Capacitance
Fig.
3
10000
4
IR, Leakage Current (nA)
Junction Capacitance (pF)
5
3
2
1
TA=125oC
1000
TA=25oC
100
10
4
6
8
Reverse Voltage (V)
10
12
14
10
15
30
35
Reverse Voltage (V)
Version: C14
RB751V-40WS
ORDERING INFORMATION
PART NO.
PACKING
PACKING CODE
SUFFIX (Note 1)
CODE
SUFFIX
PART NO.
RB751V-40WS
-xx
RR
G
R9
PACKAGE
SOD-323F
PACKING
3,000 / 7" Reel
10,000 / 13" Reel
Note 1: Part No. Suffix „-xx “ would be used for special requirement
EXAMPLE
PART NO.
PART NO.
RB751V-40WS RR
RB751V-40WS
RR
RB751V-40WS RRG
RB751V-40WS
RR
G
Multiple manufacture
source
Green compound
RR
G
Define manufacture
source
Green compound
RB751V-40WS-B0 RRG RB751V-40WS
SUFFIX
-B0
PACKING CODE
PACKING CODE
PREFERRED P/N
SUFFIX
DESCRIPTION
source
Version: C14
RB751V-40WS
PACKAGE OUTLINE DIMENSIONS
SOD-323F
DIM.
Unit (mm)
Unit (inch)
Min
Max
Min
Max
A
1.15
1.35
0.045
0.053
B
2.30
2.80
0.091
0.110
C
0.25
0.40
0.010
0.016
D
1.60
1.80
0.063
0.071
E
0.80
1.10
0.031
0.043
F
0.05
0.25
0.002
0.010
SUGGEST PAD LAYOUT
Unit (mm)
Unit (inch)
Typ.
Typ.
A
0.63
0.025
B
0.83
0.033
C
1.60
0.063
D
2.86
0.113
DIM.
Version: C14
RB751V-40WS
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Information contained herein is intended to provide a product description only. No license, express or implied,to
any intellectual property rights is granted by this document. Except as provided in TSC's terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or seling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
Version: C14
很抱歉,暂时无法提供与“RB751V-40WS RRG”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+2.300831+0.29511
- 10+1.2916810+0.16568
- 100+0.72129100+0.09252
- 500+0.55541500+0.07124
- 1000+0.487981000+0.06259
- 国内价格 香港价格
- 3000+0.383733000+0.04922
- 6000+0.343136000+0.04401
- 9000+0.322409000+0.04135
- 15000+0.2991015000+0.03837
- 21000+0.2852721000+0.03659
- 30000+0.2718430000+0.03487
- 75000+0.2423475000+0.03109
- 150000+0.22410150000+0.02875
- 300000+0.20877300000+0.02678
- 国内价格
- 1+0.26784
- 200+0.10368
- 500+0.10001
- 1000+0.09818
