DBL101G – DBL107G
Taiwan Semiconductor
1A, 50V - 1000V Standard Bridge Rectifier
FEATURES
KEY PARAMETERS
AEC-Q101 qualified available
Ideal for printed circuit board
Reliable low cost construction utilizing molded plastic technique
High surge current capability
UL Recognized File # E-326854
RoHS Compliant
Halogen-free according to IEC 61249-2-21
APPLICATIONS
PARAMETER
VALUE
UNIT
IF
1
A
VRRM
50 - 1000
V
IFSM
30, 40
A
TJ MAX
150
°C
Package
DBL
Configuration
Quad
● Switching mode power supply (SMPS)
● Adapters
● Lighting application
MECHANICAL DATA
Case: DBL
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: As marked
Weight: 0.360g (approximately)
DBL
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Marking code on the device
Repetitive peak reverse voltage
VRRM
Reverse voltage, total rms value
VR(RMS)
Forward current
Peak forward surge current,
8.3ms single half sine-wave
superimposed on rated load
Rating for fusing (t
很抱歉,暂时无法提供与“DBL101GHC1G”相匹配的价格&库存,您可以联系我们找货
