SD103AW - SD103CW
Taiwan Semiconductor
Small Signal Product
Low VF SMD Schottky Barrier Diode
FEATURES
- Low power loss, high current capability, low VF
- Surface device type mounting
- Moisture sensitivity level (MSL): 1
- Matte Tin (Sn) lead finish with Nickel (Ni) under plate
- Compliant to RoHS Directive 2011/65/EU and
in accordance to WEEE 2002/96/EC
- Halogen-free according to IEC 61249-2-21
SOD-123
MECHANICAL DATA
- Case: SOD-123 small outline plastic package
- Molding compound, UL flammability classification rating 94V-0
- Terminal: Matte tin plated, lead free,
solderable per MIL-STD-202, Method 208 guaranteed
- High temperature soldering guaranteed : 260°C/10s
- Polarity: Indicated by cathode band
- Weight: 0.01 g (approximately)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS (TA=25°C unless otherwise noted)
PARAMETER
Power Dissipation
SYMBOL
SD103AW SD103BW SD103CW
UNIT
PD
400
mW
VRRM
40
30
Reverse Voltage
VR
28
21
14
Mean Forward Current @ TL = 100°C
IO
Repetitive Peak Reverse Voltage
@ t ≦ 1.0 s
Repetitive Peak Forward Surge Current
Thermal Resistance ( Junction to Ambient )
Junction Temperature
Storage Temperature Range
PARAMETER
Reverse Breakdown Voltage
Forward Voltage
Reverse Leakage Current
Junction Capacitance
IR = 10 μA
SD103BW
IR = 10 μA
SD103CW
IR = 10 μA
IF = 20 mA
IF = 200 mA
SD103AW
VR = 30 V
SD103BW
VR = 20 V
SD103CW
VR = 10 V
VR = 0 , f = 1.0 MHz
V
mA
IFRM
1.5
A
RθJA
300
°C/W
TJ
125
°C
TSTG
-65 to +125
°C
SYMBOL
SD103AW
350
V
MIN
TYP
MAX
Units
V
40
V(BR)
30
VF
IR
CJ
50
0.37
0.60
5
V
μA
pF
Version: D1601
SD103AW - SD103CW
RATINGS AND CHARACTERISTICS CURVES
(TA=25℃ unless otherwise noted)
Fig. 1 Typical Forward Characteristics
Fig. 2 Forward Current Derating Curve
0.42
100
IO, Mean Forward Current (A)
Instantaneous Forward Current (A)
1000
10
1
0.1
0.01
0.0
0.2
0.4
0.6
0.8
0.35
0.28
0.21
0.14
Fig. 3
0.07
50
Instantaneous Forward Voltage (V)
75
100
Terminal Temperature
125
150
Fig. 4
(°C)
Fig. 4 Typical Junction Capacitance
Fig. 3 Admissible
Dissipation
Fig. Power
3
100
450
350
Junction Capacitance (pF)
Power Dissipation (mW)
400
300
250
200
150
100
10
50
50
75
100
Ambient Temperature (°C)
125
150
40
Reverse Voltage (V)
Version: D1601
SD103AW - SD103CW
ORDERING INFORMATION
PART NO.
PACKING CODE
PACKING CODE
SD103xW
(Note 1, 2)
SUFFIX
RH
G
PACKAGE
PACKING
SOD-123
3K / 7" Reel
Note 1: "x" is Device Code from "A" - "C".
Note 2: Whole series with green compound
EXAMPLE
EXAMPLE P/N
PART NO.
PACKING CODE
SD103AW RHG
SD103AW
RH
PACKING CODE
DESCRIPTION
SUFFIX
G
Green compound
PACKAGE OUTLINE DIMENSIONS
SOD-123
DIM.
Unit (mm)
Unit (inch)
Min
Max
Min
Max
A
1.40
1.80
0.055
0.071
B
3.55
3.85
0.140
0.152
C
0.45
0.70
0.018
0.028
D
2.55
2.85
0.100
0.112
E
0.95
1.35
0.037
0.053
F
0.05
0.15
0.002
0.006
G
0.50 REF
0.02 REF
H
0.10
0.004
SUGGEST PAD LAYOUT
Unit (mm)
Unit (inch)
Min
Min
G
2.25
0.089
X
0.90
0.035
X1
4.05
0.159
Y
0.95
0.037
DIM.
MARKING
Part No.
Marking
SD103AW
S4
SD103BW
S5
SD103CW
S6
Version: D1601
SD103AW - SD103CW
CREAT BY ART
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC's terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
Version: D1601
很抱歉,暂时无法提供与“SD103AW RHG”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+2.372251+0.30828
- 10+1.4425010+0.18746
- 50+1.0327350+0.13421
- 100+0.89816100+0.11672
- 500+0.65925500+0.08568
- 国内价格 香港价格
- 3984+0.538353984+0.06996
- 9000+0.346219000+0.04499
- 24000+0.3292824000+0.04279
- 国内价格 香港价格
- 3984+0.537853984+0.06990
- 国内价格 香港价格
- 3000+0.482753000+0.06274
- 9000+0.407359000+0.05294
