DB102TB
DB102TB
    SMCDIODESOLUTIONS(桑德斯)
    DIP4
    BRIDGE RECT 1PHASE 100V 1A DB-M
DB102TB 数据手册
DB101 THRU DB107 Technical Data Data Sheet N1778, Rev. A DB101 THRU DB107 SINGLE PHASE 1.0AMP GLASS PASSIVATED BRIDGE RECTIFIER Features Glass passivated die construction Low forward voltage drop High current capability High surge current capability Plastic material-UL flammability 94V-0 This is a Pb − Free Device “-HF” suffix is for Halogen Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request          DB-M Circuit Diagram Mechanical Data       Case: DB-M, Molded plastic Terminals: Plated leads solderable per MIL-STD-202, Method 208 Polarity: as marked on case Mounting Position: Any Marking: Type Number Lead Free: For RoHS / Lead Free Version Maximum Ratings@TA=25°C unless otherwise specified Single Phase half wave 60Hz, resistive or inductive load. For capacitive load current derate by 20%. Characteristic Symbol DB101 DB101-HF THRU DB107-HF Marking Code DB102 DB103 DB104 DB105 DB106 DB107 Unit DB101H DB102H DB103H DB104H DB105H DB106H DB107H Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage VRRM VRWM VR 50 100 200 400 600 800 1000 V RMS Reverse Voltage VRMS 35 70 140 280 420 560 700 V Average Forward Output Current (Note 1) @ TC =100°C IF(AV) 1.0 A Non-Repetitive Peak Forward Surge Current 8.3ms Single half sine-wave superimposed on rated load (JEDEC Method) IFSM 45 A I2t 8.404 A2 s I2t Rating for Fusing (t < 8.3ms)  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  DB101 THRU DB107 Technical Data Data Sheet N1778, Rev. A Electrical Characteristics@TA=25°C unless otherwise specified: Characteristic Symbol DB101-HF THRU DB107-HF Marking Code DB101 DB102 DB103 DB104 DB105 DB106 DB107 Unit DB101H DB102H DB103H DB104H DB105H DB106H DB107H Maximum Forward Voltage Drop per Bridge Element @IF =1.0A, TJ=25°C VF 1.0 V Peak Reverse Current @TA = 25°C At Rated DC Blocking Voltage @TA = 125°C IR 5 200 μA Typical Junction Capacitance (Note 2) CJ 25 pF * Pulse width < 300 µs, duty cycle < 2% Thermal-Mechanical Specifications: Characteristic DB101-HF THRU DB107-HF Marking Code Typical Thermal Resistance Junction to Ambient Typical Thermal Resistance Junction to Lead Symbol DB101 DB102 DB103 DB104 DB105 DB106 DB107 Unit DB101H DB102H DB103H DB104H DB105H DB106H DB107H RθJA 40 °C/W RθJL 15 °C/W -55+150 °C Operating Junction and Storage Temperature TJ ,TSTG Range Note: 1. Mounted on glass epoxy PC board with 1.3mm2 solder pad. 2. Measured at 1.0 MHZ and applied reverse voltage of 4.0 VDC Ratings and Characteristics Curves  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  DB101 THRU DB107 Technical Data Data Sheet N1778, Rev. A Mechanical Dimensions DB-M(Inches/Millimeters)  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  DB101 THRU DB107 Technical Data Data Sheet N1778, Rev. A Marking Diagram Where XXXXX is YYWWL DB101 DB101H YY WW L = Type Number = Marking Code = Year = Week = Lot Number Cautions:Molding resin Epoxy resin UL:94V-0 DB101-HF DB101 Ordering Information Device DB101 THRU DB107 Package Plating Shipping DB-M Pure Sn 50pcs / tube For information on tape and reel specifications, including part orientation and tape sizes, please refer to our tape and reel packaging specification.  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  DB101 THRU DB107 Technical Data Data Sheet N1778, Rev. A DISCLAIMER: 1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product characteristics. Before ordering, purchasers are advised to contact the SMC Diode Solutions sales department for the latest version of the datasheet(s). 2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment, medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by means of users’ fail-safe precautions or other arrangement . 3- In no event shall SMC Diode Solutions be liable for any damages that may result from an accident or any other cause during operation of the user’s units according to the datasheet(s). SMC Diode Solution assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information, products or circuits described in the datasheets. 4- In no event shall SMC Diode Solutions be liable for any failure in a semiconductor device or any secondary damage resulting from use at a value exceeding the absolute maximum rating. 5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC Diode Solutions. 6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC Diode Solutions. 7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and regulations..  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com 
DB102TB 价格&库存
很抱歉,暂时无法提供与“DB102TB”相匹配的价格&库存,您可以联系我们找货
