HBS810TR
HBS810TR
    SMCDIODESOLUTIONS(桑德斯)
    SMD4
    1000V,8APACKAGE HBS BRIDGE RECTI
HBS810TR 数据手册
HBS802 THRU HBS810 Technical Data Data Sheet N2257, Rev. - HBS802 THRU HBS810 Glass Passivated Single-Phase 8.0Amp Surface Mount Bridge Rectifier Features Surface mount bridge, small package; Ideal for printed circuit boards; Glass passivated chip junction; High forward current capability up to 8.0A; High surge current capability; High heat dissipation capability; Low profile package; Low forward voltage drop; Plastic package has Underwrites Laboratory Flammability Classification 94V-0 This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request          HBS    Circuit Diagram Mechanical Data       Case: HBS; Epoxy meets UL-94V-0 Flammability rating; Terminals:Matte tin plated leads, solderable per J-STD-002 and JESD22-B102; High temperature soldering guaranteed: Solder Reflow 260℃,10seconds; Polarity: As marked on body; Marking: Type number; Maximum Ratings and Electrical Characteristics @TA=25°C unless otherwise specified Single Phase half wave 60Hz, resistive or inductive load. For capacitive load current derate by 20%. Type Number Symbol HBS802 HBS804 HBS806 HBS808 Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage VRRM VRWM VDC 200 400 600 800 1000 V RMS Reverse Voltage VRMS 140 280 420 560 700 V Maximum average forward rectified output current at @TA =25°C Non-Repetitive Peak Forward Surge Current 8.3ms Single half sine-wave superimposed on rated load (JEDEC Method) I(AV) 8 A IFSM 200 A I2 t 166 A2sec Rating for fusing (t
HBS810TR 价格&库存
很抱歉,暂时无法提供与“HBS810TR”相匹配的价格&库存,您可以联系我们找货
