TSP15H200S S1G
TSP15H200S S1G
    TAIWANSEMICONDUCTOR(台湾半导体)
    TO-277
    DIODE SCHOTTKY 200V 15A TO277A
TSP15H200S S1G 数据手册
TSP15H120S – TSP15H200S Taiwan Semiconductor 15A, 120V - 200V Trench Schottky Surface Mount Rectifier FEATURES ● ● ● ● ● ● ● ● ● KEY PARAMETERS Patented Trench Schottky technology Excellent high temperature stability Low forward voltage Low power loss / high efficiency High forward surge capability Ideal for automated placement Moisture sensitivity level: level 1, per J-STD-020 RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 15 A VRRM 120 - 200 V IFSM 250 A TJ MAX 150 °C Package TO-277A (SMPC) Configuration Single die APPLICATIONS ● Switching mode power supply (SMPS) ● Adapters ● DC to DC converters MECHANICAL DATA ● ● ● ● ● ● Case: TO-277A (SMPC) Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 1A whisker test Polarity: Indicated by cathode band Weight: 0.095g (approximately) TO-277A (SMPC) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL TSP15H120S TSP15H150S TSP15H200S UNIT Marking code on the device 15H120 15H150 15H200 Repetitive peak reverse voltage VRRM 120 150 200 V Reverse voltage, total rms value VR(RMS) 84 105 140 V Forward current Surge peak forward current, 8.3ms single half sine wave superimposed on rated load Junction temperature IF 15 A IFSM 250 A TJ -55 to +150 °C Storage temperature TSTG -55 to +150 °C 1 Version: C2103 TSP15H120S – TSP15H200S Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT RӨJL 9 °C/W Junction-to-lead thermal resistance ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage CONDITIONS (1) Reverse current (2) @ rated VR SYMBOL TYP MAX UNIT TSP15H120S 0.57 - V TSP15H150S IF = 7.5A, TJ = 25°C 0.69 - V TSP15H200S 0.73 - V TSP15H120S 0.67 0.75 V TSP15H150S IF = 15.0A, TJ = 25°C 0.75 0.84 V 0.79 0.89 V 0.48 - V TSP15H150S IF = 7.5A, TJ = 125°C 0.56 - V TSP15H200S 0.59 - V TSP15H120S 0.58 0.66 V TSP15H150S IF = 15.0A, TJ = 125°C 0.63 0.73 V TSP15H200S 0.66 0.76 V - 250 µA - 150 µA - 35 mA - 25 mA TSP15H200S VF TSP15H120S TSP15H120S TSP15H150S TJ = 25°C TSP15H200S TSP15H120S TSP15H150S TJ = 125°C TSP15H200S IR Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1) PACKAGE PACKING TSP15HxS TO-277A (SMPC) 6,000 / Tape & Reel Notes: 1. “x” defines voltage from 120V(TSP15H120S) to 200V(TSP15H200S) 2 Version: C2103 TSP15H120S – TSP15H200S Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 10000 15 TSP15H120S CAPACITANCE (pF) 12 9 6 TSP15H150S 1000 TSP15H200S 3 0 f=1.0MHz Vsig=50mVp-p 100 50 75 100 125 150 0.1 1 CASE TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) INSTANTANEOUS REVERSE CURRENT (mA) Fig.4 Typical Forward Characteristics 100 TJ=150°C 10 1 TJ=125°C 0.1 TJ=100°C 0.01 0.001 TJ=25°C 0.0001 10 20 30 40 50 60 70 80 90 100 10010 TSP15H120S 10 UF1DLW TJ=150°C 1 TJ=125°C TJ=125°C TJ=100°C 1 TJ=25°C 0.01 0.1 0.001 0.10.30.2 0.4 0.3 0.5 0.4 INSTANTANEOUS FORWARD CURRENT (A) INSTANTANEOUS REVERSE CURRENT (mA) TSP15H150S TJ=150°C TJ=125°C TJ=100°C 0.01 0.001 TJ=25°C 0.0001 10 20 30 40 50 60 70 80 90 0.5 0.9 0.6 0.6 0.7 0.70.80.8 0.9 1.0 1 1.1 1.2 1.1 1.2 Fig.6 Typical Forward Characteristics 100 0.1 Pulse width 300μs 1% duty cycle Pulse width FORWARD VOLTAGE (V) Fig.5 Typical Reverse Characteristics 1 TJ=25°C 0.1 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) 10 100 REVERSE VOLTAGE (V) Fig.3 Typical Reverse Characteristics TSP15H120S 10 (A) 25 100 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) 100 10 10 TSP15H150S 1 UF1DLW TJ=150°C TJ=125°C T =125°C J TJ=25°C 0.1 TJ=100°C 1 TJ=25°C 0.01 0.1 0.001 0.1 (A) AVERAGE FORWARD CURRENT (A) 18 Pulse width 300μs 1% duty cycle Pulse width 0.2 0.3 0.3 0.4 0.4 0.5 0.5 0.6 0.7 0.8 0.9 0.6 0.7 0.8 0.9 1.0 1 FORWARD VOLTAGE (V) 3 Version: C2103 TSP15H120S – TSP15H200S Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.8 Typical Forward Characteristics TSP15H200S 10 TJ=150°C 1 TJ=125°C 0.1 TJ=100°C 0.01 0.001 TJ=25°C 0.0001 10 20 30 40 50 60 70 80 90 100 100 10 10 TSP15H200S UF1DLW 1 TJ=150°C TJ=125°C TJ=125°C TJ=25°C 0.1 (A) INSTANTANEOUS FORWARD CURRENT (A) 100 TJ=100°C 1 0.01 TJ=25°C 0.1 0.001 0.1 0.30.2 0.4 0.3 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) Pulse width 300μs 1% duty cycle Pulse width 0.4 0.5 0.5 0.9 0.6 0.6 0.7 0.70.80.8 0.9 1.0 1 1.1 FORWARD VOLTAGE (V) Fig.9 Maximum Non-Repetitive Forward Surge Current 300 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (mA) Fig.7 Typical Reverse Characteristics 8.3ms single half sine wave 250 200 150 100 50 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 4 Version: C2103 1.2 TSP15H120S – TSP15H200S Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS TO-277A (SMPC) SUGGESTED PAD LAYOUT MARKING DIAGRAM P/N YW F 5 = Marking Code = Date Code = Factory Code Version: C2103 TSP15H120S – TSP15H200S Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: C2103
TSP15H200S S1G 价格&库存
很抱歉,暂时无法提供与“TSP15H200S S1G”相匹配的价格&库存,您可以联系我们找货
