FTB1F-15F
THRU
FTB10F-15F
Technical Data
Data Sheet N1743, Rev. A
FTB1F-15F THRU FTB10F-15F
1.5A SURFACE MOUNT GLASS PASSIVATED BRIDGE RECTIFIER
Features
Glass Passivated Chip Junction
Reverse Voltage - 100 to 1000 V
Forward Current - 1.5 A
Designed for Surface Mount Application
Fast reverse recovery time
This is a Halogen Free Device
All SMC parts are traceable to the wafer lot
Additional testing can be offered upon request
ABF
Circuit Diagram
Mechanical Data
Case: ABF
Terminals: Solderable per MIL-STD-750, Method 2026
Weight: 82 mg
Maximum Ratings @TA=25°C unless otherwise specified
Single Phase half wave 60Hz, resistive or inductive load. For capacitive load current derate by 20%.
Symbol
FTB1F
-15F
FTB2F
-15F
FTB4F
-15F
FTB6F
-15F
FTB8F
-15F
Peak Repetitive Reverse Voltage
Working Peak Reverse Voltage
DC Blocking Voltage
VRRM
VRWM
VR
100
200
400
600
800
1000
V
RMS Reverse Voltage
VRMS
70
140
280
420
560
700
V
Average Forward Output Current @ TA=50°C
Non-Repetitive Peak Forward Surge Current
8.3ms Single half sine-wave superimposed on
rated load (JEDEC Method)
IF(AV)
1.5
A
IFSM
50
A
Characteristic
China - Germany - Korea - Singapore - United States
http://www.smc-diodes.com - sales@ smc-diodes.com
FTB10F
Units
-15F
FTB1F-15F
THRU
FTB10F-15F
Technical Data
Electrical Characteristics @TA=25°C unless otherwise specified
Characteristic
Symbol
FTB1F
-15F
FTB2F
-15F
FTB4F
-15F
FTB6F
-15F
FTB8F
-15F
FTB10F
Units
-15F
Forward voltage per element @ IF =1.5A
VF
1.3
V
Maximum DC reverse current
at rated DC blocking voltage
IR
5
100
µA
CJ
25
pF
Trr
Trr(TYP.)
500
300
ns
TA = 25°C
TA = 125°C
Typical Junction Capacitance (Note 1)
Maximum Reverse Recovery Time (Note 3)
* Pulse width < 300 µs, duty cycle < 2%
Thermal-Mechanical Specifications @TA=25°C unless otherwise specified
Characteristic
Symbol
Typical Thermal Resistance (Note 2)
Operating and storage temperature range
FTB1F
-15F
RθJA
TJ,TSTG
FTB2F
-15F
FTB4F
-15F
FTB6F
-15F
FTB8F
-15F
80
-55 to +150
Note: 1. Measured at 1.0 MHz and applied reverse voltage of 4.0V D.C.
2. Mounted on glass epoxy PC board with 4×(5×5mm2) copper pad.
3. Reverse Recovery Test Conditions: IF=0.5A, IR=1.0A, IRR=0.25A
Ratings and Characteristics Curves
FTB10F
Units
-15F
°C/W
°C
FTB1F-15F
THRU
FTB10F-15F
Technical Data
Ordering Information
Device
FTB1F-15F
THRU
FTB10F-15F
Marking Diagram
Package
Plating
Shipping
ABF
Pure Sn
5000pcs / reel
For information on tape and reel specifications, including part
orientation and tape sizes, please refer to our tape and reel
packaging specification.
Type number
Marking code
FTB1F-15F
F15F1F
FTB2F-15F
F15 F2F
FTB4F-15F
F15F4F
FTB6F-15F
F15F6F
FTB8F-15F
F15F8F
FTB10F-15F
F15F10F
FTB1F-15F
THRU
FTB10F-15F
Technical Data
Mechanical Dimensions ABF(Inches/Millimeters)
Carrier Tape Specification ABF
SYMBOL
Millimeters
Min.
Max.
A
5.00
5.40
B
6.40
6.80
d
1.40
1.60
E
1.40
1.60
F
5.55
5.75
P
3.90
4.10
P0
3.90
4.10
P1
1.90
2.10
W
11.50
12.50
FTB1F-15F
THRU
FTB10F-15F
Technical Data
DISCLAIMER:
1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product
characteristics. Before ordering, purchasers are advised to contact the SMC Diode Solutions sales department for the latest version of
the datasheet(s).
2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment,
medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by
means of users’ fail-safe precautions or other arrangement .
3- In no event shall SMC Diode Solutions be liable for any damages that may result from an accident or any other cause during
operation of the user’s units according to the datasheet(s). SMC Diode Solution assumes no responsibility for any intellectual property
claims or any other problems that may result from applications of information, products or circuits described in the datasheets.
4- In no event shall SMC Diode Solutions be liable for any failure in a semiconductor device or any secondary damage resulting from use
at a value exceeding the absolute maximum rating.
5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC Diode Solutions.
6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC
Diode Solutions.
7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will
hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third
party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and
regulations.
很抱歉,暂时无法提供与“FTB10F-15FTR”相匹配的价格&库存,您可以联系我们找货
