TSPB5H100S – TSPB5H150S
Taiwan Semiconductor
5A, 100V - 150V Trench Schottky Surface Mount Rectifier
FEATURES
KEY PARAMETERS
Patented Trench Schottky technology
Excellent high temperature stability
Low forward voltage
Lower power loss/ high efficiency
High forward surge capability
Ideal for automated placement
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF
5
A
VRRM
100 - 150
V
IFSM
100
A
TJ MAX
150
°C
Package
SMPC4.0
Configuration
Single die
APPLICATIONS
● Switching mode power supply (SMPS)
● Adapters
● DC to DC converter
MECHANICAL DATA
Case: SMPC4.0
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 1A whisker test
Polarity: Indicated by cathode band
Weight: 0.090g (approximately)
SMPC4.0
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Marking code on the device
TSPB5H
100S
TSPB5H
120S
TSPB5H
150S
B5H100
B5H120
B5H150
UNIT
Repetitive peak reverse voltage
VRRM
100
120
150
V
Reverse voltage, total rms value
VR(RMS)
70
84
105
V
Forward current
Peak forward surge current, 8.3ms single half
sine-wave superimposed on rated load
Critical rate of rise of off-state voltage
IF
5
A
IFSM
100
A
dv/dt
10,000
V/μs
Junction temperature
TJ
- 55 to +150
°C
Storage temperature
TSTG
- 55 to +150
°C
1
Version: C2103
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
RӨJL
15
°C/W
Junction-to-lead thermal resistance
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
CONDITIONS
SYMBOL
TSPB5H100S
TSPB5H120S
Forward voltage
TSPB5H150S
(1)
VF
TSPB5H100S
TSPB5H120S
Reverse current @ rated VR
IF = 5A, TJ = 25°C
(2)
TSPB5H150S
TSPB5H100S
TSPB5H120S
TSPB5H150S
TSPB5H100S
TSPB5H120S
TSPB5H150S
IF = 5A, TJ = 125°C
TJ = 25°C
IR
TJ = 125°C
TYP
MAX
UNIT
0.59
0.66
V
0.66
0.74
V
0.74
0.84
V
0.53
0.60
V
0.56
0.64
V
0.60
0.70
V
150
μA
100
μA
18
mA
12
mA
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)
PACKAGE
PACKING
TSPB5HxS
SMPC4.0
6,000 / Tape & Reel
Notes:
1. “x” defines voltage from 100V(TSPB5H100S) to 150V(TSPB5H150S)
2
Version: C2103
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
1000
5
CAPACITANCE (pF)
4
3
2
100
1
f=1.0MHz
Vsig=50mVp-p
10
50
75
100
125
150
0.1
1
CASE TEMPERATURE (°C)
INSTANTANEOUS FORWARD CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (mA)
Fig.4 Typical Forward Characteristics
100
TSPB5H100S
TJ=150°C
1
TJ=125°C
0.1
TJ=100°C
0.01
0.001
TJ=25°C
0.0001
10
40
50
60
70
80
90 100
10 10
TSPB5H100S
1
10.1
TSPB5H120S
TJ=150°C
1
TJ=125°C
TJ=100°C
0.01
0.001
TJ=25°C
0.0001
40
50
60
70
80
TJ=125°C
TJ=125°C
TJ=100°C
TJ=25°C
TJ=25°C
0.1
0.001
0.1
0.2
0.3
0.4
0.3
0.4
0.5
0.6
Pulse width 300μs
1% duty cycle
Pulse width
0.5
0.7
0.6
0.8
0.7
0.9
0.8
1
1.1
1.2
1.1
1.2
Fig.6 Typical Forward Characteristics
100
10
TJ=150°C
FORWARD VOLTAGE (V)
Fig.5 Typical Reverse Characteristics
0.1
UF1DLW
0.01
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
10
100
REVERSE VOLTAGE (V)
Fig.3 Typical Reverse Characteristics
10
10
(A)
25
TSPB5H100S
TSPB5H120S
TSPB5H150S
90 100
10 10
TSPB5H120S
1
10.1
UF1DLW
TJ=150°C
TJ=125°C
TJ=125°C
TJ=100°C
TJ=25°C
(A)
AVERAGE FORWARD CURRENT (A)
6
TJ=25°C
0.01
0.1
0.001
0.1
0.2
0.3
0.4
0.3
0.4
0.5
0.6
Pulse width 300μs
1% duty cycle
Pulse width
0.5
0.7
0.6
0.8
0.7
0.9
0.8
1
FORWARD VOLTAGE (V)
3
Version: C2103
Fig.8 Typical Forward Characteristics
TSPB5H150S
10
TJ=150°C
1
TJ=125°C
0.1
TJ=100°C
0.01
0.001
TJ=25°C
0.0001
10
40
50
60
70
80
90 100
10 10
TSPB5H150S
1
1
0.1
UF1DLW
TJ=150°C
TJ=125°C
TJ=125°C
TJ=25°C
TJ=25°C
0.01
0.1
0.001
0.2
0.3
TJ=100°C
(A)
100
Fig.7 Typical Reverse Characteristics
Pulse width 300μs
1% duty cycle
Pulse width
0.3
0.4
0.4
0.5
0.5
0.6
0.6
0.7
0.8
0.7
0.9
0.8
1
1.1
FORWARD VOLTAGE (V)
4
Version: C2103
1.2
PACKAGE OUTLINE DIMENSIONS
SMPC4.0
SUGGESTED PAD LAYOUT
MARKING DIAGRAM
P/N = Marking Code
5
YW
= Date Code
F
= Factory Code
Version: C2103
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: C2103
很抱歉,暂时无法提供与“TSPB5H150S S2G”相匹配的价格&库存,您可以联系我们找货
