HDBL103G C1G
HDBL103G C1G
    TAIWANSEMICONDUCTOR(台半)
    DIP4
    BRIDGE RECT 1PHASE 200V 1A DBL
HDBL103G C1G 数据手册
HDBL101G – HDBL107G Taiwan Semiconductor 1A, 50V - 1000V High Efficient Bridge Rectifier FEATURES ● ● ● ● ● ● ● ● KEY PARAMETERS Glass passivated chip junction Ideal for printed circuit board Reliable low cost construction utilizing molded plastic technique High surge current capability UL Recognized File # E-326854 AEC-Q101 qualified available RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 1 A VRRM 50 - 1000 V IFSM 50 A TJ MAX 150 °C Package DBL Configuration Quad APPLICATIONS ● Switching mode power supply (SMPS) ● Adapters ● Lighting application MECHANICAL DATA ● ● ● ● ● ● Case: DBL Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: As marked Weight: 0.360g (approximately) DBL ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device Repetitive peak reverse voltage VRRM Reverse voltage, total rms value VR(RMS) Forward current Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load Rating for fusing (t
HDBL103G C1G 价格&库存
很抱歉,暂时无法提供与“HDBL103G C1G”相匹配的价格&库存,您可以联系我们找货
