GBU15L05HD2G
GBU15L05HD2G
    TAIWANSEMICONDUCTOR(台湾半导体)
    SIP4
    BRIDGE RECT 1PHASE 600V 15A GBU
GBU15L05HD2G 数据手册
GBU15L05 – GBU15L06 Taiwan Semiconductor 15A, 600V - 800V Low VF Standard Bridge Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available Low forward drop enhance the efficiency Oxide planar chip junction High surge current capability UL Recognized File # E-326243 RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS PARAMETER VALUE UNIT IF 15 A VRRM 600 - 800 V IFSM 200 A TJ MAX 150 °C Package GBU Configuration Quad ● Switching mode power supply (SMPS) ● Adapters ● Lighting application MECHANICAL DATA ● ● ● ● ● Case: GBU Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Polarity: As marked Weight: 4.00g (approximately) GBU ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device GBU15L05 GBU15L06 GBU15L05 GBU15L06 UNIT Repetitive peak reverse voltage VRRM 600 800 V Reverse voltage, total rms value VR(RMS) 420 560 V Forward current Surge peak forward current single half t = 8.3ms sine-wave superimposed on rated load t = 1.0ms IF IFSM 15 A 200 A 630 A Rating for fusing (t
GBU15L05HD2G 价格&库存
很抱歉,暂时无法提供与“GBU15L05HD2G”相匹配的价格&库存,您可以联系我们找货
