TS8P07G D2G
TS8P07G D2G
    TAIWANSEMICONDUCTOR(台湾半导体)
    SIP4
    BRIDGE RECT 1PHASE 1KV 8A TS-6P
TS8P07G D2G 数据手册
TS8P01G – TS8P07G Taiwan Semiconductor 8A, 50V - 1000V Standard Bridge Rectifier FEATURES ● ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available Glass passivated chip junction Ideal for printed circuit board Typical IR less than 0.1μA High surge current capability UL Recognized File # E-326243 RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 8 A VRRM 50 - 1000 V IFSM 200 A TJ MAX 150 °C Package TS-6P Configuration Quad APPLICATIONS ● Switching mode power supply (SMPS) ● Adapters ● Lighting application MECHANICAL DATA ● ● ● ● ● ● ● Case: TS-6P Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Mounting torque: 0.92 N⋅m maximum Polarity: As marked Weight: 7.15g (approximately) TS-6P ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) Repetitive peak reverse voltage VRRM TS8P 01G TS8P 01G 50 Reverse voltage, total rms value VR(RMS) 35 PARAMETER SYMBOL Marking code on the device Forward current Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load Rating of fusing (t
TS8P07G D2G 价格&库存
很抱歉,暂时无法提供与“TS8P07G D2G”相匹配的价格&库存,您可以联系我们找货
