DB152TB
DB152TB
    SMCDIODESOLUTIONS(桑德斯)
    DIP4
    BRIDGE RECT 1P 100V 1.5A DB-M
DB152TB 数据手册
DB151 THRU DB157 Technical Data Data Sheet N1915, Rev. A DB151 THRU DB157 SINGLE PHASE 1.5AMP GLASS PASSIVATED BRIDGE RECTIFIER Features Glass passivated die construction Low forward voltage drop High current capability High surge current capability Plastic material-UL flammability 94V-0 This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request         DB-M Circuit Diagram Mechanical Data      Case: DB-M, Molded plastic Terminals: Plated leads solderable per MIL-STD-202, Method 208 Polarity: as marked on case Mounting Position: Any Lead Free: For RoHS / Lead Free Version Maximum Ratings and Electrical Characteristics @TA=25°C unless otherwise specified Single Phase half wave 60Hz, resistive or inductive load. For capacitive load current derate by 20%. Characteristic Symbol DB151 DB152 DB153 DB154 DB155 DB156 DB157 Unit Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage VRRM VRWM VR 50 100 200 400 600 800 1000 V RMS Reverse Voltage VRMS 35 70 140 280 420 560 700 V Average Forward Output Current (Note 1) @ TC =100°C IF(AV) 1.5 A Non-Repetitive Peak Forward Surge Current 8.3ms Single half sine-wave superimposed on rated load (JEDEC Method) IFSM 55 A I2t 12.6 A2 s I2t Rating for Fusing (t < 8.3ms)  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  DB151 THRU DB157 Technical Data Data Sheet N1915, Rev. A Electrical Characteristics: Characteristic Symbol DB151 DB152 DB153 DB154 DB155 DB156 DB157 Unit Maximum Forward Voltage Drop per Bridge Element @IF =1.5A, TJ=25°C VF 1.0 V Peak Reverse Current @TA = 25°C At Rated DC Blocking Voltage @TA = 125°C IR 5 200 μA Typical Junction Capacitance (Note 2) CJ 25 pF * Pulse width < 300 µs, duty cycle < 2% Thermal-Mechanical Specifications: Characteristic Symbol DB151 DB152 DB153 DB154 DB155 DB156 DB157 Unit Typical Thermal Resistance Junction to Ambient RθJA 40 °C/W Typical Thermal Resistance Junction to Lead RθJL 15 °C/W -55 to + 150 °C Operating Junction and Storage Temperature TJ ,TSTG Range Note: 1. Mounted on glass epoxy PC board with 1.3mm2 solder pad. 2. Measured at 1.0 MHZ and applied reverse voltage of 4.0 VDC Ratings and Characteristics Curves  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  DB151 THRU DB157 Technical Data Data Sheet N1915, Rev. A Mechanical Dimensions DB-M(Inches/Millimeters)  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  DB151 THRU DB157 Technical Data Data Sheet N1915, Rev. A Marking Diagram Where XXXXX is YYWWL DB151 YY WW L = Type Number = Year = Week = Lot Number Cautions:Molding resin Epoxy resin UL:94V-0 Ordering Information Device DB151 THRU DB157 Package Plating Shipping DB-M(Pb-Free) Pure Sn 50pcs / tube For information on tape and reel specifications, including part orientation and tape sizes, please refer to our tape and reel packaging specification.  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  DB151 THRU DB157 Technical Data Data Sheet N1915, Rev. A DISCLAIMER: 1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product characteristics. Before ordering, purchasers are advised to contact the SMC Diode Solutions sales department for the latest version of the datasheet(s). 2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment, medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by means of users’ fail-safe precautions or other arrangement . 3- In no event shall SMC Diode Solutions be liable for any damages that may result from an accident or any other cause during operation of the user’s units according to the datasheet(s). SMC Diode Solution assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information, products or circuits described in the datasheets. 4- In no event shall SMC Diode Solutions be liable for any failure in a semiconductor device or any secondary damage resulting from use at a value exceeding the absolute maximum rating. 5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC Diode Solutions. 6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC Diode Solutions. 7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and regulations..  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com 
DB152TB 价格&库存
很抱歉,暂时无法提供与“DB152TB”相匹配的价格&库存,您可以联系我们找货
