TSSA3U60 R3G
TSSA3U60 R3G
    TAIWANSEMICONDUCTOR(台湾半导体)
    DO-214AC
    电压:60V 电流:3A
TSSA3U60 R3G 数据手册
TSSA3U60 Taiwan Semiconductor 3A, 60V Trench Schottky Surface Mount Rectifier FEATURES ● ● ● ● ● ● KEY PARAMETERS Patented Trench Schottky technology Low power loss, high efficiency High surge current capability Moisture sensitivity level: level 1, per J-STD-020 RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS ● Trench Schottky barrier rectifier are designed for high frequency miniature switched mode power supplies such as adapters, lighting PARAMETER VALUE UNIT IF 3 A VRRM 60 V IFSM 60 A TJ MAX 150 °C Package DO-214AC (SMA) Configuration Single die MECHANICAL DATA ● ● ● ● ● ● Case: DO-214AC (SMA) Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 0.060g (approximately) DO-214AC (SMA) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device TSSA3U60 UNIT 3U60 Repetitive peak reverse voltage VRRM 60 V Reverse voltage, total rms value VR(RMS) 42 V Forward current Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load Junction temperature IF 3 A IFSM 60 A TJ - 55 to +150 °C Storage temperature TSTG - 55 to +150 °C 1 Version: G2102 TSSA3U60 Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT Junction-to-lead thermal resistance RӨJL 27 °C/W Junction-to-ambient thermal resistance RӨJA 70 °C/W Junction-to-case thermal resistance RӨJC 20 °C/W Thermal Performance Note: Units mounted on PCB (5mm x 5mm Cu pad test board) ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage CONDITIONS IF = 3A, TJ = 25°C (1) Reverse current @ rated VR IF = 3A, TJ = 125°C (2) Junction capacitance Reverse recovery time TJ = 25°C SYMBOL TYP MAX UNIT 0.48 0.54 V 0.41 0.50 V - 500 µA 12 30 mA CJ 450 610 pF trr 20 25 ns VF IR TJ = 125°C 1MHz, VR = 4.0V IF = 0.5A, IR = 1.0A, Irr = 0.25A Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE PACKAGE PACKING TSSA3U60 DO-214AC (SMA) 7,500 / Tape & Reel 2 Version: G2102 TSSA3U60 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 1000 3 CAPACITANCE (pF) 2 1 100 f=1.0MHz Vsig=50mVp-p 0 10 25 50 75 100 125 150 0 1 LEAD TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) TJ=150°C TJ=125°C TJ=100°C 0.01 TJ=25°C 0.001 10 20 30 40 50 60 70 80 90 100 10 10 UF1DLW 1 TJ=150°C TJ=125°C TJ=125°C 1 0.1 TJ=25°C TJ=100°C TJ=25°C 0.01 0.1 0.001 0.0 0.1 0.2 0.3 0.3 0.4 0.5 0.6 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) Pulse width 300μs 1% duty cycle Pulse width 0.4 0.7 0.5 0.8 0.6 0.9 0.7 1 1.1 FORWARD VOLTAGE (V) Fig.5 Maximum Non-Repetitive Forward Surge Current 70 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (mA) Fig.4 Typical Forward Characteristics 10 0.1 100 REVERSE VOLTAGE (V) Fig.3 Typical Reverse Characteristics 1 10 (A) AVERAGE FORWARD CURRENT (A) 4 60 8.3ms single half sine wave 50 40 30 20 10 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: G2102 1.2 TSSA3U60 Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS DO-214AC (SMA) SUGGESTED PAD LAYOUT MARKING DIAGRAM 4 P/N = Marking Code G = Green Compound YW = Date Code F = Factory Code Version: G2102 TSSA3U60 Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 5 Version: G2102
TSSA3U60 R3G 价格&库存
很抱歉,暂时无法提供与“TSSA3U60 R3G”相匹配的价格&库存,您可以联系我们找货
TSSA3U60 R3G
  • 5+0.70730
  • 50+0.56376
  • 150+0.49194
库存:5
