94HCB16WT
94HCB16WT
    GRAYHILLINC.
    DIP
94HCB16WT 数据手册
Thru-Hole DIP Switches SERIES 94H Binary Coded FEATURES • Sealed Construction; No Tape Seal Required • Surface Mount or Thru-Hole Style • Tube or Tape and Reel Packaging • Octal, BCD, and Hexadecimal Code • In Standard or Complement • Standard and Right Angle Mount • Flush or Extended Actuators • Gold-Plated Contacts ACTUATOR STYLES .020 +.004/-.002 (0,51 + 0,10/0,05) 3 45 DIMENSIONS Surface Mount Gullwing In inches (and millimeters) Tolerances are ± .010 inches unless specified otherwise. .060 (1,52) TYP. .100 .005 (2,54 0,13) TYP. 2 67 Octal–8 position .390 (9,91) 3 12 45 0.560 PIN #1 0.100 TYP .380 (9,65) 2 C 8 0.280 Solder pad layout as viewed from the top of the switch 4 45 23 C 1 0.070 TYP 45 .190 (4,83) 2 PLACES 67 23 23 01 Figure 1 "A" style rotor Figure 2 "F" style rotor .225 (5,72) .500 (12,7) .025 (0,64) Surface Mount J-Lead 3 .390 (9,91) All actuation types are available in octal (8), binary coded decimal (10), or hexadecimal (16) codes; with either standard or complement output. Standard code outputs have natural color rotors; complements in a contrasting color. 12 0.410 (10,41) 2 4 C 1 EXTENDED ACTUATOR TYPES 0.050 (1,27) .190 (4,83) 2 PLACES CORNER CLOSEST TO PIN #1 0.100 (2,54) Typ. C 8 .140 DIA. ( ∅ 3,56) 0.250 [6.35] 0.315 [8.00] 0.385 [9.78] 0.240 (6,10) 3 4 .270 (6,86) OR .170 (4,32) OR .090 (2,29) SEE ORDERING INFORMATION .270 (6,86) OR .170 (4,32) OR .090 (2,29) SEE ORDERING INFORMATION .200 (5,08) 2 1 Standard Thru-Hole 3 .390 (9,91) .040 .005 (1,02 0,13) .100 .005 TYP. (2,54 0,13) 2 C 8 4 C 1 .140 DIA. ( ∅ 3,56) 1 2 0 7 12 .190 (4,83) 2 PLACES CORNER CLOSEST TO PIN #1 .380 (9,65) TERMINALS ARE .020 +.004/-.002 (0,51 +0,10/0,05) WIDE BY .012 .002 (0,31 0,05) THICK .038 DIA. HOLE SIZE RECOMMENDED PC board layout as viewed from the top of the switch Figure 3 .146 (3,71) .225 (5,72) .300 (7,62) TYP. DIP 19 G rayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com EF 7 5 0 6 EF 901 01 01 456 78 BCD–10 position 67 89 0 45 0 0 DIP Switches 89 AB AB CD Hex–16 position CD 5 6 3 4 .282 (7,16) 45 Thru-Hole DIP Switches DIMENSIONS In inches (and millimeters) TAPE AND REEL PACKAGING: Series 94H Meets requirements of EIA 481-2. Right Angle Thru-Hole .430 (10,92) .210 (5,33) .282 (7,16) .190 .400 (4,83) (10,16) 1 0 2 3 4 13 INCH DIAMETER REEL .145 (3,68) 45 23 23 .156 (3,96) PIN #1 .100 ± .005 (2,54 ± 0,13) TYP. .100 ± .005 (2,54 ± 0,13) 45 ORDERING INFORMATION: Series 94H Series Actuator Style: A = Flush, Figure 1 B = .270, Figure 3 (see page B-21) C = .170, Figure 3 (see page B-21) E = .090, Figure 3 (see page B-21) F = Flush, Figure 2 Code: B = Standard (Natural), C = Complementary (Contrasting Color) RoHS Compliant Packaging: R = Tape and Reel, (Surface Mount Only) Blank = Tube* Terminal Style: RA = Right Angle, Thru-Hole J = J-Lead W = Surface Mount Blank = Thru-Hole Number of Positions: 08 = Octal, 8 Position 10 = BCD, 10 Position 16 = Hex, 16 Position 16mm PIN #1 CHAMFER 67 67 67 67 5 5 5 DIRECTION OF FEED 24mm Each reel contains the following number of switches with a 15.35 inch (390 mm) minimum leader and a 6.30 inch (160 mm) minimum trailer. 94HA style 94HB style 94HC style 94HE style 94HF style 750 150 200 300 750 sw/reel sw/reel sw/reel sw/reel sw/reel * 27 Pieces per tube for surface mount and thru-hole, 24 pieces per tube for right angle switches. SERIES 94 High Temperature Knobs: .190 (4,83) For Shaft Extensions .370 (9,40) 1 Slotted knobs show switch markings. Contact Grayhill for other knob material/ marking color combinations and geometrics. 2 .370 (9,40) 3 .040 (1,02) .210 (5,33) 4 .040 (1,02) 5 A B * Use only with Actuator Type B or C ORDERING INFORMATION: Knob Style and Height 1A 5A 1B 1B 2B 3B 4B 1B 4B 5B Series 94 High Temperature Knobs* Arrow Color N/A Black N/A N/A White Black Black N/A White Black Part Number 947706-001 947706-005 947705-001 947705-012 947705-004 947705-017 947705-018 947705-009 947705-010 947705-019 Knob Color Gray Gray Black Gray Gray Gray Gray Natural Black Gray *Ordered as a separate item. B = Standard (Natural), C = Complementary (Conrasting Color). Available from your local Grayhill Distributor. For prices and discounts, contact a local Sales Office, an authorized local Distributor or Grayhill. DIP 20 Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com 4 4 4 4 94HAB10WRT 5 1 0 1 PC board layout as viewed from the top of the switch 0 1 6 7 TERMINALS ARE .020 ±.002 (0,51±0,05) WIDE BY .012 ±.002 (0,31 ±0,05) THICK 1 C 4 8 C 2 0 7 45 23 5 6 6 7 DIP Switches CONDUCTIVE PLASTIC EMBOSSED TAPE 6 7 0 0 0 0 1 1 1 1 23 23 23 23
94HCB16WT 价格&库存
很抱歉,暂时无法提供与“94HCB16WT”相匹配的价格&库存,您可以联系我们找货
