TS10K60HD3G
TS10K60HD3G
    TAIWANSEMICONDUCTOR(台湾半导体)
    SIP4
    BRIDGE RECT 1PHASE 600V 10A TS4K
TS10K60HD3G 数据手册
TS10K40 – TS10K100 Taiwan Semiconductor 10A, 400V - 1000V Standard Bridge Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS Ideal for printed circuit board High surge current capability Typical IR less than 0.1µA UL Recognized File # E-326243 AEC-Q101 available RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS ● ● ● ● PARAMETER VALUE UNIT IF 10 A VRRM 400 - 1000 V IFSM 150 A TJ MAX 150 °C Package TS4K Configuration Quad Switching mode power supply (SMPS) Adapters TV Monitor MECHANICAL DATA ● ● ● ● ● ● ● Case: TS4K Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: As marked Mounting torque: 8.17 in-lbs maximum Weight: 4.00g (approximately) + ~ ~ - TS4K ~ ~ + - ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device TS10K 40 TS10K 60 TS10K 80 TS10K 100 TS10K40 TS10K60 TS10K80 TS10K100 UNIT Repetitive peak reverse voltage VRRM 400 600 800 1000 V Reverse voltage, total rms value VR(RMS) 280 420 560 700 V Forward current Surge peak forward current single half sine-wave superimposed on rated load per diode t = 8.3ms IF 10 A IFSM 150 A Rating of fusing ( t
TS10K60HD3G 价格&库存
很抱歉,暂时无法提供与“TS10K60HD3G”相匹配的价格&库存,您可以联系我们找货
