C3D10065I
C3D10065I
    WOLFSPEED
    TO-220-2
    凭借碳化硅 (SiC) 肖特基势垒二极管的性能优势,电力电子系统有望达到比基于硅的解决方案更高的效率标准,同时还能实现更高的频率和功率密度。SiC 二极管可以轻松并联以满足各种应用需求,无需担心热失控...
C3D10065I 数据手册
C3D10065I VRRM = Silicon Carbide Schottky Diode Z-Rec® IF (TC=125˚C) = Rectifier Q c Features • • • • • • = 10 A 24 nC Package 650-Volt Schottky Rectifier Ceramic Package Provides 2.5kV Isolation Zero Reverse Recovery Current High-Frequency Operation Temperature-Independent Switching Behavior Positive Temperature Coefficient on VF TO-220 Isolated Benefits • • • • • 650 V Electrically Isolated Package Essentially No Switching Losses Higher Efficiency Reduction of Heat Sink Requirements Parallel Devices Without Thermal Runaway PIN 1 CASE PIN 2 Applications • • • • • HVAC Switch Mode Power Supplies (SMPS) Boost diodes in PFC or DC/DC stages Free Wheeling Diodes in Inverter Stages AC/DC converters Part Number Package Marking C3D10065I Isolated TO-220-2 C3D10065I Maximum Ratings (TC = 25˚C unless otherwise specified) Symbol Parameter Unit Test Conditions VRRM Repetitive Peak Reverse Voltage 650 V VRSM Surge Peak Reverse Voltage 650 V VDC DC Blocking Voltage 650 V 19 10 9 A 39 26.5 A TC=25˚C, tP=10 ms, Half Sine Pulse TC-110˚C, tP=10 ms, Half Sine Pulse IF Continuous Forward Current TC=25˚C TC=125˚C TC=135˚C Note Fig. 3 IFRM Repetitive Peak Forward Surge Current IFSM Non-Repetitive Peak Forward Surge Current 90 70 A TC=25˚C, tP=10 ms, Half Sine Pulse TC=110˚C, tP=10 ms, Half Sine Pulse Fig. 8 IF,Max Non-Repetitive Peak Forward Surge Current 860 680 A TC=25˚C, tP=10 ms, Pulse TC=110˚C, tP=10 ms, Pulse Fig. 8 60 26 W TC=25˚C TC=110˚C Fig. 4 VR=0-650V Ptot Power Dissipation dV/dt Diode dV/dt ruggedness 200 V/ns ∫i2dt i2t value 40.5 24.5 A2s -55 to +175 ˚C 1 8.8 Nm lbf-in TJ , Tstg Operating Junction and Storage Temperature TO-220 Mounting Torque 1 Value C3D10065I Rev. E, 01-2018 TC=25˚C, tP=10 ms TC=110˚C, tP=10 ms M3 Screw 6-32 Screw Electrical Characteristics Symbol Parameter Typ. Max. Unit Test Conditions Note IF = 10 A TJ=25°C IF = 10 A TJ=175°C Fig. 1 μA VR = 650 V TJ=25°C VR = 650 V TJ=175°C Fig. 2 24 nC VR = 400 V, IF = 10 A di/dt = 500 A/μs TJ = 25°C Fig. 5 460.5 44 40 pF VR = 0 V, TJ = 25°C, f = 1 MHz VR = 200 V, TJ = 25˚C, f = 1 MHz VR = 400 V, TJ = 25˚C, f = 1 MHz Fig. 6 3.6 μJ VR = 400 V Fig. 7 VF Forward Voltage 1.5 2.0 1.8 2.4 V IR Reverse Current 12 24 60 220 QC Total Capacitive Charge C Total Capacitance EC Capacitance Stored Energy Note: This is a majority carrier diode, so there is no reverse recovery charge. Thermal Characteristics Symbol RθJC Parameter Thermal Resistance from Junction to Case Typ. Unit Note 2.5 °C/W Fig. 9 Typical Performance 100 30 25 90 TJ = -55 °C TJ = 75 °C TJ = 125 °C TJ = 175 °C 10 5 0 0.0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 FowardVVoltage, (V) VF (V) F Figure 1. Forward Characteristics 2 80 70 TJ = 175 °C 60 TJ = 125 °C 50 TJ = 75 °C R 15 Reverse Leakage ICurrent, (mA) IRR (mA) 20 F Foward Current, I (A) IF (A) TJ = 25 °C C3D10065I Rev. E, 01-2018 40 TJ = 25 °C 30 TJ = -55 °C 20 10 0 0 100 200 300 400 500 600 700 800 900 1000 ReverseVVoltage, (V) VR (V) R Figure 2. Reverse Characteristics Typical Performance 70 70 10% Duty 20% Duty 30% Duty 50% Duty 70% Duty DC 60 50 40 PTot (W) IF(peak) (A) 50 60 30 40 30 20 20 10 10 0 25 50 75 100 125 150 0 175 25 50 75 TC ˚C 175 Conditions: TJ = 25 °C Ftest = 1 MHz Vtest = 25 mV 450 400 30 350 Capacitance C (pF)(pF) (nC) QC (nC) CapacitiveQ Charge, C 500 25 20 15 10 300 250 200 150 100 5 50 0 0 0 100 200 300 400 500 600 700 (V) VR (V) ReverseVVoltage, R Figure 5. Total Capacitance Charge vs. Reverse Voltage 3 150 Figure 4. Power Derating Conditions: TJ = 25 °C 35 125 TC ˚C Figure 3. Current Derating 40 100 C3D10065I Rev. E, 01-2018 0 1 10 100 (V) VR (V) ReverseVVoltage, R Figure 6. Capacitance vs. Reverse Voltage 1000 Typical Performance 1,000 10 9 7 IFSM I (A) (A) 6 FSM 5 C Capacitance StoredE Energy, µJ) (mJ) EC (µ 8 4 100 TJ = 25 °C TJ = 110 °C 3 2 1 0 0 100 200 300 400 500 600 10 10E-6 700 ReverseVVoltage, (V) VR (V) 1E-3 Figure 8. Non-repetitive peak forward surge current versus pulse duration (sinusoidal waveform) Figure 7. Capacitance Stored Energy 0.5 1 0.3 0.1 100E-3 0.05 0.02 0.01 SinglePulse 10E-3 1E-3 1E-6 10E-6 100E-6 1E-3 T (Sec) 10E-3 Figure 9. Transient Thermal Impedance 4 C3D10065I Rev. E, 01-2018 10E-3 tp (s) Time, tp (s) R Thermal Resistance (˚C/W) 100E-6 100E-3 1 Package Dimensions Package TO-220-2 Recommended Solder Pad Layout TO-220-2 Part Number Package Marking C3D10065I Isolated TO-220-2 C3D10065I Note: Recommended soldering profiles can be found in the applications note here: http://www.wolfspeed.com/power_app_notes/soldering 5 C3D10065I Rev. E, 01-2018 Diode Model Diode Model CSD04060 Vf T = VT + If*RT VT= 0.965 + (Tj * -1.3*10-3) RT= 0.096 + (Tj * 1.06*10-3) VfT = VT + If * RT VT = 0.94 + (TJ * -1.3*10-3) RT = 0.044 + (TJ * 4.4*10-4) VT RT Note: Tj = Diode Junction Temperature In Degrees Celsius, valid from 25°C to 175°C Notes • RoHS Compliance The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS2), as implemented January 2, 2013. RoHS Declarations for this product can be obtained from your Wolfspeed representative or from the Product Ecology section of our website at http:// www.wolfspeed.com/power/tools-and-support/product-ecology. • REACh Compliance REACh substances of high concern (SVHCs) information is available for this product. Since the European Chemical Agency (ECHA) has published notice of their intent to frequently revise the SVHC listing for the foreseeable future,please contact a Cree representative to insure you get the most up-to-date REACh SVHC Declaration. REACh banned substance information (REACh Article 67) is also available upon request. • This product has not been designed or tested for use in, and is not intended for use in, applications implanted into the human body nor in applications in which failure of the product could lead to death, personal injury or property damage, including but not limited to equipment used in the operation of nuclear facilities, life-support machines, cardiac defibrillators or similar emergency medical equipment, aircraft navigation or communication or control systems, or air traffic control systems. Related Links • • • Cree SiC Schottky diode portfolio: http://www.wolfspeed.com/Power/Products#SiCSchottkyDiodes Schottky diode Spice models: http://www.wolfspeed.com/power/tools-and-support/DIODE-model-request2 SiC MOSFET and diode reference designs: http://go.pardot.com/l/101562/2015-07-31/349i Copyright © 2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree, the Cree logo, and Zero Recovery are registered trademarks of Cree, Inc. 6 C3D10065I Rev. E, 01-2018 Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 Fax: +1.919.313.5451 www.cree.com/power
C3D10065I 价格&库存
很抱歉,暂时无法提供与“C3D10065I”相匹配的价格&库存,您可以联系我们找货
