KBP210 L
KBP210 L
    MDD(辰达半导体)
    SIP4
    BRIDGE RECTIFIER KBP 1KV 2A
KBP210 L 数据手册
PART CODE: KBP2100000L20A SPECIFICATION SHEET SPECIFICATION SHEET NO. N0729-KBP2100000L20A DATE July 29, 2021 REVISION A0 DESCRIPITION Thru Hole Single Bridge Rectifier, KBP Series, KBP210 L Type, 4 Pins, Reverse Voltage 1000V Max. Forward Current 2.0A Max. Operating Temp. Range -55°C ~+150°C, Package in Bulk, 500pcs/Box RoHS/RoHS III compliant CUSTOMER CUSTOMER PART NUMBER CROSS REF. PART NUMBER ORIGINAL PART NUMBER MDD KBP210 L PART CODE KBP32100000L20A VENDOR APPROVE Issued/Checked/Approved DATE: July 29, 2021 CUSTOMER APPROVE DATE: 1 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: KBP2100000L20A THRU HOLE BRIDGE RECTIFER KBP SERIES MAIN FEATURE • The plastic package carries Underwriters Laboratory Flammability Classification 94V-0 • Glass passivated junction • Low reverse leakage • High forward surge current capability • High temperature soldering guaranteed: 260 °C/10 seconds, 0.375” (9.5mm) lead length (2.3kg) tension APPLICATION • For printed circuit board RFQ PART CODE GUIDE Request For Quotation KBP 2100000 L 20A 1 2 3 4 1) KBP: Thru Hole Single Bridge Rectifier, KBP Series 2) 2100000: Type code for original part number KBP210 L 3) L: Package code, In Bulk, 500pcs/Box. 4) 30A: Specification code for Reverse Voltage 1000V Max. Forward Current 2.0A Max. MORE ITEMS AVAILABLE KBP2005000L205 KBP2010000L210 KBP2080000L280 KBP2100000L20A KBP3005000L305 KPB3010000L310 KBP3080000L380 KPB3100000L30A KBP2020000L220 KBP2040000L240 KBP2060000L260 KBP3020000L320 KBP3040000L340 KBP3070000L360 2 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: KBP2100000L20A THRU HOLE BRIDGE RECTIFER KBP SERIES DIMENSION (Unit: Inch/mm) Image for reference Marking: KBP210 KBP 3 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: KBP2100000L20A THRU HOLE SMD SCHOTTKY BRIDGE SMD RECTIFER GENERAL BARRIER KBP RECTIFER RECTIFER SERIES MECHANICAL DATA Case Terminals Polarity Mounting Position Weight per piece JEDEC KBP molded plastic body Solder plated, Solderable per MIL-STD-750, Method 2026 Polarity symbol marking on body Any 0.050 Ounce, 1.52 grams MAX. RATING & CHARACTERISTICS Parameter SYMBOLS VALUE Min. Typical UNITS Max. Repetitive peak reverse voltage V RRM 1000 Volts RMS voltage V RMS 700 Volts DC blocking voltage V DC 1000 Volts Average forward output rectified current I AV 2.0 A at Tc= 50°C (see Note 3) I FSM Peak forward surge current 8.3ms single half 45 A sine-wave superimposed on rated load (JEDEC Method) Instantaneous forward voltage at 2.0A DC reverse current at rated DC blocking voltage TA=25℃ VF 1.10 Volts IR 5.0 µA 500 mA TA=125℃ Junction capacitance (Note 2) Thermal resistance (Note 3) Operating junction temperature range Storage temperature range CJ 40 pF R QJA 40 °C/W TJ -55 +150 T STG -55 +150 °C Note 1. Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz, resistive or inductive load, for capacitive load current derate by 20%. 2. Measured at 1MHz and applied reverse voltage of 4.0V D.C. 3. Unit mounted on PCB with 0.47”*0.47”(12.0*12.0mm) copper pads , 0.375”(9.5mm) lead length NextGen Components, Inc. sales@NextGenComponent.com 4 www.NextGenComponent.com PART CODE: KBP2100000L20A THRU HOLE BRIDGE SMD RECTIFER GENERAL KBP RECTIFER SERIES RELIABILITY Number Experiment Items Experiment Method And Conditions Reference Documents 1 Solder Resistance Test Test 260°C± 5°C for 10 ± 2 sec. Immerse body into solder 1/16” ± 1/32" MIL-STD-750D METHOD-2031.2 2 Solderability Test 230°C ±5°C for 5 sec. MIL-STD-750D METHOD-2026.1 0 3 Pull Test 1 kg in axial lead direction for 10 sec. MIL-STD-750D METHOD-2036.4 4 Bend Test 0.5Kg Weight Applied To Each Lead, Bending Arcs 90 °C ± 5 °C For 3 Times MIL-STD-750D METHOD-2036.4 5 High Temperature Reverse Bias Test TA=100°C for 1000 Hours at VR=80% Rated VR MIL-STD-750D METHOD-1038.4 6 Forward Operation Life Test TA=25°C Rated Average Rectified Current MIL-STD-750D METHOD-1027.3 7 Intermittent Operation Life Test On state: 5 min with rated IRMS Power Off state: 5 min with Cool Forced Air. On and off for 1000 cycles. MIL-STD-750D METHOD-1036.3 8 Pressure Cooker Test 15 PSIG, TA=121°C, 4 hours MIL-S-19500 APPENOIXC 9 Temperature Cycling Test -55°C~+125°C; 30 Minutes For Dwelled Time 5 minutes for transferred time. Total: 10 cycles. MIL-STD-750D METHOD-1051.7 10 Thermal Shock Test 0°C for 5 minutes., 100°C for 5minutes, Total: 10 cycles MIL-STD-750D METHOD-1056.7 11 Forward Surge Test 8.3ms Single Sale Sine-wave One Surge. MIL-STD-750D METHOD-4066.4 12 Humidity Test TA=65°C, RH=98% for 1000 hours. MIL-STD-750D METHOD-1021.3 13 High Temperature Storage life Test 150°C for 1000 Hours MIL-STD-750D METHOD-1031.5 5 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: KBP2100000L20A THRU HOLE BRIDGE RECTIFER KBP SERIES RATINGS AND CHARACTERISTIC CURVES (For Reference Only) 6 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: KBP2100000L20A THRU HOLE BRIDGE RECTIFER KBP SERIES PACKAGE Part Type Qty. Per Box (pcs) Inner Box L*W*H (mm) Carton size L*W*H (mm) Qty. Per Carton (pcs) G. W (kg) KBP 500 300*110*32 315*245*190 5,000 8.25 DISCLAIMER NextGen Component, Inc. reserves the right to make changes to the product(s) and or information contained herein without notice. No liability is assumed as a result of their use or application. No rights under any patent accompany the sale of any such product(s) or information 7 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com
KBP210 L 价格&库存
很抱歉,暂时无法提供与“KBP210 L”相匹配的价格&库存,您可以联系我们找货
