MB4FTR
MB4FTR
    SMCDIODESOLUTIONS(桑德斯)
    SMD4
    BRIDGE RECT 1P 400V 500MA MBF
MB4FTR 数据手册
MB05F THRU MB10F Technical Data Data Sheet N1456, Rev. B MB05F THRU MB10F SINGLE PHASE 0.8AMP SURFACE MOUNT GLASS PASSIVATED BRIDGE RECTIFIER Features Glass passivated die construction Low forward voltage drop High current capability High surge current capability Designed for surface mount application Plastic material-UL flammability 94V-0 This is a Pb − Free Device “-HF” suffix is for Halogen Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request           MBF Circuit Diagram Mechanical Data      Case: MBF, Molded plastic Terminals: Plated leads solderable per MIL-STD-202, Method 208 Polarity: as marked on case Mounting Position: Any Lead Free: For RoHS / Lead Free Version Maximum Ratings @TA=25°C unless otherwise specified Type Number Symbol MB05F-HF THRU MB10F-HF Marking Code MB05F MB1F MB05FH MB1FH MB2F MB4F MB6F MB8F MB10F Units MB2FH MB4FH MB6FH MB8FH MB10FH Peak Repetitive Reverse Voltage DC Blocking Voltage VRRM VDC 50 100 200 400 600 800 1000 V RMS Voltage VRMS 35 70 140 280 420 480 700 V Average Rectified Output Current (Note1)@TA=40℃ (Note 2)@TA=40℃ Non-Repetitive Peak Forward Surge Current 8.3ms Single half sine-wave superimposed on rated load (JEDEC Method) IO 0.5 0.8 A IFSM 30 A  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  MB05F THRU MB10F Technical Data Data Sheet N1456, Rev. B Electrical Characteristics:@TA=25°C unless otherwise specified Type Number Symbol MB05F-HF THRU MB10F-HF Marking Code MB05F MB1F MB2F MB4F MB6F MB8F MB10F Units MB05FH MB1FH MB2FH MB4FH MB6FH MB8FH MB10FH VFM 1.1 V Peak Reverse Current @TA = 25°C At Rated DC Blocking Voltage @TA = 125°C IR 5 500 μA Typical Junction Capacitance (Note 3) Cj 13 pF Forward Voltage per element @IF =0.8A * Pulse width < 300 µs, duty cycle < 2% Thermal-Mechanical Specifications:@TA=25°C unless otherwise specified Type Number MB05F-HF THRU MB10F-HF Marking Code Typical Thermal Resistance per leg Operating Junction and Storage Temperature Range Symbol MB05F MB1F MB2F MB4F MB6F MB8F MB10F Units MB05FH MB1FH MB2FH MB4FH MB6FH MB8FH MB10FH RθJA RθJL 60 16 °C/W TJ ,TSTG -55+150 °C Note: 1. Mounted on glass epoxy PC board with 1.3mm2 solder pad.. 2. Measured at 1.0 MHz and applied reverse voltage of 4.0V D.C. 3. Thermal REsistance From Junction to Ambient Ratings and Characteristics Curves  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  MB05F THRU MB10F Technical Data Data Sheet N1456, Rev. B Ordering Information Device MB05F THRU MB10F MB05FTR THRU MB10F TR Marking Diagram Package Plating Shipping MBF Pure Sn 5000pcs / reel MBF Pure Sn 5000pcs / reel For information on tape and reel specifications, including part orientation and tape sizes, please refer to our tape and reel packaging specification. Where XXXXX is YYWWL MB05F MB05FH YY WW L = Type Number = Marking Code = Year = Week = Lot Number Cautions:Molding resin Epoxy resin UL:94V-0 MB05F MB05F-HF  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  MB05F THRU MB10F Technical Data Data Sheet N1456, Rev. B Mechanical Dimensions MBF(Inches/Millimeters) Carrier Tape & Reel Specification MBF A0 Millimeters Min. Max. 5.41 5.21 B0 7.10 7.30 D0 D1 P0 1.50 1.40 3.90 1.60 P1 7.90 8.10 P2 1.95 2.05 E 1.65 1.85 K0 1.55 1.75 F 5.45 5.55 W 11.90 12.10 T 0.24 0.30 10P0 39.80 40.20 SYMBOL  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  1.60 4.10 MB05F THRU MB10F Technical Data Data Sheet N1456, Rev. B DISCLAIMER: 1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product characteristics. Before ordering, purchasers are advised to contact the SMC Diode Solutions sales department for the latest version of the datasheet(s). 2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment, medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by means of users’ fail-safe precautions or other arrangement . 3- In no event shall SMC Diode Solutions be liable for any damages that may result from an accident or any other cause during operation of the user’s units according to the datasheet(s). SMC Diode Solution assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information, products or circuits described in the datasheets. 4- In no event shall SMC Diode Solutions be liable for any failure in a semiconductor device or any secondary damage resulting from use at a value exceeding the absolute maximum rating. 5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC Diode Solutions. 6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC Diode Solutions. 7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and regulations.  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com 
MB4FTR 价格&库存
很抱歉,暂时无法提供与“MB4FTR”相匹配的价格&库存,您可以联系我们找货
