DBL201G – DBL209G
Taiwan Semiconductor
2A, 50V - 1400V Standard Bridge Rectifier
FEATURES
KEY PARAMETERS
Ideal for printed circuit board
Reliable low cost construction utilizing molded plastic technique
High surge current capability
UL Recognized File # E-326854
AEC-Q101 qualified available
RoHS Compliant
Halogen-free according to IEC 61249-2-21
APPLICATIONS
PARAMETER
VALUE
UNIT
IF
2
A
VRRM
50 - 1400
V
IFSM
50
A
TJ MAX
150
°C
Package
DBL
Configuration
Quad
● Switching mode power supply (SMPS)
● Adapters
● Lighting application
MECHANICAL DATA
Case: DBL
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: As marked
Weight: 0.380g (approximately)
DBL
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
Marking code on the
device
Repetitive peak reverse
voltage
Reverse voltage, total rms
value
Forward current
Peak forward surge
current, 8.3ms single half
sine-wave superimposed
on rated load
Rating for fusing (t
很抱歉,暂时无法提供与“DBL207GHC1G”相匹配的价格&库存,您可以联系我们找货
