FR2KTR
FR2KTR
    SMCDIODESOLUTIONS(桑德斯)
    SMB(DO-214AA)
    DIODE GEN PURP 800V 2A SMB
FR2KTR 数据手册
FR2A-FR2K Technical Data Data Sheet N0439, Rev. A FR2A-FR2M 2.0A SURFACE MOUNT FAST RECOVERY RECTIFIER Features          SMB Circuit Diagram Glass passivated Die Construction Ideal Suited for Automatic Assembly Low Forward Voltage Drop, High Efficiency Low Power Loss Fast Recovery Time The plastic package carries Underwriters Laboratory Flammability Classification 94V-0 This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request Mechanical Data     Case: SMB molded plastic Terminals: Solder plated, solderable per MIL-STD-750, Method 2026 Polarity: Color band denotes cathode end Mounting Position: Any Weight: 0.09grams Maximum Ratings and Electrical Characteristics @TA=25°C unless otherwise specified Characteristic Symbol FR2A FR2B FR2D FR2G FR2J FR2K FR2M Units 50 100 200 400 600 800 1000 V 35 70 140 280 420 560 V Peak Repetitive Reverse Voltage DC Blocking Voltage Maximum RMS voltage VRRM VDC VRMS Average forward rectified output current @TL = 90°C I(AV) 2.0 A Non-Repetitive Peak Forward Surge Current 8.3ms Single half sine-wave superimposed on rated load (JEDEC Method) IFSM 50 A Forward Voltage VFM 1.30 V IRM 5.0 300.0 µA @IF =2.0A Peak Reverse Current @TA = 25°C At Rated DC Blocking Voltage @TA = 125°C Reverse recovery time (Note 1) trr 150 250 700 500 ns Typical Junction Capacitance (Note 2) Typical Thermal Resistance (Note 3) CJ RθJL 50 20 pF °C/W Operating and Storage Temperature Range TSTG -55 to +150 °C Note: 1. Reverse recovery condition IF=0.5A, IR=1.0A, Irr=0.25A 2. Measured at 1MHz and applied reverse voltage of 4.0V D.C. 3. Mounted on P.C.B Board with 8.0mm2 land area.  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  FR2A-FR2K Technical Data Data Sheet N0439, Rev. A Ratings and Characteristics Curves  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  FR2A-FR2K Technical Data Data Sheet N0439, Rev. A Mechanical Dimensions SMB SYMBOL Ordering Information Device FR2A-FR2M Package SMB Millimeters Inches Min. Max. Min. Max. A 3.30 3.94 0.130 0.155 B 4.06 4.70 0.160 0.185 C 1.80 2.20 0.071 0.087 D 0.152 0.305 0.006 0.012 E 4.80 5.59 0.189 0.220 F 2.10 2.60 0.083 0.102 G 0.051 0.203 0.002 0.008 H 0.76 1.52 0.030 0.060 Marking Diagram Where XXXXX is YYWWL Shipping FR2A YY WW L 3000pcs / reel For information on tape and reel specifications, including part orientation and tape sizes, please refer to our tape and reel packaging specification. = Part Name = Year = Week = Lot Number Cautions:Molding resin Epoxy resin UL:94V-0 Carrier Tape & Reel Specification SMB SYMBOL A B C d E F P P0 P1 T W Millimeters Min. Max. 3.99 5.72 3.23 1.40 1.40 5.60 7.90 3.90 1.90 - 4.19 5.92 3.43 1.60 1.60 5.70 8.10 4.10 2.10 0.60 11.80 12.20  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  FR2A-FR2K Technical Data Data Sheet N0439, Rev. A DISCLAIMER: 1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product characteristics. Before ordering, purchasers are advised to contact the SMC - Sangdest Microelectronics (Nanjing) Co., Ltd sales department for the latest version of the datasheet(s). 2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment, medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by means of users’ fail-safe precautions or other arrangement . 3- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any damages that may result from an accident or any other cause during operation of the user’s units according to the datasheet(s). SMC - Sangdest Microelectronics (Nanjing) Co., Ltd assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information, products or circuits described in the datasheets. 4- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any failure in a semiconductor device or any secondary damage resulting from use at a value exceeding the absolute maximum rating. 5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and regulations..  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com 
FR2KTR 价格&库存
很抱歉,暂时无法提供与“FR2KTR”相匹配的价格&库存,您可以联系我们找货
