ABF10UTR
ABF10UTR
    SMCDIODESOLUTIONS(桑德斯)
    SMD4
    BRIDGE RECT 1PHASE 1KV 1A ABF
ABF10UTR 数据手册
ABF2U THRU ABF10U Technical Data Data Sheet N1827, Rev. A ABF2U THRU ABF10U SINGLE PHASE 1.0AMP SURFACE MOUNT GLASS PASSIVATED BRIDGE RECTIFIER Features Glass passivated die construction Low forward voltage drop High current capability High surge current capability Designed for surface mount application Plastic material-UL flammability 94V-0 This is a Halogen Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request          ABF Circuit Diagram Mechanical Data     Case: SOPA-4, Molded plastic ABF Terminals: Plated leads solderable per MIL-STD-202, Method 208 Polarity: Polarity symbols marked on case Mounting Position: Any Maximum Ratings@T unless Characteristics otherwise specified@TA=25°C unless otherwise specified A=25°C and Electrical Single Phase half wave 60Hz, resistive or inductive load. For capacitive load current derate by 20%. Characteristic ABF2U ABF4U ABF6U ABF8U VRRM 200 400 600 800 1000 VR(RMS) 140 280 420 560 700 Maximum DC blocking voltage VDC 200 400 600 800 1000 Average Rectified Output Current @TC = 100°C IF(AV) 1.0 V Peak Forward Surge Current 8.3ms Single half sine-wave superimposed on rated load (JEDEC Method) IFSM 35 A I2 t 5.08 A2 s Maximum repetitive peak reverse voltage RMS Reverse Voltage Rating for fusing (t
ABF10UTR 价格&库存
很抱歉,暂时无法提供与“ABF10UTR”相匹配的价格&库存,您可以联系我们找货
