TSP10H200S S1G
TSP10H200S S1G
    TAIWANSEMICONDUCTOR(台湾半导体)
    TO-277
    DIODE SCHOTTKY 200V 10A TO277A
TSP10H200S S1G 数据手册
TSP10H200S Taiwan Semiconductor 10A, 200V Trench Schottky Surface Mount Rectifier FEATURES ● ● ● ● ● ● ● ● ● KEY PARAMETERS Patented Trench Schottky technology Excellent high temperature stability Low forward voltage Low power loss / high efficiency High forward surge capability Ideal for automated placement Moisture sensitivity level: level 1, per J-STD-020 RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 10 A VRRM 200 V IFSM 180 A TJ MAX 150 °C Package TO-277A (SMPC) Configuration Single die APPLICATIONS ● Switching mode power supply (SMPS) ● Adapters ● DC to DC converter MECHANICAL DATA ● ● ● ● ● ● Case: TO-277A (SMPC) Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 0.095g (approximately) TO-277A (SMPC) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device TSP10H200S UNIT 10H200 Repetitive peak reverse voltage VRRM 200 V Reverse voltage, total rms value VR(RMS) 140 V Forward current Surge peak forward current, 8.3ms single half sine wave superimposed on rated load Junction temperature IF 10 A IFSM 180 A TJ -55 to +150 °C Storage temperature TSTG -55 to +150 °C 1 Version: E2103 TSP10H200S Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT RӨJL 15 °C/W Junction-to-lead thermal resistance ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER CONDITIONS SYMBOL IF = 5A, TJ = 25°C Forward voltage IF = 10A, TJ = 25°C (1) IF = 5A, TJ = 125°C VF IF = 10A, TJ = 125°C Reverse current @ rated VR (2) TJ = 25°C IR TJ = 125°C TYP MAX UNIT 0.75 - V 0.80 0.91 V 0.59 - V 0.66 0.74 V - 100 µA - 20 mA Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE PACKAGE PACKING TSP10H200S TO-277A (SMPC) 6,000 / Tape & Reel 2 Version: E2103 TSP10H200S Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 10000 10 CAPACITANCE (pF) 8 6 4 1000 100 2 0 25 50 75 100 125 f=1.0MHz Vsig=50mVp-p 10 150 0.1 1 LEAD TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) TJ=150°C 0.1 TJ=125°C 0.01 TJ=100°C 0.001 TJ=25°C 0.0001 0.00001 10 20 30 40 50 60 70 100 Fig.4 Typical Forward Characteristics 10 80 90 100 100 10 10 UF1DLW TJ=150°C 1 TJ=125°C TJ=125°C TJ=25°C 0.1 TJ=100°C 1 TJ=25°C 0.01 Pulse width 300μs 1% duty cycle Pulse width 0.8 1.0 0.1 0.2 0.001 0.4 0.3 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) 0.4 0.6 0.5 0.6 0.7 0.8 0.9 1 1.1 FORWARD VOLTAGE (V) Fig.5 Maximum Non-Repetitive Forward Surge Current 200 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (mA) Fig.3 Typical Reverse Characteristics 1 10 REVERSE VOLTAGE (V) (A) AVERAGE FORWARD CURRENT (A) 12 180 8.3ms single half sine wave 160 140 120 100 80 60 40 20 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: E2103 1.2 TSP10H200S Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS TO-277A (SMPC) SUGGESTED PAD LAYOUT MARKING DIAGRAM P/N YW F 4 = Marking Code = Date Code = Factory Code Version: E2103 TSP10H200S Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 5 Version: E2103
TSP10H200S S1G 价格&库存
很抱歉,暂时无法提供与“TSP10H200S S1G”相匹配的价格&库存,您可以联系我们找货
