BAV19WS RRG
BAV19WS RRG
    TAIWANSEMICONDUCTOR(台湾半导体)
    SC-90
BAV19WS RRG 数据手册
BAV19WS/BAV20WS/BAV21WS Taiwan Semiconductor 200mA, 120-250V High Voltage SMD Switching Diode FEATURES KEY PARAMETERS ● ● ● ● ● Low power loss, high efficiency Ideal for automated placement High surge current capability Moisture sensitivity level: level 1, per J-STD-020 Compliant to RoHS directive 2011/65/EU and in accordance to WEEE 2002/96/EC ● Halogen-free according to IEC 61249-2-21 APPLICATIONS ● ● ● ● Switching mode power supply (SMPS) Adapters Lighting application On-board DC/DC converter PARAMETER VALUE UNIT IF(AV) 200 mA VRRM 120-250 V IFSM 2.5 A VF at IF=200mA 1.25 V TJ MAX. 150 °C Package SOD-323F Configuration Single die MECHANICAL DATA ● ● ● ● ● ● Case: SOD-323F Molding compound meets UL 94 V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 1A whisker test Polarity: Indicated by cathode band Weight: 4.5 ± 0.5 mg (approximately) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL BAV19WS BAV20WS S5 Marking code on the device Power dissipation PD 200 mW Average forward current IF 200 mA 120 S6 BAV21WS UNIT 200 S7 Repetitive peak reverse voltage Pulse Width = 1 s , Square Wave Peak forward surge current Pulse Width = 1 μs , Square Wave Junction temperature range VRRM 250 V TJ -65 to +150 °C Storage temperature range TSTG -65 to +150 °C 0.5 IFSM A 2.5 1 Version: I1804 BAV19WS/BAV20WS/BAV21WS Taiwan Semiconductor ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER CONDITIONS Forward voltage per diode IF = 100mA, TJ = 25°C (1) IF = 200mA, TJ = 25°C SYMBOL MIN MAX - 1.00 - 1.25 120 - 200 - 250 - IR - 100 nA CJ - 5 pF trr - 50 ns VF BAV19WS Reverse voltage BAV20WS IR=100µA, TJ = 25°C VR BAV21WS Reverse current (2) BAV19WS VR=100V TJ = 25°C BAV20WS VR=150V TJ = 25°C BAV21WS VR=200V TJ = 25°C 1 MHz, VR=0V Junction capacitance IF=IR=30mA, RL=100Ω, Reverse recovery time IRR=3mA UNIT V V Notes: 1. Pulse test with PW=0.3 ms 2. Pulse test with PW=30 ms ORDERING INFORMATION PART NO. PACKAGE PACKING BAV19WS RRG SOD-323F 3K / 7" Reel BAV19WS RR SOD-323F 3K / 7" Reel BAV19WS R9G SOD-323F 10K / 13" Reel BAV19WS R9 SOD-323F 10K / 13" Reel BAV20WS RRG SOD-323F 3K / 7" Reel BAV20WS RR SOD-323F 3K / 7" Reel BAV20WS R9G SOD-323F 10K / 13" Reel BAV20WS R9 SOD-323F 10K / 13" Reel BAV21WS RRG SOD-323F 3K / 7" Reel BAV21WS RR SOD-323F 3K / 7" Reel BAV21WS R9G SOD-323F 10K / 13" Reel BAV21WS R9 SOD-323F 10K / 13" Reel 2 Version: I1804 BAV19WS/BAV20WS/BAV21WS Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Typical Forward Characteristics Fig.2 Typical Reverse Characteristics 100 IR, Instantaneous Reverse Current (μA) IF,Instantaneous Forward Current (A) 1 TA=150oC TA=125oC TA=75oC TA=25oC TA=0oC TA=-40oC 0.1 0.01 0.001 TA=125oC 10 TA=75oC 1 TA=25oC 0.1 TA=0oC 0.01 0.001 0.0001 0 0.2 0.4 0.6 0.8 1 1.2 1.4 0 50 100 150 200 250 VR, Instantaneous Reverse Voltage (V) VF, Instantaneous Forward Voltage (V) Fig.3 Typical Capacitance VS. Reverse Voltage Fig.3 Power Derating Curve 250 3.0 PD, Power Dissipation (mW) 4.0 CT, Total Capacitance (pF) TA=150oC TA=-40oC f=1.0MHz 2.0 1.0 0.0 200 150 100 50 0 0 10 20 30 40 0 VR, Reverse Voltage (V) 50 100 150 200 o TA, ambient Temperature ( C) 3 Version: I1804 BAV19WS/BAV20WS/BAV21WS Taiwan Semiconductor PACKAGE OUTLINE DIMENSION SOD-323F DIM. Unit (mm) Unit (inch) Min Max Min Max A 1.15 1.35 0.045 0.053 B 2.30 2.80 0.091 0.110 C 0.25 0.40 0.010 0.016 D 1.60 1.80 0.063 0.071 E 0.80 1.10 0.031 0.043 F 0.05 0.25 0.002 0.010 SUGGEST PAD LAYOUT DIM. 4 Unit (mm) Unit (inch) Typ. Typ. A 0.63 0.025 B 0.83 0.033 C 1.60 0.063 D 2.86 0.113 Version: I1804 BAV19WS/BAV20WS/BAV21WS Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 5 Version: I1804
BAV19WS RRG 价格&库存
很抱歉,暂时无法提供与“BAV19WS RRG”相匹配的价格&库存,您可以联系我们找货
BAV19WS RRG
  • 10+0.56057
  • 100+0.43612
  • 250+0.34664
  • 1000+0.31167
  • 3000+0.29047
BAV19WS RRG
  • 3000+0.429843000+0.05580
  • 9000+0.360969000+0.04686
库存:5930
BAV19WS RRG
  • 1+2.108511+0.27372
  • 10+1.3034510+0.16921
  • 50+0.9317950+0.12097
  • 100+0.80837100+0.10494
  • 500+0.59073500+0.07669
库存:5930
BAV19WS RRG
  • 10+0.6032310+0.07831
  • 100+0.46918100+0.06091
  • 250+0.37343250+0.04848
  • 1000+0.335131000+0.04351
  • 3000+0.312503000+0.04057
BAV19WS RRG
    • 1+0.29895
    • 200+0.11934
    • 500+0.11535
    • 1000+0.11340
