BAV19WS-G/BAV20WS-G/BAV21WS-G
Taiwan Semiconductor
Small Signal Product
200mA, 120V - 250V Switching Diodes
FEATURES
- Fast Switching Speed
- Surface Mount Package Ideally Suited For Automatic Insertion
- High Conductance
- Packing code with suffix "G" means
green compound (halogen-free)
- Compliant to RoHS Directive 2011/65/EU and
in accordance to WEEE 2002/96/EC
SOD-323
- Halogen-free according to IEC 61249-2-21
APPLICATION
Surface mount fast switching diode
General purpose small signal switching
MECHANICAL DATA
- Case: SOD-323 small outline plastic package
- Moisture sensitivity level 1
- Polarity: Indicated by cathode band
- Weight: 4.36 ± 0.5 mg
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS (TA=25°C unless otherwise noted)
PARAMETER
SYMBOL
BAV19WS-G BAV20WS-G BAV21WS-G
UNIT
Average Rectified Output Current
IO
200
mA
Repetitive Peak Reverse Voltage
VRRM
120
200
250
V
VR
100
150
200
V
DC Reverse Voltage
Non-Repetitive Peak Forward
Surge Current
Pulse Width = 1 μs
Pulse Width = 1 s
Repetitive Peak Forward Surge Current
Power Dissipation
Thermal Resistance Junction to Ambient
Junction and Storage Temperature Range
PARAMETER
Breakdown Voltage
(Note 1)
Forward Voltage
Reverse Leakage Current
(Note 2)
Junction Capacitance
625
mA
PD
200
mW
RθJA
625
°C/W
TJ , TSTG
-65 to 150
°C
MIN
MAX
120
200
250
1.00
1.25
IR
100
nA
CJ
5
pF
trr
50
ns
BAV19WS-G
V(BR)R
BAV21WS-G
IF=100mA
IF=200mA
A
0.5
IFRM
SYMBOL
BAV20WS-G
2.5
IFSM
VF
UNIT
V
V
BAV19WS-G
BAV20WS-G
BAV21WS-G
VR=0, f=1.0MHz
Reverse Recovery Time (Note 3)
Note 1: Test condition : IR= 100μA
Note 2: Test condition : BAV19WS-G @ VR=100V, BAV20WS-G @ VR=150V, BAV21WS-G @ VR=200V
Note 3: Test condition : IF= IR= 30mA , RL=100Ω , Irr=0.1xIR
Document Number: DS_S0000021
Version: A15
RATINGS AND CHARACTERISTICS CURVES
Fig. 1 Typical Forward Characteristics
Fig. 2 Typical Reverse Characteristics
100
IR, Instantaneous Reverse Current (μA)
IF,Instantaneous Forward Current (A)
1
TA=150oC
TA=125oC
TA=75oC
TA=25oC
TA=0oC
TA=-40oC
0.1
0.01
0.001
0.4
0.6
0.8
1
1.2
10
TA=125oC
1
TA=75oC
0.1
TA=25oC
0.01
TA=0oC
0.001
TA=-40oC
TA=150oC
0.0001
50
100
150
200
250
VR, Instantaneous Reverse Voltage (V)
VF, Instantaneous Forward Voltage (V)
Fig. 4 Power Derating Curve
Fig. 3 Typical Capacitance VS. Reverse Voltage
250
4.0
200
3.0
f=1.0 MHz
PD, Power Dissipation (mW)
CT, Total Capacitance (pF)
3.5
2.5
2.0
1.5
1.0
0.5
150
100
50
VR, Reverse Voltage (V)
30
40
80
120
160
200
TA, ambient Temperature (oC)
Version: A15
ORDERING INFORMATION
PART NO.
PACKING CODE
BAVxxWS-G
(Note 1, 2)
RR
PACKING CODE
SUFFIX
PACKAGE
PACKING
SOD-323
3K / 7" Reel
G
Note 1: "xx" is Device Code from "BAV19WS-G" to "BAV21WS-G".
Note 2: Whole series with green compound
EXAMPLE
PREFERRED P/N
PART NO.
PACKING CODE
BAV19WS-G RRG
BAV19WS-G
RR
PACKING CODE
DESCRIPTION
SUFFIX
G
Green compound
DIMENSIONS
SOD-323
B
DIM.
A
C
D
E
Unit (mm)
Unit (inch)
Min
Max
Min
Max
A
1.150
1.400
0.045
0.055
B
2.300
2.700
0.091
0.106
C
0.250
0.450
0.010
0.018
D
1.600
1.800
0.063
0.071
E
0.800
1.000
0.031
0.039
F
0.050
0.177
0.002
0.007
G
0.475 REF
0.019 REF
H
0.100
0.004
H
F
G
SUGGESTED PAD LAYOUT
Unit (mm)
Unit (inch)
Typ.
Typ.
G
1.600
0.063
X
0.630
0.025
X1
2.850
0.112
Y
0.830
0.033
DIM.
Note: The suggested land pattern dimensions have been provided for reference only, as actual pad layouts may vary depending on application
MARKING
Part No.
Marking
BAV19WS-G
A8
BAV20WS-G
T2
BAV21WS-G
T3
Version: A15
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC's terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
Version: A15
很抱歉,暂时无法提供与“BAV21WS-G RRG”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.24495
- 200+0.09774
- 500+0.09450
- 1000+0.09288
- 国内价格 香港价格
- 3000+0.330803000+0.04278
- 6000+0.294756000+0.03812
- 9000+0.276349000+0.03574
- 15000+0.2556215000+0.03306
- 21000+0.2433521000+0.03147
- 30000+0.2314030000+0.02992
- 国内价格 香港价格
- 1+1.670521+0.21601
- 10+1.0204010+0.13194
- 100+0.63001100+0.08147
- 500+0.45792500+0.05921
- 1000+0.402131000+0.05200
