DBL153GHC1G
DBL153GHC1G
    TAIWANSEMICONDUCTOR(台湾半导体)
    DIP4
    BRIDGE RECT 1PHASE 200V 1.5A DBL
DBL153GHC1G 数据手册
DBL151G – DBL159G Taiwan Semiconductor 1.5A, 50V - 1400V Standard Bridge Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available Ideal for printed circuit board Reliable low cost construction utilizing molded plastic technique High surge current capability UL Recognized File # E-326854 RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS PARAMETER VALUE UNIT IF 1.5 A VRRM 50 - 1400 V IFSM 50 A TJ MAX 150 °C Package DBL Configuration Quad ● Switching mode power supply (SMPS) ● Adapters ● Lighting application MECHANICAL DATA ● ● ● ● ● ● Case: DBL Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: As marked Weight: 0.360g (approximately) DBL ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER Marking code on the device Repetitive peak reverse voltage Reverse voltage, total rms value Forward current Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load Rating for fusing (t
DBL153GHC1G 价格&库存
很抱歉,暂时无法提供与“DBL153GHC1G”相匹配的价格&库存,您可以联系我们找货
