BAV20W RHG
BAV20W RHG
    TAIWANSEMICONDUCTOR(台湾半导体)
    SOD-123F
BAV20W RHG 数据手册
BAV19W/BAV20W/BAV21W Taiwan Semiconductor Small Signal Product 410mW High Voltage SMD Switching Diode FEATURES - These diodes are also available in DO-35, LL34 Package - Surface Mount Device Type - Moisture sensitivity level 1 - Matte Tin (Sn) lead finish with Nickel (Ni) underplate - Pb free version and RoHS compliant - Packing code with suffix "G" means green compound (halogen-free) SOD-123F MECHANICAL DATA - Case: Flat lead SOD-123F small outline plastic package - Terminal: Matte tin plated, lead free, solderable per MIL-STD-202, Method 208 guaranteed - High temperature soldering guaranteed: 260°C/10s - Polarity: Indicated by cathode band - Weight: 4.85 ± 0.5mg MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS (TA=25°C unless otherwise noted) PARAMETER SYMBOL VALUE UNIT PD 410 mW Repetitive Peak Reverse Voltage VRRM 250 V Repetitive Peak Forward Current IFRM 625 mA IO 200 mA Power Dissipation Mean Forward Current Non-Repetitive Peak Forward Surge Current Pulse Width = 1 μs Pulse Width = 1 s 4 IFSM Thermal Resistance (Junction to Ambient) RθJA 375 Junction and Storage Temperature Range TJ , TSTG -65 to +150 PARAMETER Reverse Breakdown Voltage (Note 1) Forward Voltage Reverse Leakage Current (Note 2) Junction Capacitance SYMBOL BAV19W BAV20W V(BR) BAV21W IF = 100 mA IF = 200 mA A 1 o C/W o MIN MAX 120 - 200 - 250 - C UNIT V - 1 - 1.25 IR - 100 nA CJ - 5 pF trr - 50 ns VF V BAV19W BAV20W BAV21W VR = 0 , f = 1.0 MHz Reverse Recovery Time (Note 3) Note 1 : Test condition : IR= 100μA Note 2 : Test condition : BAV19W @ VR=100V, BAV20W @ VR=150V, BAV21W @ VR=200V Note 3 : Test condition : IF= IR= 30mA , RL=100Ω , Irr=3mA Document Number: DS_S1501003 Version: E15 BAV19W/BAV20W/BAV21W Taiwan Semiconductor Small Signal Product RATINGS AND CHARACTERISTICS CURVES (TA=25°C unless otherwise noted) Fig. 1 Admissible Power Dissipation Curve Fig. 2 Typicla Forward Characteristics 300 1000 100 Forward Current (mA) Power Dissipation (mW) 250 200 150 100 10 1 0.1 50 0 0 25 50 75 100 125 150 Ambient Temperature (oC) 0.01 0 1 2 Forward Voltage (V) Fig. 3 Leakage Current Fig. VS. 3 Junction Temperature 100 Leakage Current (uA) 10 1 0.1 0.01 0 100 200 Junction Temperature (oC) Document Number: DS_S1501003 Version: E15 BAV19W/BAV20W/BAV21W Taiwan Semiconductor Small Signal Product ORDER INFORMATION (EXAMPLE) BAV19W RHG Green compound code Packing code Part no. PACKAGE OUTLINE DIMENSIONS SOD-123F DIM. Unit (mm) Unit (inch) Min Max Min Max A 1.50 1.70 0.059 0.067 B 3.30 3.90 0.130 0.154 C 0.50 0.70 0.020 0.028 D 2.50 2.70 0.098 0.106 E 0.80 1.15 0.031 0.045 F 0.05 0.20 0.002 0.008 SUGGEST PAD LAYOUT Unit (mm) Unit (inch) Typ. Typ. C 2.86 0.113 G 1.52 0.060 X 1.34 0.053 X1 4.20 0.165 Y 1.80 0.071 DIM. MARKING CODE Part no. Marking BAV19W H1 BAV20W H2 BAV21W H3 Document Number: DS_S1501003 Version: E15 BAV19W/BAV20W/BAV21W Taiwan Semiconductor Small Signal Product Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied,to any intellectual property rights is granted by this document. Except as provided in TSC's terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or seling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. Document Number: DS_S1501003 Version: E15
BAV20W RHG 价格&库存
很抱歉,暂时无法提供与“BAV20W RHG”相匹配的价格&库存,您可以联系我们找货
BAV20W RHG
  • 10+0.56584
  • 100+0.44019
  • 250+0.34988
  • 1000+0.31454
  • 3000+0.29310
库存:2004
BAV20W RHG
  • 3000+0.388663000+0.05028
  • 6000+0.347176000+0.04491
  • 9000+0.326009000+0.04218
  • 15000+0.3021915000+0.03910
  • 21000+0.2880721000+0.03727
  • 30000+0.2743530000+0.03549
库存:5382
BAV20W RHG
  • 1+1.940711+0.25106
  • 10+1.1814910+0.15285
  • 100+0.73278100+0.09480
  • 500+0.53508500+0.06922
  • 1000+0.470721000+0.06090
库存:5382
BAV20W RHG
  • 10+0.6097010+0.07888
  • 100+0.47431100+0.06136
  • 250+0.37735250+0.04882
  • 1000+0.338921000+0.04385
  • 3000+0.316213000+0.04091
库存:2004
