BAT42W/BAT43W
Taiwan Semiconductor
Small Signal Product
Surface Mount, Switching Schottky Barrier Diode
FEATURES
- Low forward voltage drop
- Surface mount device type
- Moisture sensitivity level (MSL): 1
- Compliant to RoHS Directive 2011/65/EU and
in accordance to WEEE 2002/96/EC
- Halogen-free according to IEC 61249-2-21
SOD-123
MECHANICAL DATA
- Case: Bend lead SOD-123 small outline plastic package
- Terminal: Matte tin plated, lead free,
solderable per MIL-STD-202, Method 208 guaranteed
- High temperature soldering guaranteed : 260°C/10s
- Polarity: Indicated by cathode band
- Weight: 0.01 g (approximately)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS (TA=25°C unless otherwise noted)
PARAMETER
SYMBOL
Repetitive Peak Reverse Voltage
VRRM
Working Peak Reverse Voltage
VRWM
DC Blocking Voltage
Forward Continue Current
Repetitive Peak Forward Current
Non-Repetitive Peak Forward Surge Current
30
UNIT
V
VR(RMS)
21
V
(Note 1)
IFM
200
mA
@ t < 1.0s
IFM
500
mA
@ t < 1.0 ms
(Note 1)
IFSM
4
A
IFRM
500
mA
Pd
200
mW
IF=200mA
1.0
IF=2mA
Maximum Forward Voltage
BAT43W
VR
RMS Reverse Voltage
Power Dissipation
BAT42W
0.33
0.40
IF=15mA
0.45
IF=50mA
0.65
IF=10mA
VF
V
Peak Reverse Current
@ VR=25V & TJ=25°C
IR
500
nA
Junction Capacitance
VR=1V, f=1.0MHz
CJ
10
pF
Reverse Recovery Time
(Note 2)
trr
5
ns
Thermal Resistance Junction to Ambient
(Note 1)
RθJA
625
°C
TJ
-55 to +125
°C
TSTG
-55 to +125
°C
Operating Temperature Range
Storage Temperature Range
Notes: 1. Valid provided that terminals are kept at ambient temperature.
Notes: 2. Test conditions : IF=10mA, IR=10mA, RL=100Ω, IRR=1mA
Version: G1605
BAT42W/BAT43W
RATINGS AND CHARACTERISTICS CURVES
Fig.1 Typical Forward Characteristics
Fig. 2 Typical Forward Characteristics
100
100
10
Forward Current (mA)
Instantaneous Forward Current (μA)
1000
BAT43W
1
BAT42W
0.1
10
0.01
10
100
1
1000
100
1000
Instantaneous Forward Voltage (mV)
Fig. 3 Typical Reverse Characteristics
Fig. 4 Typical Reverse Characteristics
120
100
Fig. 4
line 1
14.5
Reverse Current (nA)
Reverse Leakage Current (nA)
15.5
13.5
12.5
11.5
80
BAT43W
60
line 2
40
BAT42W
9.5
100
Reverse Voltage (mV)
1000
2
8
14
32
Reverse Voltage (V)
Version: G1605
BAT42W/BAT43W
ORDERING INFORMATION
PART NO.
BAT4xW
(Note 1&2)
PACKING CODE
PACKING CODE
SUFFIX
RH
G
PACKAGE
PACKING
SOD-123
3K / 7" Reel
Note 1: "x" is Device Code from "2" - "3".
Note 2: Whole series with green compound
EXAMPLE
EXAMPLE P/N
PART NO.
PACKING CODE
BAT42W RHG
BAT42W
RH
PACKING CODE
SUFFIX
G
DESCRIPTION
Green compound
Version: G1605
BAT42W/BAT43W
PACKAGE OUTLINE DIMENSIONS
SOD-123
DIM.
Unit (mm)
Unit (inch)
Min
Max
Min
Max
A
1.40
1.80
0.055
0.071
B
3.55
3.85
0.140
0.152
C
0.45
0.70
0.018
0.028
D
2.55
2.85
0.100
0.112
E
0.95
1.35
0.037
0.053
F
0.05
0.15
0.002
0.006
0.50 REF
G
H
0.10
0.02 REF
0.004
SUGGEST PAD LAYOUT
DIM.
Unit (mm)
Unit (inch)
Min
Min
G
2.25
0.089
X
0.90
0.035
X1
4.05
0.159
Y
0.95
0.037
MARKING
Part No.
BAT42W
Marking
S7
BAT43W
S8
Version: G1605
BAT42W/BAT43W
CREAT BY ART
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC's terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
Version: G1605
很抱歉,暂时无法提供与“BAT43W RHG”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 3000+0.136963000+0.01775
- 国内价格 香港价格
- 1+1.588261+0.20574
- 10+0.9604210+0.12441
- 100+0.59150100+0.07662
- 500+0.42928500+0.05561
- 1000+0.376581000+0.04878
- 国内价格 香港价格
- 3000+0.309353000+0.04008
- 6000+0.275316000+0.03567
- 9000+0.257949000+0.03342
- 15000+0.2383915000+0.03088
- 21000+0.2268021000+0.02938
- 30000+0.2155430000+0.02792
- 国内价格 香港价格
- 1+1.581101+0.20500
- 10+0.9558010+0.12390
- 100+0.59650100+0.07740
- 500+0.43000500+0.05580
- 1000+0.377301000+0.04890
- 3000+0.306603000+0.03980
- 6000+0.298306000+0.03870
- 9000+0.210809000+0.02740
- 24000+0.1845024000+0.02390
