ES2AA – ES2JA
Taiwan Semiconductor
2A, 50V - 600V Super Fast Surface Mount Rectifier
FEATURES
KEY PARAMETERS
Glass passivated chip junction
Ideal for automated placement
Low profile package
Super fast recovery time for high efficiency
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF
2
A
VRRM
50 - 600
V
IFSM
50
A
TJ MAX
150
°C
APPLICATIONS
Package
DO-214AC (SMA)
Configuration
Single die
DC to DC converter
Switching mode converters and inverters
Lighting application
Snubber
Freewheeling application
MECHANICAL DATA
Case: DO-214AC (SMA)
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: Indicated by cathode band
Weight: 0.060g (approximately)
DO-214AC (SMA)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
Repetitive peak reverse voltage
VRRM
ES
2AA
ES
2AA
50
Reverse voltage, total rms value
VR(RMS)
35
PARAMETER
SYMBOL
Marking code on the device
ES
2BA
ES
2BA
100
ES
2CA
ES
2CA
150
ES
2DA
ES
2DA
200
ES
2FA
ES
2FA
300
ES
2GA
ES
2GA
400
ES
2HA
ES
2HA
500
70
105
140
210
280
350
ES
UNIT
2JA
ES
2JA
600
V
420
V
Forward current
Peak forward surge current,
8.3ms single half sine-wave
superimposed on rated load
Junction temperature
IF
2
A
IFSM
50
A
TJ
- 55 to +150
°C
Storage temperature
TSTG
- 55 to +150
°C
1
Version: M2102
ES2AA – ES2JA
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
Junction-to-lead thermal resistance
RӨJL
°C/W
Junction-to-ambient thermal resistance
RӨJA
75
°C/W
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage
CONDITIONS
ES2AA
ES2BA
ES2CA
ES2DA
ES2FA
ES2GA
ES2HA
ES2JA
(1)
Reverse current @ rated VR
TJ = 25°C
(2)
Junction capacitance
IF = 2A, TJ = 25°C
Reverse recovery time
1MHz, VR = 4.0V
IF = 0.5A, IR = 1.0A,
Irr = 0.25A
TYP
MAX
UNIT
0.95
V
1.30
V
1.70
V
10
µA
350
µA
25
pF
pF
35
ns
VF
IR
TJ = 125°C
ES2AA
ES2BA
ES2CA
ES2DA
ES2FA
ES2GA
ES2HA
ES2JA
SYMBOL
CJ
trr
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)
PACKAGE
PACKING
ES2xA
DO-214AC (SMA)
7,500 / Tape & Reel
Notes:
1. “x” defines voltage from 50V(ES2AA) to 600V(ES2JA)
2
Version: M2102
ES2AA – ES2JA
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
60
50
CAPACITANCE (pF)
2
1
40
ES2AA - ES2DA
30
ES2FA - ES2JA
10
50
75
100
125
f=1.0MHz
Vsig=50mVp-p
0.1
1
LEAD TEMPERATURE (°C)
INSTANTANEOUS FORWARD CURRENT (A)
100
TJ=125°C
10
TJ=75°C
1
TJ=25°C
0.1
40
50
60
70
80
100
Fig.4 Typical Forward Characteristics
1000
90
100
100 10
10
1
UF1DLW ES2FA - ES2GA
ES2AA - ES2DA
TJ=125°C
TJ=25°C
0.1
1
ES2HA - ES2JA
0.01
0.1
0.001
0.6
0.8
1.0
1.2
0.3
0.4
0.5
0.6
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
Pulse width 300μs
1% duty cycle
Pulse width
1.4
0.7
1.6
0.8
1.8
0.9
2.0
1
1.1
FORWARD VOLTAGE (V)
Fig.5 Maximum Non-Repetitive Forward Surge Current
60
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (μA)
Fig.3 Typical Reverse Characteristics
10
10
REVERSE VOLTAGE (V)
(A)
AVERAGE FORWARD CURRENT (A)
3
8.3ms single half sine wave
50
40
30
10
100
NUMBER OF CYCLES AT 60 Hz
3
Version: M2102
1.2
ES2AA – ES2JA
Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram
4
Version: M2102
ES2AA – ES2JA
PACKAGE OUTLINE DIMENSIONS
DO-214AC (SMA)
SUGGESTED PAD LAYOUT
MARKING DIAGRAM
5
P/N
= Marking Code
G
= Green Compound
YW
= Date Code
F
= Factory Code
Version: M2102
ES2AA – ES2JA
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: M2102
很抱歉,暂时无法提供与“ES2HA M2G”相匹配的价格&库存,您可以联系我们找货
