94RB16FT
94RB16FT
    GRAYHILLINC.
    DIP
    SWITCH HEX ROTARY DIP R/A
94RB16FT 数据手册
Thru-Hole DIP Switches SERIES 94R Economical, Binary Coded FEATURES • 10,000 Cycles of Operation • Gold-Plated Contacts • Sealed Contact System • Right Angle Mount • Octal, BCD & Hexadecimal Codes • Standard or Complement • RoHS Compliant DIMENSIONS In inches (and millimeters) .094 (2,93) .213 (5,41) .286 (7,26) .162 (4,11) .480 .443 (12,19) (11,25) SWITCH POSITION CODE & TRUTH TABLES: Series 94H and 94R Standard Output 0 1 2 3 4 5 6 7 8 9 A B C D E F CODE OUTPUT CODE OUTPUT 1248 1248 Complement Output .433 (11,00) .210 (5,33) .689 (17,50) 1.123 (28,52) .044 (1,12) DIA. .200 (5,08) DIP Switches DIP 21 Pin #1 1 C 4 8 C 2 .179 (4,55) PC board layout as viewed from the top of the switch .059 (1,50) .058 (1,47) DIA. .199 (5,05) .235 (5,97) Unless otherwise indicated, tolerances are ± .010 (0,25) SPECIFICATIONS: Electrical Ratings Series 94H and 94R Make-and-break Current Rating: 30 mA at 30 Vdc for 10,000 cycles of operation. Carrying Current Rating: 100 mA at 50 Vdc Contact Resistance: 50 mohms maximum initially (measured at 10 mA, 50 mVdc). 150 mohms maximum after life. Insulation Resistance:(measured at 100 Vdc across open switch contacts) Initial: 5000 Mohms minimum. After Life: 1000 Mohms minimum. Dielectric Strength: (measured across open switch contacts) Initial: 500 Vac RMS minimum. After Life: 250 Vac RMS Moisture Resistance: 2 40 hours with temperature cycling and polarization. Passes insulation resistance and dielectric strength per MIL-STD-202F, Method 106 following exposure. Materials and Finishes Rotor and Switch Body: Plastic (UL94V-O) Contact Material: Copper alloy plated. 30 microinches minimum gold over 50 microinches minimum nickel. Shorting Member: C opper alloy plated. 30 microinches minimum gold over 50 microinches minimum nickel. Terminals: Copper alloy, matte tin plated over nickel barrier. Dot indicates terminal to common connection. All switches are continuous rotation. Octal and Octal Complement outputs are 0 thru 7 positions. BCD and BCD Complement outputs are 0 thru 9 positions. Hexadecimal and Hexadecimal Complement outputs are 0 thru F positions. Standard codes have natural color rotors; complements have rotors in a contrasting color. Internal O-ring: Rubber BUNA-N Soldering Information Soldering Temperature: 260° C maximum. Cleaning: Acceptable solutions include 1-1-1 Trichlorenthane, Freon (TF, TE, or TMS), Isopropyl Alcohol and detergent (140°F maximum). Solutions which are not recommended include Acetone, Methylene Chloride, and Freon TMC. Mechanical Ratings Mechanical Life: 10,000 cycles of operation. One cycle is a rotation through all positions and a complete return through all positions. Mechanical Shock: 1000g's, 0.5 mS, half sine per MIL-STD-202F, Method 213, Test Condition E. Vibration Resistance: 10-2000 Hz at 15G or 0.060" double amplitude per MIL-STD-202F, Method 204, Test Condition B. Operational Torque: 2 to 6 inch-ounces initially and 1.2 inch-ounces minimum after life. ORDERING INFORMATION: Series 94R Continuous Rotation Versions Code Octal BCD Hexadecimal Rotational Stop Versions* Code Hexadecimal No. of Positions 16 Standard Code Part Number 94RB16FT Complement Part Number 94RC16FT No. of Positions 8 10 16 Standard Code Part Number 94RB08CT 94RB10CT 94RB16CT Complement Part Number 94RC08CT 94RC10CT 94RC16CT Environmental Ratings Operating Temperature Range: -40° to +85°C. Storage Temperature Range: -40° to +85°C. * Consult Grayhill for 8 or 10 position G rayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com
94RB16FT 价格&库存
很抱歉,暂时无法提供与“94RB16FT”相匹配的价格&库存,您可以联系我们找货
