Power Modules
DataSheet
EF Series
AVAILABLE OPTIONS
Series
EF
et
e
• High Thermal Efficiency
• Complete Power Control
• Circuits In a Single Package
• UL Recognized E72445
Circuit Type
01 05 15 18
02 13 16 19
04 14 17 20
D
U
01
B
U
F
AC Line Voltage
B: 120 VAC F: 480 VAC
C: 240 VAC G: 530 VAC
D: 380 VAC
ol
Load Current (Amps)
1Ø 3Ø AC SW.
D: 50 70 55
E: 75 100 85
F: 100 135 110
G: 125 170 140
Blank: No Free Wheeling Diode
F: Free Wheeling Diode
(Circuits 1, 2, 16 & 19 Only)
Required for valid part number
ELECTRICAL SPECIFICATIONS
Symbol
D
E
F
Maximum DC Output Current (Tc = 85°C) (Single Phase Rating)
Maximum Voltage Drop @ Amps Peak
Operating Junction Temperature Range
Critical Rate of Rise of On-State Current @ TJ=125°C
Critical Rate of Rise of Off-State Voltage [V/µs]
G
di/dt
dv/dt
50 A
1.7V @ 50A
-40 - 125°C
100A/μs
500V/μs
100A
1.4V @ 100A
-40 - 125°C
100A/μs
500A/μs
125A
1.55V @ 125A
-40 - 125°C
500V/μs
Repetitive Peak Reverse Voltage (AC Line Nominal) [Vpk]
VRRM
Maximum Non-Repetitive Surge Current (1/2 Cycle, 60 Hz) [A]
Maximum I²T for Fusing (t=8.3ms) [A²sec]
Minimum Required Gate Current to Trigger @ 25°C [mA]
Minimum Required Gate Voltage to Trigger @ 25°C [V]
Average Gate Power [W]
Maximum Peak Reverse Gate Voltage [V]
Maximum Thermal Resistance, Junction to Ceramic Base per Chip
Isolation Voltage [Vrms]
ITSM
400
75A
1.85V @ 75A
-40 - 125°C
100A/μs
500A/μs
400 (120 VAC)
600 (120 VAC)
800 (120 VAC)
1200 (120 VAC)
1400 (120 VAC)
600
1500
1950
I2T
IGT
VGT
PG(AV)
VGM
RJC
VISOL
670
60
2.5
0.5
5.0
0.8°C/W
2500
1500
80
3.0
0.5
5.0
0.7°C/W
2500
9340
150
3.0
0.5
5.0
0.36°C/W
2500
15800
150
3.0
0.5
5.0
0.3°C/W
2500
O
bs
Description
Do not forget to visit us at: www.crydom.com
ID
VF
TJ
Copyright © 2017 Crydom Inc. Specifications subject to change without notice.
Power Modules
DataSheet
GENERAL SPECIFICATIONS
Description
Weight (typical)
4000 VRMS
4000 VRMS
4000 VRMS
4000 VRMS
4000 VRMS
MECHANICAL SPECIFICATIONS
O
bs
CIRCUIT DIAGRAMS
ol
PIN DETAIL
et
e
Tolerances: ±0.02 in / 0.5 mm
All dimensions are in: inches [millimeters]
Power Modules
DataSheet
bs
AGENCY APPROVALS
ol
et
e
TERMINAL ORIENTATION
AGENCY APPROVALS
O
E72445
Rev. 012710
Power Modules
DataSheet
DANGER / PELIGRO / DANGER /GEFAHR / PERICOLO / 危险
• Verificar todas
las conexiones
y colocar todas
las tapas antes
de energizer
el equipo.
El
incumplimiento
de estas
instrucciones
puede provocar
la muerte o
lesiones serias.
• Eteindre
toutes les
sources
d'énergie de
cet appareil
avant de
travailler
dessus de cet
appareil
GEFAHR EINES
ELEKTRISCHE
N SCHLAGES
ODER EINER
EXPLOSION.
• Stellen Sie
jeglichen
Strom ab, der
dieses Gerät
versorgt, bevor
Sie an dem
Gerät Arbeiten
durchführen
RISCHIO DI
SCOSSA
ELETTRICA O
DELL’ESPLOSIONE.
• Spenga tutta
l'alimentazione
che fornisce
questa
apparecchiatura
prima di lavorare
a questa
apparecchiatura
存在电击、
爆炸或电弧
闪烁危险
在操作此设
备之前请先
关闭电源。
• Vor dem
Drehen auf
Energie alle
Anschlüsse
überprüfen
und alle
Abdeckungen
ersetzen.
若不遵守这些说明,
可能会导致严重的
人身伤害甚至死亡。
• Vérifier tous
connections, et
remettre tous
couverts en
olace avant de
mettre sous
• Verificare tutti
i collegamenti
e sostituire
tutte le coperture
prima
dell’accensione
De non-suivi de
ces instructions
provoquera la
mort ou des
lésions sérieuses
sérieuses.
Unterlassung
dieser
Anweisungen
können zum
Tode oder zu
schweren
Verletzungen
führen.
L'omissione di
queste istruzioni
provocherà la
morte o
lesioni serie
ol
Failure to follow
these
instructions will
result in death
or serious injury.
• Desconectar
todos los
suministros de
energia a este
equipo antes
de trabajar
con este equipo.
RISQUE DE
DESCHARGE
ELECTRIQUE
OU EXPLOSION
e
• Verify all
connections
and replace all
covers before
turning on
power.
RIESGO DE
DESCARGA
ELECTRICA O
EXPLOSION.
et
HAZARD OF
ELECTRIC
SHOCK,
EXPLOSION,
OR ARC FLASH.
• Disconnect all
power before
installing or
working with
this equipment.
bs
WARNING / AVERTISSEMENT / WARNUNG /ADVERTENCIA / AVVERTENZA / 警告
RISK OF MATERIAL DAMAGE AND HOT
ENCLOSURE
RISQUE DE DOMMAGE MATERIEL ET DE
SURCHAUFFE DU BOITIER
GEFAHR VON MATERIALSCHÄDEN UND
GEHÄUSEERHITZUNG
• The product's side panels may be hot, allow
the product to cool before touching.
• Follow proper mounting instructions including
torque values.
• Do not allow liquids or foreign objects to enter
this product.
• Les panneaux latéraux du produit peuvent être
chauds. Laisser le produit refroidir avant de le
toucher.
• Respecter les consignes de montage, et
notamment les couples de serrage.
• Ne pas laisser pénétrer de liquide ni de corps
étrangers à l'intérieur du produit.
• Die Seitenwände können heiß sein. Lassen Sie
das Produkt abkühlen, bevor Sie es berühren.
• Beachten Sie die Montageanweisungen,
• Führen Sie keine Flüssigkeiten oder
Fremdkörper in das Produkt ein.
Die Nichtbeachtung dieser Anweisung kann
Körperverletzung oder Materialschäden
zur Folge haben.
RIESGO DE DAÑOS MATERIALES Y DE
SOBRECALENTAMIENTO DE LA UNIDAD
RISCHIO DI DANNI MATERIALI E D'INVOLUCRO
CALDO
材料损坏和高温外壳的危险性
• Los paneles laterales del producto pueden
estar calientes. Esperar que el producto se
enfríe antes de tocarlo.
• Respetar las instrucciones de montaje, y en
particular los pares de apretado.
• No dejar que penetren líquidos o cuerpos
extraños en el producto.
• I pannelli laterali dell'apparecchio possono
scottare; lasciar quindi raffreddare il prodotto
prima di toccarlo.
• Seguire le istruzioni di montaggio corrette.
• Non far entrare liquidi o oggetti estranei in questo
apparecchio.
Si no se respetan estas precauciones pueden
producirse graves lesiones, daños materiales.
La mancata osservanza di questa precauzione può
causare gravi rischi per l'incolumità personale o
danni alle apparecchiature.
O
Le non-respect de cette directive peut entraîner,
Failure to follow these instructions can result in des lésions corporelles graves ou des
serious injury, or equipment damage.
dommages matériels.
• 产品的一侧面板可能很热,在其冷却前请
不要触碰。
• 遵照正确的安装说明,包括扭矩值。
• 请勿让液体及其他异物进入本产品。
如不能正确执行这些操作说明,
极有可能造成严重人体伤害或者设备的损坏。
Power Modules
DataSheet
ANNEX - ENVIROMENTAL INFORMATION
The environmental information disclosed in this annex including the EIP Pollution logo are in compliance with People’s Republic of China
Electronic Industry Standard SJ/T11364 – 2006, Marking for Control of Pollution Caused by Electronic Information Products.
Toxic or hazardous Substance and Elements
Lead
(Pb)
Mercury
(Hg)
Cadmium
(Cd)
Hexavalent
Chromium
(Cr (VI))
Semiconductor die
Polybrominated
diphenyl ethers
(PBDE)
et
Solder
Polybrominated
biphenyls
(PBB)
e
Part
Name
附件 - 环保信息
部件
名称
铅
汞
镉
有毒有害物质或元素
六价铬
多溴联苯
(Pb)
(Hg)
(Cd)
(Cr (VI))
bs
半导体芯片
焊接点
ol
此附件所标示的包括电子信息产品污染图标的环保信息符合中华人民共和国电子行业标准 SJ/T11364 - 2006,
电子信息产品污染控制标识要求。
O
50
(PBB)
多溴二苯醚
(PBDE)
很抱歉,暂时无法提供与“EFG15F”相匹配的价格&库存,您可以联系我们找货
