S1A-F
S1A-F
    SMCDIODESOLUTIONS(桑德斯)
    SMA(DO-214AC)
    SMT GLASS PASSIVATED RECTIFIER
S1A-F 数据手册
S1A-S1M Technical Data Data Sheet N0560, Rev. B S1A THRU S1M 1.0A SURFACE MOUNT GLASS PASSIVATED RECTIFIER Features Glass Passivated Die Construction Ideally Suited for Automatic Assembly Low Forward Voltage Drop Low Power Loss Built-in Strain Relief Plastic Case Material has UL Flammability Classification Rating 94V-0 This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request          SMA Circuit Diagram Mechanical Data      Case: SMA molded plastic body Terminals: Solder plated, solderable per MIL-STD-750, Method 2026 Polarity: Color band denotes cathode end Mounting Position: Any Weight: 0.06 grams Maximum Ratings and Electrical Characteristics @TA=25°C unless otherwise specified Type Number Symbol S1A S1B S1D S1G S1J S1K S1M Units Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage VRRM VRWM VR 50 100 200 400 600 800 1000 V Maximum RMS voltage VRMS 35 70 140 280 420 560 700 V Average Rectified Output Current @TL= 100°C Non-Repetitive Peak Forward Surge Current 8.3ms Single half sine-wave superimposed on rated load (JEDEC Method) IO 1.0 A IFSM 30 A VF 1.10 V Peak Reverse Current @TA = 25°C At Rated DC Blocking Voltage @TA = 125°C IRM 5.0 200 μA Reverse Recovery Time(Note1) trr 2.5 μS Typical Junction Capacitance(Note2) CJ 15 pF Typical Thermal Resistance Junction to Lead (Note 3) RθJL 30 °C/W Forward Voltage @ IF = 1.0 A Operating and Storage Temperature Range TJ,TSTG -65 to +175 Note: 1. Reverse recovery condition IF=0.5A, IR=1.0A, Irr=0.25A 2. Measured at 1MHz and applied reverse voltage of 4.0V D.C. 3. Mounted on P.C.B.with 8.0mm² land areas.  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  °C S1A-S1M Technical Data Data Sheet N0560, Rev. B Ratings and Characteristics Curves  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  S1A-S1M Technical Data Data Sheet N0560, Rev. B Mechanical Dimensions SMA SYMBOL Ordering Information Device S1A-S1M Package SMA (Pb-Free) Millimeters Inches Min. Max. Min. Max. A 2.40 2.84 0.094 0.112 B 3.99 4.75 0.157 0.187 C 1.05 1.70 0.041 0.067 D 0.15 0.51 0.006 0.020 E 4.80 5.66 0.189 0.223 F 1.90 2.95 0.075 0.116 G 0.05 0.203 0.002 0.008 H 0.76 1.52 0.030 0.600 Marking Diagram Where XXXXX is YYWWL Shipping S1A YY WW L 5000pcs / reel For information on tape and reel specifications, including part orientation and tape sizes, please refer to our tape and reel packaging specification. = Type Number = Year = Week = Lot Number Cautions:Molding resin Epoxy resin UL:94V-0 Carrier Tape Specification SMA SYMBOL A B C d E F P P0 P1 T W Millimeters Min. Max. 2.97 5.70 2.32 1.40 1.40 5.60 3.90 3.90 1.90 0.25 3.17 5.90 2.52 1.60 1.60 5.70 4.10 4.10 2.10 0.35 11.80 12.20  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  S1A-S1M Technical Data Data Sheet N0560, Rev. B DISCLAIMER: 1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product characteristics. Before ordering, purchasers are advised to contact the SMC - Sangdest Microelectronics (Nanjing) Co., Ltd sales department for the latest version of the datasheet(s). 2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment, medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by means of users’ fail-safe precautions or other arrangement . 3- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any damages that may result from an accident or any other cause during operation of the user’s units according to the datasheet(s). SMC - Sangdest Microelectronics (Nanjing) Co., Ltd assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information, products or circuits described in the datasheets. 4- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any failure in a semiconductor device or any secondary damage resulting from use at a value exceeding the absolute maximum rating. 5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and regulations..  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com 
S1A-F 价格&库存
很抱歉,暂时无法提供与“S1A-F”相匹配的价格&库存,您可以联系我们找货
