RS3JTA
RS3JTA
    SMCDIODESOLUTIONS(桑德斯)
    SMC(DO-214AB)
    DIODE GEN PURP 600V 3A SMC
RS3JTA 数据手册
RS3A-RS3M Technical Data Data Sheet N1813, Rev.A RS3A-RS3M SURFACE MOUNT SUPER FAST RECTIFIER Features Glass Passivated chip junction Built-in strain relief Fast switching speed for high efficiency High temperature soldering guaranteed: 250℃/10 second at terminals This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request        SMC Circuit Diagram Mechanical Data      Case: SMC molded plastic Epoxy: UL 94V-0 rate flame retardant Lead: Solder plated, solderable per MIL-STD-202E method208C Polarity: Color band denotes cathode end Weight: 0.21 grams Maximum Ratings and Electrical Characteristics @TA=25°C unless otherwise specified Type Number Symbol RS3A RS3B RS3D RS3G RS3J RS3K RS3M Units Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage VRRM VRWM VDC 50 100 200 400 600 800 1000 V RMS Reverse Voltage VRMS 35 70 140 280 420 560 700 V Average forward rectified output current @TL= 100°C Non-Repetitive Peak Forward Surge Current 8.3ms Single half sine-wave superimposed on rated load (JEDEC Method) Forward Voltage @IF =3.0A IO 3.0 A IFSM 100 A VF 1.3 V Peak Reverse Current @TA = 25°C At Rated DC Blocking Voltage @TA = 125°C IRM 10 250 µA Maximum Reverse Recovery Time (Note 1) Trr Typical Junction Capacitance (Note 2) Typical Thermal Resistance Junction to Ambient (Note 3) Operating and Storage Temperature Range CJ RθJA RθJL TJ, TSTG 150 250 500 60 50 15 -55 to +150 Note: 1. Measured with IF=0.5A, IR=1.0A, Irr=0.25A, 2. Measured at 1.0 MHZ and applied reverse voltage of 4.0 VDC 3. Thermal resistance from Junction to ambient and from junction to lead mounted on PCB with 0.3×0.3” (8.0 × 8.0mm) copper pad areas  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  ns pF °C/W °C RS3A-RS3M Technical Data Data Sheet N1813, Rev.A Ratings and Characteristics Curves  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  RS3A-RS3M Technical Data Data Sheet N1813, Rev.A Mechanical Dimensions SMC SYMBOL Ordering Information Device RS3A-RS3M Package SMC (Pb-Free) Millimeters Inches Min. Max. Min. Max. A 5.59 6.22 0.220 0.245 B 6.60 7.11 0.260 0.280 C 2.90 3.20 0.114 0.126 D 0.152 0.305 0.006 0.012 E 7.75 8.13 0.305 0.320 F 2.00 2.62 0.079 0.103 G - 0.203 - 0.008 H 0.76 1.52 0.030 0.060 Marking Diagram Where XXXXX is YYWWL Shipping RS3A YY WW L 3000pcs / reel For information on tape and reel specifications, including part orientation and tape sizes, please refer to our tape and reel packaging specification. = Type Number = Year = Week = Lot Number Cautions:Molding resin Epoxy resin UL:94V-0 Carrier Tape Specification SMC SYMBOL A B C d E F P P0 P1 T W Min. 5.90 8.20 2.40 1.40 1.40 7.60 7.90 3.90 3.90 - Millimeters Max. 15.80  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  6.10 8.40 2.60 1.60 1.60 7.70 8.10 4.10 4.10 0.600 16.20 RS3A-RS3M Technical Data Data Sheet N1813, Rev.A DISCLAIMER: 1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product characteristics. Before ordering, purchasers are advised to contact the SMC - Sangdest Microelectronics (Nanjing) Co., Ltd sales department for the latest version of the datasheet(s). 2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment, medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by means of users’ fail-safe precautions or other arrangement . 3- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any damages that may result from an accident or any other cause during operation of the user’s units according to the datasheet(s). SMC - Sangdest Microelectronics (Nanjing) Co., Ltd assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information, products or circuits described in the datasheets. 4- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any failure in a semiconductor device or any secondary damage resulting from use at a value exceeding the absolute maximum rating. 5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and regulations..  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com 
RS3JTA 价格&库存
很抱歉,暂时无法提供与“RS3JTA”相匹配的价格&库存,您可以联系我们找货
