TSS4B03GHC2G
TSS4B03GHC2G
    TAIWANSEMICONDUCTOR(台湾半导体)
    SIP4
    BRIDGE RECT 1PHASE 200V 4A TS4B
TSS4B03GHC2G 数据手册
TSS4B01G - TSS4B04G Taiwan Semiconductor CREAT BY ART 4A, 50V - 400V Glass Passivated Bridge Rectifiers FEATURES - Glass passivated junction - Ideal for printed circuit board - High case dielectric strength of 2000VRMS - Reliable low cost construction - UL Recognized File # E-326243 - Compliant to RoHS Directive 2011/65/EU and in accordance to WEEE 2002/96/EC - Halogen-free according to IEC 61249-2-21 TS4B MECHANICAL DATA Case: TS4B en de d Molding compound, UL flammability classification rating 94V-0 Part no. with suffix "H" means AEC-Q101 qualified Packing code with suffix "G" means green compound (halogen-free) mm Terminal: Matte tin plated leads, solderable per JESD22-B102 Meet JESD 201 class 2 whisker test Polarity: Polarity as marked on the body Mounting torque: 5 in-lbs maximum Weight: 4 g (approximately) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS (TA=25°C unless otherwise noted) PARAMETER TSS4B TSS4B TSS4B TSS4B 01G 02G 03G 04G VRRM 50 100 200 400 V VRMS 35 70 140 280 V VDC 50 100 200 400 V SYMBOL Maximum RMS voltage Maximum DC blocking voltage eco Maximum repetitive peak reverse voltage UNIT IF(AV) 4 A Peak forward surge current, 8.3 ms single half sine-wave superimposed on rated load IFSM 150 A Rating for fusing (t
TSS4B03GHC2G
物料型号:TSS4B01G - TSS4B04G
器件简介: - 玻璃钝化结 - 适合印刷电路板使用 - 高外壳耐电压2000VRMS - 可靠的低成本构造
引脚分配:文档中没有明确提供引脚分配图,但提到极性标记在器件本体上。
参数特性: - 最大重复峰值反向电压:50V至400V - 最大RMS电压:35V至280V - 最大直流阻断电压:50V至400V - 最大平均正向整流电流:4A - 峰值正向浪涌电流:150A(8.3ms单半正弦波) - 额定熔断电流:93A^2s(t<8.3ms) - 最大瞬态正向电压:0.98V至1.3V(@4A) - 25°C时最大反向电流:5500μA - 最大反向恢复时间:35ns至50ns - 典型热阻:5.5°C/W - 工作结温范围:-55°C至+150°C - 存储温度范围:-55°C至+150°C
功能详解: - 提供了正向特性曲线、最大非重复正向浪涌电流、典型反向特性等图表。
应用信息: - 适用于电阻性或感性负载,带有散热器。
封装信息: - 封装类型:TS4B - 封装材料:UL阻燃等级94V-0的模塑料 - 标记图示:提供了器件的标记图。
订购信息: - 提供了部件编号、后缀、包装代码和描述的示例。
版本信息: - 文档编号:DS_D1311039 - 版本:E15
TSS4B03GHC2G 价格&库存
很抱歉,暂时无法提供与“TSS4B03GHC2G”相匹配的价格&库存,您可以联系我们找货
