TSUP10M45SH S1G
TSUP10M45SH S1G
    TAIWANSEMICONDUCTOR(台湾半导体)
    TO-277
    10A, 45V, SCHOTTKY RECTIFIER
TSUP10M45SH S1G 数据手册
TSUP10M45SH Taiwan Semiconductor 10A, 45V Trench Schottky Rectifier FEATURES ● ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified Patented Trench Schottky technology Low power loss, high efficiency Ideal for automated placement Wettable flank Moisture sensitivity level: level 1, per J-STD-020 RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 10 A VRRM 45 V IFSM 220 A TJ MAX 175 °C Package TO-277A (SMPC4.6U) Configuration Single die APPLICATIONS ● ● ● ● ● Switching mode power supply (SMPS) Adapters Lighting application On-board DC/DC converter Automotive MECHANICAL DATA ● ● ● ● ● ● Case: TO-277A (SMPC4.6U) Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 0.104g (approximately) TO-277A (SMPC4.6U) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device TSUP10M45SH UNIT 10M45 Repetitive peak reverse voltage VRRM 45 V Reverse voltage, total rms value VR(RMS) 32 V IF 10 A Forward current Surge peak forward current single half sine-wave superimposed on rated load t = 8.3ms t = 1.0ms IFSM 220 330 A Junction temperature TJ -55 to +175 °C Storage temperature TSTG -55 to +175 °C 1 Version: B2103 TSUP10M45SH Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT Junction-to-lead thermal resistance RӨJL 6 °C/W Junction-to-ambient thermal resistance RӨJA 45 °C/W Junction-to-case thermal resistance RӨJC 9 °C/W Thermal Performance Note: Units mounted on PCB (16mm x 16mm Cu pad test board) ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER CONDITIONS SYMBOL IF = 5A, TJ = 25°C Forward voltage IF = 10A, TJ = 25°C (1) IF = 5A, TJ = 125°C VF IF = 10A, TJ = 125°C Reverse current @ rated VR (2) Junction capacitance TJ = 25°C IR TJ = 125°C 1MHz, VR = 4.0V CJ TYP MAX UNIT 0.50 - V 0.54 0.60 V 0.39 - V 0.46 0.54 V - 200 µA - 9 mA 1099 - pF Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE PACKAGE PACKING TSUP10M45SH TO-277A (SMPC4.6U) 6,000 / Tape & Reel 2 Version: B2103 TSUP10M45SH Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 10000 10 CAPACITANCE (pF) 8 6 4 1000 2 f=1.0MHz Vsig=50mVp-p 0 0 25 50 75 100 125 150 100 175 1 10 LEAD TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) Fig.4 Typical Forward Characteristics 100000 TJ=175°C 1000 TJ=125°C 100 TJ=150°C 10 TJ=25°C 1 0.1 10 20 30 40 50 60 70 80 90 100 100 10 1 10 UF1DLW TJ=175°C TJ=150°C TJ=125°C TJ=25°C TJ=25°C 0.1 1 0.01 TJ=125°C Pulse width 300μs Pulse widthPulse 300μswidth 1% 1% duty duty cycle cycle 0.001 0.1 0.4 0.1 0.3 0.2 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) 0.5 0.3 0.6 0.9 0.4 0.7 0.50.8 0.6 1 0.7 1.1 FORWARD VOLTAGE (V) Fig.5 Typical Transient Thermal Impedance TRANSIENT THERMAL IMPEDANCE (°C/W) INSTANTANEOUS REVERSE CURRENT (μA) Fig.3 Typical Reverse Characteristics 10000 100 REVERSE VOLTAGE (V) (A) AVERAGE FORWARD CURRENT (A) 12 100 10 1 0.1 0.01 0.001 0.0001 0.000001 0.00001 0.0001 0.001 0.01 0.1 1 10 100 PULSE DURATION (s) 3 Version: B2103 1.2 TSUP10M45SH Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS TO-277A (SMPC4.6U) SUGGESTED PAD LAYOUT MARKING DIAGRAM P/N YW F 4 = Marking Code = Date Code = Factory Code Version: B2103 TSUP10M45SH Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 5 Version: B2103
TSUP10M45SH S1G 价格&库存
很抱歉,暂时无法提供与“TSUP10M45SH S1G”相匹配的价格&库存,您可以联系我们找货
