S3AB – S3MB
Taiwan Semiconductor
3A, 50V - 1000V Standard Surface Mount Rectifier
FEATURES
KEY PARAMETERS
Glass passivated chip junction
Ideal for automated placement
Low forward voltage drop
High surge current capability
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
APPLICATIONS
PARAMETER
VALUE
UNIT
IF
3
A
VRRM
50 - 1000
V
IFSM
80
A
TJ MAX
150
°C
Package
DO-214AA (SMB)
Configuration
Single die
Switching mode power supply (SMPS)
Adapters
Lighting application
Converter
MECHANICAL DATA
Case: DO-214AA (SMB)
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: Indicated by cathode band
Weight: 0.090g (approximately)
DO-214AA (SMB)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
Repetitive peak reverse voltage
VRRM
S3
AB
S3
AB
50
Reverse voltage, total rms value
VR(RMS)
35
PARAMETER
SYMBOL
Marking code on the device
S3
BB
S3
BB
100
S3
DB
S3
DB
200
S3
GB
S3
GB
400
S3
JB
S3
JB
600
S3
KB
S3
KB
800
S3
MB
S3
MB
1000
70
140
280
420
560
700
UNIT
V
V
Forward current
Surge peak forward current, 8.3ms
single half sine-wave superimposed
on rated load
Junction temperature
IF
3
A
IFSM
80
A
TJ
- 55 to +150
°C
Storage temperature
TSTG
- 55 to +150
°C
1
Version: M2102
S3AB – S3MB
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
RӨJL
10
°C/W
Junction-to-lead thermal resistance
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage
CONDITIONS
(1)
Reverse current @ rated VR
IF = 3A, TJ = 25°C
(2)
Junction capacitance
Reverse recovery time
TJ = 25°C
TJ = 125°C
1MHz, VR = 4.0V
IF = 0.5A, IR = 1.0A
Irr = 0.25A
SYMBOL
TYP
MAX
UNIT
VF
1.15
V
10
µA
250
µA
CJ
40
pF
trr
1500
ns
IR
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)
PACKAGE
PACKING
S3xB
DO-214AA (SMB)
3,000 / Tape & Reel
Notes:
1. "x" defines voltage from 50V(S3AB) to 1000V(S3MB)
2
Version: M2102
S3AB – S3MB
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
100
3
CAPACITANCE (pF)
AVERAGE FORWARD CURRENT (A)
4
2
1
50
75
100
125
10
f=1.0MHz
Vsig=50mVp-p
1
150
1
10
REVERSE VOLTAGE (V)
LEAD TEMPERATURE (°C)
Fig.3 Typical Reverse Characteristics
Fig.4 Typical Forward Characteristics
10
TJ=125°C
1
TJ=25°C
0.1
40
50
60
70
80
90
100
100
10
10
TJ=125°C
TJ=25°C
0.1
1
0.01
0.001
0.3
0.1
0.7
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
UF1DLW
1
(A)
INSTANTANEOUS FORWARD CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (μA)
100
10
100
0.4
0.8
0.9
0.5
0.6
1
1.1
0.7
1.2
Pulse width
Pulse Width=300μs
1% Duty
0.8
0.9 Cycle
1
1.1
1.3
1.4
1.5
1.6
FORWARD VOLTAGE (V)
3
Version: M2102
1.2
S3AB – S3MB
Fig.5 Maximum Non-Repetitive Forward Surge Current
PEAK FORWARD SURGE CURRENT (A)
100
8.3ms single half sine wave
80
60
40
10
100
NUMBER OF CYCLES AT 60 Hz
Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram
4
Version: M2102
S3AB – S3MB
PACKAGE OUTLINE DIMENSIONS
DO-214AA (SMB)
SUGGESTED PAD LAYOUT
MARKING DIAGRAM
5
P/N
= Marking Code
G
= Green Compound
YW
= Date Code
F
= Factory Code
Version: M2102
S3AB – S3MB
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: M2102
很抱歉,暂时无法提供与“S3MBHR5G”相匹配的价格&库存,您可以联系我们找货
