SICRF5650
SICRF5650
    SMCDIODESOLUTIONS(桑德斯)
    TO-220-2
    SICRF5650
SICRF5650 数据手册
SICR5650 SICRB5650 SICRD5650 SICRF5650 Technical Data Data Sheet N1870, Draft 1 SICR5650 / SICRB5650 / SICRD5650 / SICRF5650 650V SIC POWER SCHOTTKY RECTIFIER Description Features SICR5650/ SICRB5650/ SICRD5650/ SICRF5650 are all single SiC Schottky rectifiers packaged in TO-220AC, D2PAK, DPAK and ITO-220ACcase. The device is a high voltage Schottky rectifier that has very low total conduction losses and very stable switching characteristics over temperature extremes. The SICR5650/ SICRB5650/ SICRD5650/ SICRF5650 are ideal for energy sensitive, high frequency applications in challenging environments.        Applications         Alternative energy inverters Power Factor Correction (PFC) Free-Wheeling diodes Switching supply output rectification Reverse polarity protection 175°C TJ operation Ultra-low switching loss Switching speeds independent of operating temperature Low total conduction losses High forward surge current capability High package isolation voltage Guard ring for enhanced ruggedness and long term reliability Pb − Free Device All SMC parts are traceable to the wafer lot Additional electrical and life testing can be performed upon request SICR5650 SICRB5650 SICRD5650 SICRF5650 TO-220AC D2PAK DPAK ITO-220AC Maximum Ratings: Characteristics Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage Symbol Condition VRRM VRWM VR - Max. Units 650 V Average Rectified Forward Current IF (AV) 5 A Peak One Cycle Non-Repetitive Surge Current 50% duty cycle @Tc=105°C, rectangular wave form IFSM 8.3ms, Half Sine pulse 60 A  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  SICR5650 SICRB5650 SICRD5650 SICRF5650 Technical Data Data Sheet N1870, Draft 1 Electrical Characteristics: Characteristics Symbol Forward Voltage Drop* Reverse Current at DC condition* Reverse Current * Units @ 5A, Pulse, TJ = 25 C 1.5 1.7 V @ 5A, Pulse, TJ = 150 C @VR = rated VR TJ = 25 C @VR = rated VR TJ = 125 C @VR = 5V, TC = 25 C fSIG = 1MHz Measured lead to lead 5 mm from package body Clip mounting, the epoxy body away from the heatsink edge by more than 0.110" along the lead direction. Clip mounting, the epoxy body is inside the heatsink. Screw mounting, the epoxy body is inside the heatsink. 1.98 2.5 V 5 60 A 70 250 A - TBD pF - TBD nH - 10,000 V/s - 4500 - 3500 - 1500 IR1 LS Voltage Rate of Change RSM Isolation Voltage (t = 1.0 second, R. H. < =30%, TA = 25 C) Max. VF2 CT Series Inductance Typ. VF1 IR2 Junction Capacitance Condition dv/dt VISO * Pulse width < 300 µs, duty cycle < 2% V Thermal-Mechanical Specifications: Characteristics Symbol Junction Temperature Storage Temperature Maximum Thermal Resistance Junction to Case TJ Tstg RJC Ordering Information SICR5650 2.4 SICRB5650 SICRD5650 -55 to +175 -55 to +175 2.4 2.4 SICRF5650 Units C C 4.2 C/W Tube Specification(TO-220AC/ITO-220AC) Device Package Weight Shipping SICR5650 TO-220AC 1.8g 50pcs / tube SICRB5650 D²PAK 1.85g 800pcs / reel SICRD5650 DPAK 0.39g 2500pcs / reel SICRF5650 ITO-220AC 1.8g 50pcs / tube For information on tape and reel specifications, including part orientation and tape sizes, please refer to our tape and reel packaging specification.  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  SICR5650 SICRB5650 SICRD5650 SICRF5650 Technical Data Data Sheet N1870, Draft 1 Marking Diagram Where XXXXX is YYWWL SICR B/D/F 5 650 SSG YY WW L = Device Type = Package type = Forward Current (5A) = Reverse Voltage (650V) = SSG = Year = Week = Lot Number Cautions:Molding resin Epoxy resin UL:94V-0 Carrier Tape & Reel Specification DPAK SYMBOL A Millimeters Min. Max. 6.80 7.00 B 10.40 10.60 C 2.60 2.80 d Φ1.45 Φ1.65 E 1.65 1.85 F 7.40 7.60 P0 3.90 4.10 P 7.90 8.10 P1 1.90 2.10 W 15.90 16.30 Carrier Tape & Reel Specification D2PAK SYMBOL Millimeters Min. Max. A 10.70 10.90 B 16.03 16.23 C 5.11 5.31 d 1.45 1.65 E 1.65 1.85 F 11.40 11.60 P0 3.90 4.10 P 15.90 16.10 P1 1.90 2.10 W 23.90 24.30  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  SICR5650 SICRB5650 SICRD5650 SICRF5650 Technical Data Data Sheet N1870, Draft 1 Mechanical Dimensions TO-220AC Symbol A A1 A2 b b1 c D D1 E E1 e1 H1 L L1 ΦP Q Θ1 Θ2 Θ3 Dimensions in millimeters Min. 4.47 1.17 2.52 0.71 1.17 0.31 14.64 8.50 10.01 9.98 4.98 6.04 13.00 3.56 3.74 2.54 Typical 4.70 1.27 2.69 0.81 1.27 0.38 14.94 8.07 10.16 10.18 5.08 6.24 13.86 3.80 3.84 2.74 5° 4° 4° Max. 4.85 1.37 2.89 0.96 1.37 0.61 15.24 8.90 10.31 10.38 5.18 6.44 14.08 3.96 4.04 2.94 Mechanical Dimensions DPAK SYMBOL A A1 b c D D1 D2 E e L L1 L2 L3 L4 Φ Θ h V Millimeters Inches Min. Max. 2.20 2.40 0.00 0.127 0.66 0.86 0.46 0.60 6.50 6.70 5.13 5.46 4.83 REF. 6.00 6.20 2.186 2.386 9.70 10.40 2.90 REF. 1.40 1.70 1.60 REF. 0.60 1.00 1.10 1.30 0° 8° 0.00 0.30 5.35 REF. Min. Max. 0.087 0.094 0.000 0.005 0.026 0.034 0.018 0.024 0.256 0.264 0.202 0.215 0.190 REF. 0.236 0.244 0.086 0.094 0.381 0.409 0.144 REF. 0.055 0.067 0.063 REF. 0.024 0.039 0.043 0.051 0° 8° 0.000 0.012 0.211 REF.  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  SICR5650 SICRB5650 SICRD5650 SICRF5650 Technical Data Data Sheet N1870, Draft 1 Mechanical Dimensions D2PAK Symbol A A1 A2 b b1 c c1 D D1 E E1 E2 e H L L1 L2 L3 e e1 e2 e3 Dimensions in millimeters Min. 4.55 0 2.59 0.71 0.36 1.17 8.55 6.40 10.01 7.6 9.98 14.6 2.00 1.17 0 Typical 4.70 0.10 2.69 0.81 1.27 0.38 1.27 8.70 Max. 4.85 0.25 2.89 0.96 10.16 10.31 10.08 2.54 15.1 2.30 1.27 10.18 0.25BSC 5° 4° 4° 0.61 1.37 8.85 15.6 2.70 1.40 2.20 8° Mechanical Dimensions ITO-220AC SYMBOL A A1 A2 A3 b b1 c D E e H1 L L1 L2 L3 ΦP1(上口) ΦP2(下口) Q Θ1 Θ2 Θ3 Θ4 Θ5 MIN. 4.30 1.10 2.50 2.50 0.50 1.10 0.50 14.80 9.96 6.50 12.70 1.60 0.80 0.60 3.30 2.99 2.50  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  Millimeters TYP. 4.50 1.30 3.00 2.70 0.60 1.20 0.60 15.00 10.16 5.10 6.70 13.20 1.80 1.00 0.80 3.50 3.19 2.70 5° 4° 10° 5° 5° MAX. 4.70 1.50 3.20 2.90 0.85 1.35 0.85 15.20 10.36 6.90 13.70 2.00 1.20 1.00 3.70 3.39 2.90 SICR5650 SICRB5650 SICRD5650 SICRF5650 Technical Data Data Sheet N1870, Draft 1 DISCLAIMER: 1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product characteristics. Before ordering, purchasers are advised to contact the SMC - Sangdest Microelectronics (Nanjing) Co., Ltd sales department for the latest version of the datasheet(s). 2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment, medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by means of users’ fail-safe precautions or other arrangement . 3- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any damages that may result from an accident or any other cause during operation of the user’s units according to the datasheet(s). SMC - Sangdest Microelectronics (Nanjing) Co., Ltd assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information, products or circuits described in the datasheets. 4- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any failure in a semiconductor device or any secondary damage resulting from use at a value exceeding the absolute maximum rating. 5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and regulations..  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com 
SICRF5650 价格&库存
很抱歉,暂时无法提供与“SICRF5650”相匹配的价格&库存,您可以联系我们找货
