BAV19W/BAV20W/BAV21W
Taiwan Semiconductor
Small Signal Product
410mW High Voltage SMD Switching Diode
FEATURES
- These diodes are also available in DO-35, LL34 Package
- Surface Mount Device Type
- Moisture sensitivity level 1
- Matte Tin (Sn) lead finish with Nickel (Ni) underplate
- Pb free version and RoHS compliant
- Packing code with suffix "G" means
green compound (halogen-free)
SOD-123F
MECHANICAL DATA
- Case: Flat lead SOD-123F small outline plastic package
- Terminal: Matte tin plated, lead free,
solderable per MIL-STD-202, Method 208 guaranteed
- High temperature soldering guaranteed: 260°C/10s
- Polarity: Indicated by cathode band
- Weight: 4.85 ± 0.5mg
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS (TA=25°C unless otherwise noted)
PARAMETER
SYMBOL
VALUE
UNIT
PD
410
mW
Repetitive Peak Reverse Voltage
VRRM
250
V
Repetitive Peak Forward Current
IFRM
625
mA
IO
200
mA
Power Dissipation
Mean Forward Current
Non-Repetitive Peak Forward
Surge Current
Pulse Width = 1 μs
Pulse Width = 1 s
4
IFSM
Thermal Resistance (Junction to Ambient)
RθJA
375
Junction and Storage Temperature Range
TJ , TSTG
-65 to +150
PARAMETER
Reverse Breakdown Voltage
(Note 1)
Forward Voltage
Reverse Leakage Current
(Note 2)
Junction Capacitance
SYMBOL
BAV19W
BAV20W
V(BR)
BAV21W
IF = 100 mA
IF = 200 mA
A
1
o
C/W
o
MIN
MAX
120
200
250
C
UNIT
V
1
1.25
IR
100
nA
CJ
5
pF
trr
50
ns
VF
V
BAV19W
BAV20W
BAV21W
VR = 0 , f = 1.0 MHz
Reverse Recovery Time (Note 3)
Note 1 : Test condition : IR= 100μA
Note 2 : Test condition : BAV19W @ VR=100V, BAV20W @ VR=150V, BAV21W @ VR=200V
Note 3 : Test condition : IF= IR= 30mA , RL=100Ω , Irr=3mA
Document Number: DS_S1501003
Version: E15
RATINGS AND CHARACTERISTICS CURVES
Fig. 1 Admissible Power Dissipation Curve
Fig. 2 Typicla Forward Characteristics
300
1000
100
Forward Current (mA)
Power Dissipation (mW)
250
200
150
100
10
1
0.1
50
50
75
100
125
150
Ambient Temperature (oC)
0.01
2
Forward Voltage (V)
Fig. 3 Leakage Current
Fig. VS.
3 Junction Temperature
100
Leakage Current (uA)
10
1
0.1
0.01
200
Junction Temperature (oC)
Version: E15
ORDER INFORMATION (EXAMPLE)
BAV19W RHG
Green compound code
Packing code
Part no.
PACKAGE OUTLINE DIMENSIONS
SOD-123F
DIM.
Unit (mm)
Unit (inch)
Min
Max
Min
Max
A
1.50
1.70
0.059
0.067
B
3.30
3.90
0.130
0.154
C
0.50
0.70
0.020
0.028
D
2.50
2.70
0.098
0.106
E
0.80
1.15
0.031
0.045
F
0.05
0.20
0.002
0.008
SUGGEST PAD LAYOUT
Unit (mm)
Unit (inch)
Typ.
Typ.
C
2.86
0.113
G
1.52
0.060
X
1.34
0.053
X1
4.20
0.165
Y
1.80
0.071
DIM.
MARKING CODE
Part no.
Marking
BAV19W
H1
BAV20W
H2
BAV21W
H3
Version: E15
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Information contained herein is intended to provide a product description only. No license, express or implied,to
any intellectual property rights is granted by this document. Except as provided in TSC's terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or seling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
Version: E15
很抱歉,暂时无法提供与“BAV19W RHG”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.28599
- 200+0.11416
- 500+0.11038
- 1000+0.10844
- 国内价格 香港价格
- 3000+0.356973000+0.04481
- 6000+0.318886000+0.04003
- 9000+0.299449000+0.03759
- 15000+0.2775715000+0.03485
- 21000+0.2646121000+0.03322
- 30000+0.2520030000+0.03164
- 75000+0.2243175000+0.02816
- 150000+0.20719150000+0.02601
- 300000+0.19281300000+0.02421
- 国内价格 香港价格
- 1+1.745441+0.21910
- 10+1.0842910+0.13611
- 100+0.67353100+0.08455
- 500+0.49146500+0.06169
- 1000+0.432321000+0.05427
