FR207GTA
FR207GTA
    SMCDIODESOLUTIONS(桑德斯)
    DO-204AC
    DIODE GPP 1KV 2A DO15
FR207GTA 数据手册
FR201G-FR207G Technical Data Data Sheet N0447, Rev. A FR201G THRU FR207G FAST RECOVERY GLASS PASSIVATED RECTIFIERS Reverse Voltage - 50 to 1000 Volts Forward Current - 2.0 Amperes Features The plastic package carries Underwriters Laboratory Flammability Classification 94V-0 Fast switching for high efficiency Low reverse leakage High forward surge current capability High temperature soldering guaranteed: 260 C/10 seconds,0.375”(9.5mm) lead length, 5 lbs. (2.3kg) tension Glass passivated chip junction This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request          DO-15 Circuit Diagram Mechanical Data Case: JEDEC DO-15 molded plastic body Terminals: Plated axial leads, solderable per MIL-STD-750, Method 2026 Polarity: Color band denotes cathode end Mounting Position: Any Weight: 0.014 ounce, 0.40 grams       Maximum Ratings and Electrical Characteristics @TA=25°C unless otherwise specified Characteristic Symbol FR FR FR 201G 202G 203G FR 204G FR 205G 5 100 3 70 2 400 1 280 4 600 2 420 VRRM VDC Maximum RMS voltage VRMS Maximum average forward rectified current 0.375”(9.5mm) lead length at @TA =75°C I(AV) 2.0 A Peak forward surge current 8.3ms single half sinewave superimposed on rated load (JEDEC Method) IFSM 70 A Maximum instantaneous forward voltage at 2.0A VF 1.3 V Maximum DC reverse current At Rated DC Blocking Voltage IRM 5.0 100 µA @TA = 25°C @TA = 100°C 35 250 8 1000 5 700 1 V trr Typical Junction Capacitance (Note 2) CJ 40 pF Typical Thermal Resistance Junction to Ambient (Note 3) RθJA 40 °C/W TJ, TSTG -55 to +150 °C Note: 1. Reverse recovery condition IF=0.5A, IR=1.0A, Irr=0.25A 2. Measured at 1MHz and applied reverse voltage of 4.0V D.C. 3. Thermal resistance from junction to ambient at 0.375”(9.5mm)lead length, P.C.B. mounted  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  500 1 V Maximum reverse recovery time (Note 1) Operating junction and storage temperature range 150 6 800 4 560 Units Maximum repetitive peak reverse voltage Maximum DC blocking voltage 50 1 200 7 140 FR FR 206G 207G ns FR201G-FR207G Technical Data Data Sheet N0447, Rev. A Ratings and Characteristics Curves  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  FR201G-FR207G Technical Data Data Sheet N0447, Rev. A Mechanical Dimensions DO-15 SYMBOL Ordering Information Device FR201G-FR207G Package DO-15 (Pb-Free) Millimeters Inches Min. Max. Min. Max. A 25.4 - 1.000 - B 5.5 7.62 0.217 0.300 C 0.7 0.9 0.028 0.034 D 2.6 3.6 0.104 0.140 Marking Diagram Shipping 3000pcs /tape For information on tape and reel specifications, including part orientation and tape sizes, please refer to our tape and reel packaging specification. FR201G = Part Name Carrier Tape Specification DO-15 SYMBOL Millimeters Min. Max. A 4.50 5.50 B 50.9 53.9 Z - 1.20 T 5.60 6.40 E - 0.80 IL1-L2I - 1.0  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  FR201G-FR207G Technical Data Data Sheet N0447, Rev. A DISCLAIMER: 1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product characteristics. Before ordering, purchasers are advised to contact the SMC - Sangdest Microelectronics (Nanjing) Co., Ltd sales department for the latest version of the datasheet(s). 2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment, medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by means of users’ fail-safe precautions or other arrangement . 3- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any damages that may result from an accident or any other cause during operation of the user’s units according to the datasheet(s). SMC - Sangdest Microelectronics (Nanjing) Co., Ltd assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information, products or circuits described in the datasheets. 4- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any failure in a semiconductor device or any secondary damage resulting from use at a value exceeding the absolute maximum rating. 5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and regulations..  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com 
FR207GTA
物料型号:FR201G-FR207G
器件简介:这些整流器具有快速开关特性,高效率,低反向漏电流,高正向浪涌电流能力,并且保证在260°C下10秒的高温焊接。
引脚分配:采用JEDEC DO-15塑封体,带有镀层的轴向引线,可按照MIL-STD-750标准方法2026进行焊接。
参数特性:包括最大重复峰值反向电压、最大直流阻断电压、最大有效值电压、最大平均正向整流电流、峰值正向浪涌电流、最大瞬时正向电压、最大直流反向电流、最大反向恢复时间、典型结电容和典型热阻。
功能详解:文档提供了正向电流降额曲线、最大正向恢复电压曲线、典型瞬时正向特性、典型反向特性、典型结电容和典型瞬态热阻抗的图表。
应用信息:适用于需要快速恢复和高效率的应用场合。
封装信息:器件采用DO-15封装,每卷3000个器件进行运输。文档还提供了标记图和载体胶带规格。
FR207GTA 价格&库存
很抱歉,暂时无法提供与“FR207GTA”相匹配的价格&库存,您可以联系我们找货
