SD101CW RHG
SD101CW RHG
    TAIWANSEMICONDUCTOR(台湾半导体)
    SOD-123
SD101CW RHG 数据手册
SD101AW - SD101CW Taiwan Semiconductor Small Signal Product Surface Mount, Switching Schottky Barrier Diode FEATURES - Low forward voltage drop - Guard ring construction for transient protection - Negligible reverse recovery time - Compliant to RoHS Directive 2011/65/EU and in accordance to WEEE 2002/96/EC - Halogen-free according to IEC 61249-2-21 SOD-123 MECHANICAL DATA - Case: SOD-123 small outline plastic package - Molding compound meets UL 94 V-0 flammability rating - Terminal: Matte tin plated, lead free, solderable per MIL-STD-202, Method 208 guaranteed - High temperature soldering guaranteed : 260°C/10s - Polarity: Indicated by cathode band - Weight: 0.01 g (approximately) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS (TA=25°C unless otherwise noted) PARAMETER SYMBOL Peak Repetitive Reverse Voltage VRRM Working Peak Reverse Voltage VRWM DC Blocking Voltage Non-Repetitive Peak Forward Surge Current UNIT 60 50 40 V 42 35 28 V VR RMS Reverse Voltage Forward Continue Current SD101AW SD101BW SD101CW VR(RMS) (Note 1) @t≦1s @ t = 10 μs IFM IFSM 15 mA 50 mA 2 A Power Dissipation (Note 1) PD 400 mW Thermal Resistance Junction to Ambient (Note 1) RθJA 300 °C/W TJ , TSTG -65 to +125 °C Operating and Storage Temperature Range Note 1: Valid provided that terminals are kept at ambient temperature. Version: C1601 SD101AW - SD101CW Taiwan Semiconductor Small Signal Product PARAMETER SYMBOL MIN MAX 60 - 50 - 40 - - 200 UNIT Reverse Breakdown Voltage Peak Reverse Current SD101AW IR = 10 μA SD101BW IR = 10 μA SD101CW IR = 10 μA SD101AW VR = 50 V SD101BW VR = 40 V V(BR) IR SD101CW VR = 30 V Forward Voltage Drop SD101AW IR = 1.0 mA 0.41 (Note 2) SD101BW IR = 1.0 mA 0.40 SD101CW IR = 1.0 mA SD101AW IR = 15 mA SD101BW IR = 15 mA 0.95 IR = 15 mA SD101CW VR = 0 V , f = 1.0 MHz 0.90 Junction Capacitance VF SD101AW SD101BW V 1.00 2.0 - pF 2.1 SD101CW 2.2 IF = IR = 5.0 mA Reverse Recovery Time nA 0.39 - CJ V trr Irr = 0.1 × IR , RL = 100 Ω - 1.0 ns Note 2: Pulse test: pulse width = 300 μs , duty cycle ≦ 2%. RATINGS AND CHARACTERISTICS CURVES (TA=25°C unless otherwise noted) Fig.1 Typical Forward Characteristics Fig. 2 Typ. Junction Capacitance VS. Reverse Voltage 2 A 1 Cj, Capacitance (pF) IF, Forward Current (mA) 10 B C 0.1 1 C B A 0.01 0 0 0.5 VF , Forward Voltage (mV) 1 0 10 20 30 40 50 VR , Reverse Voltage (V) Version: C1601 SD101AW - SD101CW Taiwan Semiconductor Small Signal Product ORDERING INFORMATION PART NO. PACKING CODE PACKING CODE SD101xW (Note 1, 2) SUFFIX RH G PACKAGE PACKING SOD-123 3K / 7" Reel Note 1: "x" is Device Code from "A" - "C". Note 2: Whole series with green compound EXAMPLE EXAMPLE P/N PART NO. PACKING CODE SD101AW RHG SD101AW RH PACKING CODE DESCRIPTION SUFFIX G Green compound PACKAGE OUTLINE DIMENSIONS SOD-123 DIM. Unit (mm) Unit (inch) Min Max Min Max A 1.40 1.80 0.055 0.071 B 3.55 3.85 0.140 0.152 C 0.45 0.70 0.018 0.028 D 2.55 2.85 0.100 0.112 E 0.95 1.35 0.037 0.053 F 0.05 0.15 0.002 0.006 G 0.50 REF 0.02 REF H - - 0.10 0.004 SUGGEST PAD LAYOUT Unit (mm) Unit (inch) Min Min G 2.25 0.089 X 0.90 0.035 X1 4.05 0.159 Y 0.95 0.037 DIM. MARKING Part No. Marking SD101AW S1 SD101BW S2 SD101CW S3 Version: C1601 SD101AW - SD101CW Taiwan Semiconductor Small Signal Product CREAT BY ART Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC's terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. Version: C1601
SD101CW RHG
物料型号:SD101AW、SD101BW、SD101CW
器件简介:文档描述的是台湾半导体公司生产的小型信号产品,具体为表面安装型、开关肖特基势垒二极管。
引脚分配:文档中没有明确指出具体的引脚分配图,但提到了极性通过阴极带指示。
参数特性: - 峰值重复反向电压:SD101AW为50V,SD101BW和SD101CW未给出具体数值。 - 工作峰值反向电压:SD101AW为60V,SD101BW为40V,SD101CW未给出具体数值。 - 正向连续电流:IFM为15mA。 - 非重复峰值正向浪涌电流:IFSM为50mA,10微秒时为2A。 - 功率耗散:Po为400mW。 - 热阻(结到环境):ROJA为300°C/W。 - 工作和存储温度范围:TJ,TSTG为-65至+125℃。
功能详解:文档中提到了该二极管具有低正向电压降、瞬态保护的护环结构、可忽略的反向恢复时间,并符合RoHS指令和WEEE指令。
应用信息:文档中没有提供具体的应用案例,但根据其特性,这类二极管通常用于需要快速开关和低功耗的电路中。
封装信息:封装类型为SOD-123小型轮廓塑料封装,符合UL 94 V-0可燃性等级,并且有铅锡焊料,可高温焊接至260°C/10s。
SD101CW RHG 价格&库存
很抱歉,暂时无法提供与“SD101CW RHG”相匹配的价格&库存,您可以联系我们找货
SD101CW RHG
  • 3000+0.447503000+0.05782
