S1B M2G
S1B M2G
    TAIWANSEMICONDUCTOR(台湾半导体)
    DO-214AC
    DIODE GEN PURP 100V 1A DO214AC
S1B M2G 数据手册
S1AB – S1MB Taiwan Semiconductor 1A, 50V - 1000V Standard Surface Mount Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS Glass passivated chip junction Ideal for automated placement Low forward voltage drop High surge current capability Moisture sensitivity level: level 1, per J-STD-020 RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 1 A VRRM 50 - 1000 V IFSM 30 A TJ MAX 150 °C APPLICATIONS ● ● ● ● Package DO-214AA (SMB) Configuration Single die Switching mode power supply (SMPS) Adapters Lighting application Converter MECHANICAL DATA ● ● ● ● ● ● Case: DO-214AA (SMB) Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 0.090g (approximately) DO-214AA (SMB) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL S1AB S1BB S1DB S1GB S1JB S1KB S1MB UNIT Marking code on the device S1AB S1BB S1DB S1GB S1JB S1KB S1MB Repetitive peak reverse voltage VRRM 50 100 200 400 600 800 1000 V Reverse voltage, total rms value VR(RMS) 35 70 140 280 420 560 700 V Forward current Surge peak forward current, 8.3ms single half sine-wave superimposed on rated load Junction temperature IF 1 A IFSM 30 A TJ - 55 to +150 °C Storage temperature TSTG - 55 to +150 °C 1 Version: I2102 S1AB – S1MB Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT RӨJL 30 °C/W Junction-to-lead thermal resistance ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage CONDITIONS (1) Reverse current @ rated VR IF = 1A,TJ = 25°C (2) Junction capacitance TJ = 25°C TJ = 125°C 1MHz, VR = 4.0V SYMBOL TYP MAX UNIT VF - 1.1 V - 5 µA - 50 µA 12 - pF IR CJ Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1) PACKAGE PACKING S1xB DO-214AA (SMB) 3,000 / Tape & Reel Notes: 1. "x" defines voltage from 50V(S1AB) to 1000V(S1MB) 2 Version: I2102 S1AB – S1MB Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 100 1 CAPACITANCE (pF) AVERAGE FORWARD CURRENT (A) 1.2 0.8 0.6 0.4 10 0.2 f=1.0MHz Vsig=50mVp-p 1 0 25 50 75 100 125 0.01 150 0.1 1 10 REVERSE VOLTAGE (V) LEAD TEMPERATURE (°C) Fig.4 Typical Forward Characteristics TJ=125°C 1 0.1 TJ=75°C 0.01 TJ=25°C 0.001 20 30 40 50 60 70 80 90 100 100 10 UF1DLW 1 10 TJ=125°C 1 0.01 0.001 0.1 0.3 0.6 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) TJ=25°C 0.1 (A) 10 INSTANTANEOUS FORWARD CURRENT (A) INSTANTANEOUS REVERSE CURRENT (μA) Fig.3 Typical Reverse Characteristics 100 0.4 0.8 0.5 0.6 1 0.7 1.2 Pulse width Pulse width=300μs 1% duty cycle 0.8 0.9 1 1.1 1.4 1.6 1.8 FORWARD VOLTAGE (V) 3 Version: I2102 1.2 S1AB – S1MB Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.5 Maximum Non-Repetitive Forward Surge Current PEAK FORWARD SURGE CURRENT (A) 40 8.3ms single half sine wave 30 20 10 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 4 Version: I2102 S1AB – S1MB Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS DO-214AA (SMB) SUGGESTED PAD LAYOUT MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YW = Date Code F = Factory Code Version: I2102 S1AB – S1MB Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: I2102
S1B M2G 价格&库存
很抱歉,暂时无法提供与“S1B M2G”相匹配的价格&库存,您可以联系我们找货
