S2BA M2G
S2BA M2G
    TAIWANSEMICONDUCTOR(台湾半导体)
    DO-214AC
    DIODE GEN PURP 100V 1.5A DO214AC
S2BA M2G 数据手册
S2AA – S2MA Taiwan Semiconductor 1.5A, 50V - 1000V Surface Mount Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS Glass passivated chip junction Ideal for automated placement Low forward voltage drop High surge current capability Moisture sensitivity level: level 1, per J-STD-020 RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS ● ● ● ● ● PARAMETER VALUE UNIT IF 1.5 A VRRM 50 - 1000 V IFSM 50 A TJ MAX 150 °C Package DO-214AC (SMA) Configuration Single die DC to DC converter Switching mode converters and inverters Lighting application Snubber General purpose MECHANICAL DATA ● ● ● ● ● ● Case: DO-214AC (SMA) Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 0.060g (approximately) DO-214AC (SMA) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER Marking code on the device Repetitive peak reverse voltage Reverse voltage, total rms value Forward current Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load Junction temperature Storage temperature SYMBOL S2AA S2BA S2DA S2GA S2JA S2KA S2MA UNIT S2AA S2BA S2DA S2GA S2JA S2KA S2MA VRRM 50 100 200 400 600 800 1000 V VR(RMS) 35 70 140 280 420 560 700 V IF 1.5 A IFSM 50 A TJ - 55 to +150 °C TSTG - 55 to +150 °C 1 Version: K2102 S2AA – S2MA Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT Junction-to-lead thermal resistance RӨJL 16 °C/W Junction-to-ambient thermal resistance RӨJA 53 °C/W ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage CONDITIONS (1) Reverse current @ rated VR IF = 1.5A, TJ = 25°C (2) Junction capacitance Reverse recovery time TJ = 25°C SYMBOL TYP MAX UNIT VF - 1.1 V - 5 µA - 125 µA CJ 30 - pF trr 1500 - ns IR TJ = 125°C 1MHz, VR = 4.0V IF = 0.5A, IR = 1.0A, Irr = 0.25A Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1) PACKAGE PACKING S2xA DO-214AC (SMA) 7,500 / Tape & Reel Notes: 1. “x” defines voltage from 50V(S2AA) to 1000V(S2MA) 2 Version: K2102 S2AA – S2MA Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 100 1.5 CAPACITANCE (pF) 1.0 0.5 10 f=1.0MHz Vsig=50mVp-p 1 0.0 25 50 75 100 125 0.1 150 1 LEAD TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) TJ=125°C TJ=100°C 0.1 0.01 TJ=25°C 0.001 10 20 30 40 50 60 70 80 90 100 10 10 UF1DLW 1 TJ=125°C TJ=25°C 1 0.1 0.01 0.1 0.001 0.6 0.3 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) Pulse width 300μs 1% duty cycle Pulse width 0.8 0.4 0.5 1.0 0.6 0.7 1.2 0.8 0.9 1.4 1 1.1 FORWARD VOLTAGE (V) Fig.5 Maximum Non-Repetitive Forward Surge Current 60 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (μA) Fig.4 Typical Forward Characteristics 100 1 100 REVERSE VOLTAGE (V) Fig.3 Typical Reverse Characteristics 10 10 (A) AVERAGE FORWARD CURRENT (A) 2.0 8.3ms single half sine wave 50 40 30 20 10 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: K2102 1.2 S2AA – S2MA Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram 4 Version: K2102 S2AA – S2MA Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS DO-214AC (SMA) SUGGESTED PAD LAYOUT MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YW = Date Code F = Factory Code Version: K2102 S2AA – S2MA Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: K2102
S2BA M2G
物料型号:S2AA至S2MA,由台湾半导体公司生产,是表面安装整流器。
器件简介: - 玻璃钝化芯片结构 - 适合自动化放置 - 低正向电压降 - 高浪涌电流能力 - 符合RoHS标准,无卤素
引脚分配:文档中未明确列出引脚分配图,但通常整流器有阴极和阳极两个引脚。
参数特性: - 正向电流(IF):1.5A - 反向击穿电压(VRRM):50V至1000V - 峰值正向浪涌电流(IFSM):50A - 最大结温(TJMAX):150°C - 封装类型:DO-214AC (SMA)
功能详解: - 适用于DC-DC转换器、开关模式转换器和逆变器、照明应用、消振器以及通用目的。
应用信息: - 用于DC到DC转换器、开关模式转换器和逆变器、照明应用、消振器和一般用途。
封装信息: - 封装类型为DO-214AC (SMA),符合UL 94V-0阻燃等级,引脚为镀锡的可焊接材料,符合JESD201类2须根测试。
绝对最大额定值和电气规格详细列出了不同型号的反向电压、正向电流、结温和存储温度范围等参数。
热性能和电气规格提供了结到引脚和结到环境的热阻,以及正向电压、反向电流和结电容等数据。
订购信息提供了订购代码、封装类型和包装信息,每个卷带包含7500个单位。
特性曲线图提供了正向电流降额曲线、典型结电容、典型反向特性、典型正向特性和最大非重复正向浪涌电流等数据。
包装轮廓尺寸和建议的布局图提供了详细的尺寸信息,以便于设计合适的PCB布局。
S2BA M2G 价格&库存
很抱歉,暂时无法提供与“S2BA M2G”相匹配的价格&库存,您可以联系我们找货
