1N4002G A0G
1N4002G A0G
    TAIWANSEMICONDUCTOR(台湾半导体)
    DO-204AL
1N4002G A0G 数据手册
1N4001G – 1N4007G Taiwan Semiconductor 1A, 50V - 1000V Standard Rectifier FEATURES ● ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available Glass passivated chip junction High current capability, Low VF High reliability High surge current capability Low power loss, high efficiency RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 1 A VRRM 50 - 1000 V IFSM 30 A TJ MAX 150 °C Package DO-204AL (DO-41) Configuration Single die APPLICATIONS ● DC to DC converter ● Switching mode converters and inverters ● General purpose MECHANICAL DATA ● ● ● ● ● ● Case: DO-204AL (DO-41) Molding compound meets UL 94V-0 flammability rating Terminal: Pure tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 0.330g (approximately) DO-204AL (DO-41) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device Repetitive peak reverse voltage VRRM Reverse voltage, total rms value VR(RMS) 1N 1N 1N 1N 1N 1N 1N UNIT 4001G 4002G 4003G 4004G 4005G 4006G 4007G 1N 1N 1N 1N 1N 1N 1N 4001G 4002G 4003G 4004G 4005G 4006G 4007G 50 100 200 400 600 800 1000 V 35 70 140 280 420 560 700 V Forward current Surge peak forward current, 8.3ms single half sine wave superimposed on rated load Junction temperature IF 1 A IFSM 30 A TJ -55 to +150 °C Storage temperature TSTG -55 to +150 °C 1 Version: P2104 1N4001G – 1N4007G Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT RӨJA 80 °C/W Junction-to-ambient thermal resistance ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage CONDITIONS (1) Reverse current @ rated VR IF = 1A, TJ = 25°C (2) Junction capacitance TJ = 25°C SYMBOL TYP MAX UNIT VF - 1 V - 5 µA - 100 µA 10 - pF IR TJ = 125°C 1MHz, VR = 4.0V CJ Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1)(2) PACKAGE PACKING 1N4xG DO-204AL (DO-41) 5,000 / Tape & Reel 1N4xG A0G DO-204AL (DO-41) 3,000 / Ammo box 1N4xGH DO-204AL (DO-41) 5,000 / Tape & Reel 1N4xGHA0G DO-204AL (DO-41) 3,000 / Ammo box Notes: 1. “x” defines voltage from 50V (1N4001G) to 1000V (1N4007G) 2. “H” means AEC-Q101 qualified 2 Version: P2104 1N4001G – 1N4007G Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 100 CAPACITANCE (pF) 1 10 f=1.0MHz Vsig=50mVp-p 1 0 25 50 75 100 125 1 150 10 AMBIENT TEMPERATURE (°C) REVERSE VOLTAGE (V) Fig.4 Typical Forward Characteristics INSTANTANEOUS FORWARD CURRENT (A) 100 TJ=125°C 1 TJ=75°C 0.1 TJ=25°C 0.01 10 20 30 40 50 60 70 80 90 100 10 10 UF1DLW 1 TJ=125°C 1 0.1 TJ=25°C 0.01 Pulse width 300μs 1% duty cycle Pulse width 0.1 0.001 0.7 0.8 0.9 1.0 1.1 1.2 1.3 0.3 0.4 0.5 0.6 0.7 0.8 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) 1.4 0.9 1.5 1 1.1 FORWARD VOLTAGE (V) Fig.5 Maximum Non-Repetitive Forward Surge Current 35 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (μA) Fig.3 Typical Reverse Characteristics 10 100 (A) AVERAGE FORWARD CURRENT (A) 2 30 8.3ms single half sine wave 25 20 15 10 5 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: P2104 1.2 1N4001G – 1N4007G Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS DO-204AL (DO-41) MARKING DIAGRAM 4 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: P2104 1N4001G – 1N4007G Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 5 Version: P2104
1N4002G A0G
物料型号:1N4001G至1N4007G,由台湾半导体公司生产。
器件简介: - 这些二极管是标准整流器,具有1A至1000V的额定电流和反向电压。 - 它们通过了AEC-Q101认证,适用于汽车电子。 - 采用玻璃钝化芯片结,具有高电流承载能力、低正向电压降(VF)、高可靠性和高浪涌电流能力。 - 符合RoHS标准,无卤素,符合环保要求。
引脚分配: - 封装类型为DO-204AL(DO-41),具有纯锡镀引脚,可按照J-STD-002标准进行焊接。 - 极性通过阴极带标识。
参数特性: - 正向电流(IF):1A - 反向电压(VRRM):50V至1000V - 浪涌峰值正向电流(IFSM):30A - 最大结温(TJMAX):150°C - 封装:DO-204AL(DO-41) - 配置:单芯片
功能详解: - 这些二极管适用于直流到直流转换器、开关模式转换器和逆变器以及一般用途。
应用信息: - 适用于多种电子设备,特别是在需要高可靠性和高效率的场合。
封装信息: - 机械数据包括外壳尺寸、阻燃等级、引脚镀层和极性标识。 - 重量大约为0.330克。
1N4002G A0G 价格&库存
很抱歉,暂时无法提供与“1N4002G A0G”相匹配的价格&库存,您可以联系我们找货
1N4002G A0G
  • 1+3.246001+0.42080
  • 10+1.8566010+0.24070
  • 100+1.13070100+0.14660
  • 500+0.81570500+0.10580
  • 1000+0.710301000+0.09210
  • 3000+0.613303000+0.07950
  • 6000+0.446806000+0.05800
  • 9000+0.298309000+0.03870
库存:1788
