B0520LW,B0530W,B0540W
Taiwan Semiconductor
Small Signal Product
Low VF SMD Schottky Barrier Diode
FEATURES
- Low power loss, high current capability, low VF
- Surface mount device type
- Moisture sensitivity level 1
- Matte Tin (Sn) lead finish with Nickel (Ni) under plate
- Compliant to RoHS Directive 2011/65/EU and
in accordance to WEEE 2002/96/EC
- Halogen-free according to IEC 61249-2-21
SOD-123
MECHANICAL DATA
- Case: Bend lead SOD-123 small outline plastic package
- Terminal: Matte tin plated, lead free,
solderable per MIL-STD-202, Method 208 guaranteed
- High temperature soldering guaranteed : 260°C/10s
- Polarity: Indicated by cathode band
- Weight: 0.01 g (approximately)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS (TA=25°C unless otherwise noted)
PARAMETER
SYMBOL
Power Dissipation
B0520LW
PD
B0530W
B0540W
410
mW
VRRM
40
Reverse Voltage
VR
14
21
28
Mean Forward Current @ TL=100°C (Lead Temperature)
IO
Repetitive Peak Reverse Voltage
UNIT
V
V
500
mA
Non-Repetitive Peak Forward Surge Current (Note 1)
IFSM
5.5
A
Thermal Resistance (Junction to Ambient)
RθJA
244
°C/W
TJ , TSTG
-55 to +125
°C
(Note 2)
Junction and Storage Temperature Range
Notes: 1. Test Condition: 8.3ms single half sine-wave superimposed on rated load
Notes: 2. Valid provided that electrodes are kept at ambient temperature
PARAMETER
Reverse Breakdown Voltage
(Minimum Value)
Forward Voltage
(Maximum Value)
SYMBOL
IR=250μA
IR=130μA
V(BR)
IR=20μA
IF=100mA
IF=500mA
TJ = 25°C
VF
IF=1000mA
VR = 10V
Reverse Leakage Current
(Maximum Value)
VR = 15V
VR = 20V
TJ = 25°C
IR
VR = 30V
VR = 0 V
B0530W
B0540W
40
0.300
0.375
0.385
0.430
0.510
0.620
75
10
130
VR = 40V
Junction Capacitance
B0520LW
f=1.0MHz
CJ
170
UNIT
V
V
μA
pF
Version: I1601
RATINGS AND CHARACTERISTICS CURVES
Fig. 2 Forward Current Derating Curve
Fig.1 Typical Forward Characteristics
0.75
B0540W
1
IO Mean Forward Current (A)
IF Forward Current (A)
10
B0530W
B0520LW
0.1
0.5
0.25
Fig. 4
0.0
0.2
0.4
0.6
0.8
25
50
100
125
150
TL , Lead Temperature (°C)
VF Forward Voltage (V)
Fig. 4 Typical Junction Capacitance
Fig. 3 Admissible Power Dissipation Curve
Fig. 3
75
450
400
Junction Capacitance (pF)
Power Dissipation (mW)
350
300
250
200
150
100
100
10
50
1
60
80
100
Ambient Temperature (°C)
120
140
10
15
Reverse Voltage (V)
Version: I1601
ORDERING INFORMATION
PART NO.
B05xxx
(Note 1, 2)
PACKING CODE
PACKING CODE
SUFFIX
RH
G
PACKAGE
PACKING
SOD-123
3K / 7" Reel
Note 1: "xxx" defines voltage from 20V (B0520LW) to 40V (B0540W)
Note 2: Whole series with green compound
EXAMPLE
EXAMPLE
PART NO.
B0540W RH
PART NO.
PACKING CODE
B0540W
RH
PACKING CODE
SUFFIX
G
DESCRIPTION
Green compound
Version: I1601
PACKAGE OUTLINE DIMENSIONS
SOD-123
DIM.
Unit (mm)
Unit (inch)
Min
Max
Min
Max
A
1.40
1.80
0.055
0.071
B
3.55
3.85
0.140
0.152
C
0.45
0.70
0.018
0.028
D
2.55
2.85
0.100
0.112
E
0.95
1.35
0.037
0.053
F
0.05
0.15
0.50 REF
G
H
0.10
0.002
0.006
0.02 REF
0.004
SUGGEST PAD LAYOUT
DIM.
Unit (mm)
Unit (inch)
Min
Min
G
2.25
0.089
X
0.90
0.035
X1
4.05
0.159
Y
0.95
0.037
MARKING
Part No.
B0520LW
Marking
SD
B0530W
SE
B0540W
SF
Version: I1601
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC's terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
Version: I1601
很抱歉,暂时无法提供与“B0520LW RHG”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+2.92862
- 10+1.22176
- 50+1.03490
- 100+0.97022
- 500+0.91392
- 国内价格 香港价格
- 1+3.446241+0.44785
- 10+2.1178910+0.27523
- 50+1.5263850+0.19836
- 100+1.33230100+0.17314
- 500+0.98889500+0.12851
- 国内价格 香港价格
- 3000+0.736243000+0.09568
- 9000+0.628429000+0.08167
