LL4003G L0G
LL4003G L0G
    TAIWANSEMICONDUCTOR(台湾半导体)
    DO213AB
    DIODE GEN PURP 200V 1A MELF
LL4003G L0G 数据手册
LL4001G – LL4007G Taiwan Semiconductor 1A, 50 - 1000V Surface Mount Rectifier FEATURES ● ● ● ● ● ● KEY PARAMETERS Plastic package has carries underwriters Ideal for automated placement Surge overload rating to 30A peak Reliable low cost construction utilizing molded RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 1 A VRRM 50 - 1000 V IFSM 30 A TJ MAX 150 °C Package APPLICATIONS MELF ● Inverters and Converters ● Free Wheeling diodes MECHANICAL DATA ● ● ● ● ● Case: MELF Molding compound meets UL 94V-0 flammability rating Meet JESD 201 class 1A whisker test Polarity: Indicated by cathode band Weight: 120.00mg (approximately) MELF ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL LL4001 LL4002 LL4003 LL4004 LL4005 LL4006 LL4007 G G G G G G G UNIT Repetitive peak reverse voltage VRRM 50 100 200 400 600 800 1000 V Reverse voltage, total rms value VR(RMS) 35 70 140 280 420 560 700 V VDC 50 100 200 400 600 800 1000 V DC blocking voltage Forward current IF 1 A IFSM 30 A Junction temperature TJ -65 to +150 °C Storage temperature TSTG -65 to +150 °C Surge peak forward current 8.3ms single half sine-wave superimposed on rated load 1 Version: F2004 LL4001G – LL4007G Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT RӨJC 50 °C/W Junction-to-case thermal resistance ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage CONDITIONS (1) Reverse current @ rated VR IF = 1.0A (2) Junction capacitance TJ = 25°C SYMBOL TYP MAX UNIT VF - 1.1 V - 5 µA - 100 µA 15 - pF IR TJ = 125°C 1 MHz, VR=4.0V CJ Notes: 1. Pulse test with PW=0.3 ms 2. Pulse test with PW=30 ms ORDERING INFORMATION ORDERING CODE(1) PACKAGE PACKING LL400xG L0G MELF 5,000/13” reel Notes: (1) “x” defines voltage from 50V(LL4001G) – 1000V(LL4007G) 2 Version: F2004 LL4001G – LL4007G Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Maximum Non-Repetitive Peak Forward Surge Current 30 Peak Forward Surge Current (A) Average Forward Current (A) 1.2 1 0.8 0.6 0.4 0.2 Resistive or Inductive Load 0 0 25 50 75 100 125 25 20 15 10 5 8.3ms Single Half Sine Wave 0 1 150 10 Terminal Temperature (°C) Fig.3 Typical Forward Characteristics Fig.4 Typical Reverse Characteristics 1000 Instantaneous Reverse Current (μA) Instantaneous Forward Current (A) 10 1 0.1 Pulse Width = 300μs 1% Duty Cycle 0.01 0.4 0.6 0.8 1 1.2 1.4 1.6 TJ = 150°C 100 10 TJ = 100°C 1 TJ = 25°C 0.1 0.01 0 20 40 60 80 100 Percentage of Peak Reverse Voltage(%) Instantaneous Forward Voltage(V) Fig.5 Typical Junction Capacitance Fig.6 Typical Transient Thermal Impedance 100 100 Transient Thermal Impedance (°C/W) Junction Capacitance (pF) 100 Number of Cycles at 60Hz 10 f = 1.0MHZ Vsig=50mVP-P 1 0.1 1 10 100 Reverse Voltage(V) 10 1 0.1 0.01 0.1 1 10 100 t - Pulse Duration (s) 3 Version: F2004 LL4001G – LL4007G Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS MELF Unit (mm) DIM Unit (inch) Min Max Min Max A 4.80 5.50 0.189 0.217 B 2.25 2.67 0.089 0.105 C 0.30 0.60 0.012 0.024 SUGGESTED PAD LAYOUT Unit (mm) Unit (inch) TYP TYP C 4.80 0.189 G 3.30 0.130 X 1.50 0.059 X1 6.30 0.248 Y 2.70 0.106 DIM 4 Version: F2004 LL4001G – LL4007G Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 5 Version: F2004
LL4003G L0G 价格&库存
很抱歉,暂时无法提供与“LL4003G L0G”相匹配的价格&库存,您可以联系我们找货
