RURG3020CC
RURG3020CC
    L3HARRIS
    TO247
    30 A, 200 V,超快双二极管
RURG3020CC 数据手册
RURG3020CC November 2013 Data Sheet 30 A, 200 V, Ultrafast Dual Diode Features • Ultrafast Recovery trr = 50 ns (@ IF = 30 A) • Max Forward Voltage, VF = 1.0 V (@ TC = 25°C) Description • Reverse Voltage, VRRM = 200 V The RURG3020CC is an ultrafast dual diode with low forward voltage drop. This device is intended for use as freewheeling and clamping diodes in a variety of switching power supplies and other power switching applications. It is specially suited for use in switching power supplies and industrial application. • Avalanche Energy Rated • RoHS Compliant Applications • Switching Power Supplies • Power Switching Circuits • General Purpose Packaging Ordering Information PART NUMBER RURG3020CC PACKAGE TO-247 JEDEC STYLE TO-247 BRAND ANODE 1 CATHODE ANODE 2 RURG3020C NOTE: When ordering, use the entire part number. CATHODE (BOTTOM SIDE METAL) Symbol K A1 Absolute Maximum Ratings A2 (Per Leg) TC = 25oC RURG3020CC UNIT Peak Repetitive Reverse Voltage . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . VRRM 200 V Working Peak Reverse Voltage . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .VRWM 200 V DC Blocking Voltage . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . VR Average Rectified Forward Current (Per Leg) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . IF(AV) 200 V 30 A 70 A 325 A (TC = 145oC) Repetitive Peak Surge Current . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . IFRM (Square Wave, 20 kHz) Nonrepetitive Peak Surge Current . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . IFSM (Halfwave, 1 Phase, 60 Hz) Maximum Power Dissipation . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . PD 125 W Avalanche Energy (See Figures 7 and 8) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .EAVL 20 mJ Operating and Storage Temperature . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .TSTG, TJ -65 to 175 oC ©2001 Fairchild Semiconductor Corporation RURG3020CC Rev. C1 1 www.fairchildsemi.com RURG3020CC Electrical Specifications (Per Leg) TC = 25oC, Unless Otherwise Specified SYMBOL TEST CONDITION MIN TYP MAX IF = 30 A - - 1.0 V IF = 30 A, TC = 150oC - - 0.85 V VR = 200 V - - 250 µA VR = 200 V, TC = 150oC - - 1 mA IF = 1 A, dIF/dt = 100 A/µs - - 45 ns IF = 30 A, dIF/dt = 100 A/µs - - 50 ns ta IF = 30 A, dIF/dt = 100 A/µs - 20 - ns tb IF = 30 A, dIF/dt = 100 A/µs - 15 - ns - - 1.2 oC/W VF IR trr RθJC UNIT DEFINITIONS VF = Instantaneous forward voltage (pw = 300 µs, D = 2%). IR = Instantaneous reverse current. Trr = Reverse recovery time (See Figure 6), summation of ta + tb. ta = Time to reach peak reverse current (See Figure 6). tb = Time from peak IRM to projected zero crossing of IRM based on a straight line from peak IRM through 25% of IRM (See Figure 6). RθJC = Thermal resistance junction to case. pw = Pulse width. D = Duty cycle. Typical Performance Curves 400 200 100 IR, REVERSE CURRENT (µA) IF , FORWARD CURRENT (A) 100 175oC 10 100oC 25oC 175oC 10 100oC 1.0 0.1 0.01 25oC 0.001 1 0 0.3 0.6 0.9 1.2 0 1.5 FIGURE 1. FORWARD CURRENT vs FORWARD VOLTAGE ©2001 Fairchild Semiconductor Corporation RURG3020CC Rev. C1 50 100 150 200 VR, REVERSE VOLTAGE (V) VF , FORWARD VOLTAGE (V) FIGURE 2. REVERSE CURRENT vs REVERSE VOLTAGE 2 www.fairchildsemi.com RURG3020CC Typical Performance Curves (Continued) IF(AV) , AVERAGE FORWARD CURRENT (A) 40 trr t, TIME (ns) 30 ta 20 tb 10 0 1 10 40 30 DC 20 SQ. WAVE 10 30 0 130 140 150 160 180 170 TC, CASE TEMPERATURE (oC) IF , FORWARD CURRENT (A) FIGURE 3. trr, ta AND tb CURVES vs FORWARD CURRENT FIGURE 4. CURRENT DERATING CURVE Test Circuits and Waveforms VGE AMPLITUDE AND RG CONTROL dIF/dt t1 AND t2 CONTROL IF L DUT CURRENT SENSE RG IF + VGE - IGBT t1 dIF trr dt ta tb 0 VDD 0.25 IRM t2 IRM FIGURE 5. trr TEST CIRCUIT FIGURE 6. trr WAVEFORMS AND DEFINITIONS I = 1A L = 40mH R < 0.1Ω EAVL = 1/2LI2 [VR(AVL) /(VR(AVL) - VDD)] Q1 = IGBT (BVCES > DUT VR(AVL)) VAVL L CURRENT SENSE R + VDD IL IL I V Q1 VDD DUT t0 FIGURE 7. AVALANCHE ENERGY TEST CIRCUIT ©2001 Fairchild Semiconductor Corporation RURG3020CC Rev. C1 t1 t2 t FIGURE 8. AVALANCHE CURRENT AND VOLTAGE WAVEFORMS 3 www.fairchildsemi.com RURG3020CC — Ultrafast Diode TO247-3L Figure 9. TO-247,Molded, 3LD, Jedec Option AB Package drawings are provided as a service to customers considering Fairchild components. Drawings may change in any manner without notice. Please note the revision and/or date on the drawing and contact a Fairchild Semiconductor representative to verify or obtain the most recent revision. Package specifications do not expand the terms of Fairchild’s worldwide terms and conditions, specifically the warranty therein, which covers Fairchild products. Always visit Fairchild Semiconductor’s online packaging area for the most recent package drawings: http://www.fairchildsemi.com/package/packageDetails.html?id=PN_TO247-003. ©2001 Fairchild Semiconductor Corporation RURG3020CC Rev. C1 4 www.fairchildsemi.com *Trademarks of System General Corporation, used under license by Fairchild Semiconductor. DISCLAIMER FAIRCHILD SEMICONDUCTOR RESERVES THE RIGHT TO MAKE CHANGES WITHOUT FURTHER NOTICE TO ANY PRODUCTS HEREIN TO IMPROVE RELIABILITY, FUNCTION, OR DESIGN. FAIRCHILD DOES NOT ASSUME ANY LIABILITY ARISING OUT OF THE APPLICATION OR USE OF ANY PRODUCT OR CIRCUIT DESCRIBED HEREIN; NEITHER DOES IT CONVEY ANY LICENSE UNDER ITS PATENT RIGHTS, NOR THE RIGHTS OF OTHERS. THESE SPECIFICATIONS DO NOT EXPAND THE TERMS OF FAIRCHILD’S WORLDWIDE TERMS AND CONDITIONS, SPECIFICALLY THE WARRANTY THEREIN, WHICH COVERS THESE PRODUCTS. LIFE SUPPORT POLICY FAIRCHILD’S PRODUCTS ARE NOT AUTHORIZED FOR USE AS CRITICAL COMPONENTS IN LIFE SUPPORT DEVICES OR SYSTEMS WITHOUT THE EXPRESS WRITTEN APPROVAL OF FAIRCHILD SEMICONDUCTOR CORPORATION. As used here in: 1. Life support devices or systems are devices or systems which, (a) are intended for surgical implant into the body or (b) support or sustain life, and (c) whose failure to perform when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in a significant injury of the user. 2. A critical component in any component of a life support, device, or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness. ANTI-COUNTERFEITING POLICY Fairchild Semiconductor Corporation’s Anti-Counterfeiting Policy. Fairchild’s Anti-Counterfeiting Policy is also stated on our external website, www.Fairchildsemi.com, under Sales Support. Counterfeiting of semiconductor parts is a growing problem in the industry. All manufactures of semiconductor products are experiencing counterfeiting of their parts. Customers who inadvertently purchase counterfeit parts experience many problems such as loss of brand reputation, substandard performance, failed application, and increased cost of production and manufacturing delays. Fairchild is taking strong measures to protect ourselves and our customers from the proliferation of counterfeit parts. Fairchild strongly encourages customers to purchase Fairchild parts either directly from Fairchild or from Authorized Fairchild Distributors who are listed by country on our web page cited above. Products customers buy either from Fairchild directly or from Authorized Fairchild Distributors are genuine parts, have full traceability, meet Fairchild’s quality standards for handing and storage and provide access to Fairchild’s full range of up-to-date technical and product information. Fairchild and our Authorized Distributors will stand behind all warranties and will appropriately address and warranty issues that may arise. Fairchild will not provide any warranty coverage or other assistance for parts bought from Unauthorized Sources. Fairchild is committed to combat this global problem and encourage our customers to do their part in stopping this practice by buying direct or from authorized distributors. PRODUCT STATUS DEFINITIONS Definition of Terms Datasheet Identification Product Status Definition Advance Information Formative / In Design Datasheet contains the design specifications for product development. Specifications may change in any manner without notice. Preliminary First Production Datasheet contains preliminary data; supplementary data will be published at a later date. Fairchild Semiconductor reserves the right to make changes at any time without notice to improve design. No Identification Needed Full Production Datasheet contains final specifications. Fairchild Semiconductor reserves the right to make changes at any time without notice to improve the design. Obsolete Not In Production Datasheet contains specifications on a product that is discontinued by Fairchild Semiconductor. The datasheet is for reference information only. Rev. I66 ©2001 Fairchild Semiconductor Corporation RURG3020CC Rev. C1 5 www.fairchildsemi.com RURG3020CC — Ultrafast Diode TRADEMARKS The following includes registered and unregistered trademarks and service marks, owned by Fairchild Semiconductor and/or its global subsidiaries, and is not intended to be an exhaustive list of all such trademarks. Sync-Lock™ F-PFS™ AccuPower™ ® FRFET® AX-CAP®* ®* ® Global Power ResourceSM PowerTrench BitSiC™ GreenBridge™ PowerXS™ Build it Now™ TinyBoost® Green FPS™ Programmable Active Droop™ CorePLUS™ TinyBuck® ® Green FPS™ e-Series™ QFET CorePOWER™ TinyCalc™ QS™ Gmax™ CROSSVOLT™ TinyLogic® Quiet Series™ GTO™ CTL™ TINYOPTO™ RapidConfigure™ IntelliMAX™ Current Transfer Logic™ TinyPower™ ISOPLANAR™ DEUXPEED® ™ TinyPWM™ Dual Cool™ Marking Small Speakers Sound Louder TinyWire™ Saving our world, 1mW/W/kW at a time™ EcoSPARK® and Better™ TranSiC™ EfficentMax™ SignalWise™ MegaBuck™ TriFault Detect™ ESBC™ SmartMax™ MICROCOUPLER™ TRUECURRENT®* SMART START™ MicroFET™ ® SerDes™ Solutions for Your Success™ MicroPak™ SPM® MicroPak2™ Fairchild® ® STEALTH™ MillerDrive™ Fairchild Semiconductor UHC® SuperFET® MotionMax™ FACT Quiet Series™ ® Ultra FRFET™ ® SuperSOT™-3 mWSaver FACT UniFET™ OptoHiT™ SuperSOT™-6 FAST® ® VCX™ OPTOLOGIC SuperSOT™-8 FastvCore™ ® ® VisualMax™ OPTOPLANAR SupreMOS FETBench™ VoltagePlus™ SyncFET™ FPS™ XS™
RURG3020CC 价格&库存
很抱歉,暂时无法提供与“RURG3020CC”相匹配的价格&库存,您可以联系我们找货
