UG2004PT C0G
UG2004PT C0G
    TAIWANSEMICONDUCTOR(台湾半导体)
    TO247
    DIODE ARRAY GP 200V 20A TO247AD
UG2004PT C0G 数据手册
UG2004PT Taiwan Semiconductor 20A, 200V Ultra Fast Rectifier FEATURES KEY PARAMETERS ● ● ● ● ● ● ● ● AEC-Q101 qualified available Dual rectifier construction, positive center-tap Ultrafast recovery time Low reverse recovery current Low forward voltage Reduces switching losses Reduces conduction losses Low thermal resistance ideal solution for high operation temperature ● RoHS Compliant ● Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 20 A VRRM 200 V IFSM 200 A TJ MAX 175 °C Package TO-247AD (TO-3P) Configuration Dual dies APPLICATIONS ● ● ● ● ● DC to DC converter Switching mode converters and inverters Lighting application Snubber Freewheeling application MECHANICAL DATA ● ● ● ● ● ● ● Case: TO-247AD (TO-3P) Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Mounting torque: 1.13 N⋅m maximum Polarity: As marked Weight: 6.10g (approximately) TO-247AD (TO-3P) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device UG2004PT UNIT UG2004PT Repetitive peak reverse voltage VRRM 200 V Reverse voltage, total rms value VR(RMS) 140 V Forward current Surge peak forward current 8.3ms single half sine wave superimposed on rated load Junction temperature IF 20 A IFSM 200 A TJ -55 to +175 °C Storage temperature TSTG -55 to +175 °C 1 Version: F2103 UG2004PT Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT RӨJC 1.5 °C/W Junction-to-case thermal resistance ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage per diode (1) Reverse current @ rated VR per diode Reverse recovery time (2) CONDITIONS SYMBOL TYP MAX UNIT IF = 10A, TJ = 25°C VF - 0.93 V TJ = 25°C IR - 200 µA trr - 25 ns IF = 0.5A, IR = 1.0A Irr = 0.25A Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1) PACKAGE PACKING UG2004PT TO-247AD (TO-3P) 30 / Tube UG2004PTH TO-247AD (TO-3P) 30 / Tube Notes: 1. “H” means ACE-Q101 qualified 2 Version: F2103 UG2004PT Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 1000 20 CAPACITANCE (pF) 15 10 100 5 0 f=1.0MHz Vsig=50mVp-p 10 25 50 75 100 125 150 175 0.1 1 CASE TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) TJ=125°C TJ=75°C 0.01 TJ=25°C 0.001 10 20 30 40 50 60 70 80 90 100 100 10 10 UF1DLW 1 TJ=125°C TJ=25°C 0.1 1 0.01 Pulse width 300μs 1% duty cycle Pulse width 0.1 0.001 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 1.1 1.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) 1.1 FORWARD VOLTAGE (V) Fig.5 Maximum Non-Repetitive Forward Surge Current 250 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (μA) Fig.4 Typical Forward Characteristics 10 0.1 100 REVERSE VOLTAGE (V) Fig.3 Typical Reverse Characteristics 1 10 (A) AVERAGE FORWARD CURRENT (A) 25 8.3ms single half sine wave 200 150 100 50 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: F2103 1.2 UG2004PT Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram 4 Version: F2103 UG2004PT Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS TO-247AD (TO-3P) MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: F2103 UG2004PT Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: F2103
UG2004PT C0G 价格&库存
很抱歉,暂时无法提供与“UG2004PT C0G”相匹配的价格&库存,您可以联系我们找货
