PART CODE:
DO411N4007A10A
SPECIFICATION SHEET
SPECIFICATION SHEET NO.
N0310-DO411N4007A10A
DATE
Mar. 10, 2021
REVISION
A0
DESCRIPITION
Axial Lead General Purpose Silicon Rectifier, DO-41 series,
1N4007 – T/B Type 2 Pins
Reverse Voltage 1000V Max. Forward Current 1.0A Max.
Operating Temp. Range -55°C ~+150°C
Package in AMMO Pack, 5000pcs/Tape, Tape/Box
RoHS/RoHS III compliant
CUSTOMER
CUSTOMER PART NUMBER
CROSS REF. PART NUMBER
ORIGINAL PART NUMBER
MDD 1N4007 – T/B
PART CODE
DO411N4007A10A
VENDOR APPROVE
Issued/Checked/Approved
DATE: March 10, 2021
CUSTOMER APPROVE
DATE:
NextGen Components, Inc.
sales@NextGenComponent.com
www.NextGenComponent.com
PART CODE:
DO411N4007A10A
GENERAL PURPOSE SILICON RECTIFIER DO-41 SERIES
MAIN FEATURE
• The plastic package carries Underwriters Laboratory Flammability Classification 94V-0
• Fast switching for high efficiency
• High forward surge current capability
• High temperature soldering guaranteed, 250 °C/10 seconds at terminals
• Low reverse leakage
APPLICATION
• For printed circuit board
RFQ
PART CODE GUIDE
Request For Quotation
DO41
1N4007
A
10A
1
2
3
4
1) DO41: Axial Lead General Purpose Silicon Rectifier, 2 Pins, DO-41 series
2) 1N4007: Type code for original part number 1N4007- T/B
3) A: Package code, Package in AMMO Pack, 5000pcs/Tape, Tape/Box
4) 10A: Specification code for Reverse Voltage 1000V Max. Forward Current 1.0A Max.
MORE ITEMS AVAILABLE
DO41IN4001A105
DO41IN4002A110
DO41IN4003A120
DO41IN4004A140
DO41IN4005A160
DO41IN4007A10A
PART CODE:
DO411N4007A10A
DIMENSION (Unit: Inch/mm)
Image for reference
Marking: 1N4007
DO-41
PART CODE:
DO411N4007A10A
MECHANICAL DATA
Case
Terminals
Polarity
Mounting
Position
Weight
per piece
JEDEC DO-41 molded
plastic body
Solder plated,
Solderable per
MIL-STD-750,
Method 2026
Polarity symbol
marking on case
Any
0.012 Ounce,
0.373 grams
VALUE
UNITS
MAX. RATING & CHARACTERISTICS
Parameter
SYMBOLS
Min.
Typical
Max.
Repetitive peak reverse voltage
V RRM
1000
Volts
RMS voltage
V RMS
700
Volts
DC blocking voltage
V DC
1000
Volts
Average forward output rectified current
I AV
1.0
A
at TL= 110°C
I FSM
Peak forward surge current 8.3ms single half
30
A
sine-wave superimposed on rated load
(JEDEC Method)
Instantaneous forward voltage at 1.0A
DC reverse current at rated DC
blocking voltage
TA=25℃
VF
1.10
Volts
IR
5
µA
50
µA
TA=100℃
Junction capacitance (Note 2)
CJ
15
pF
Thermal resistance (Note 3)
R QJA
50
°C/W
Operating junction temperature range
Storage temperature range
TJ
-65
+150
°C
T STG
-65
+150
°C
Note
1. Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz, resistive or inductive load, for
capacitive load current derate by 20%.
2. Measured at 1.0MHz and applied reverse voltage of 4.0Voltage
3. Thermal resistance from junction to ambient at 0.375”(9.5mm)lead length, PCB. Mounted.
PART CODE:
DO411N4007A10A
RELIABILITY
Number
Experiment Items
Experiment Method And Conditions
Reference
Documents
1
Solder Resistance Test
Test 260°C± 5°C for 10 ± 2 sec.
Immerse body into solder 1/16” ± 1/32"
MIL-STD-750D
METHOD-2031.2
2
Solderability Test
230°C ±5°C for 5 sec.
MIL-STD-750D
METHOD-2026.1 0
3
Pull Test
1 kg in axial lead direction for 10 sec.
MIL-STD-750D
METHOD-2036.4
4
Bend Test
0.5Kg Weight Applied To Each Lead,
Bending Arcs 90 °C ± 5 °C For 3 Times
MIL-STD-750D
METHOD-2036.4
5
High Temperature Reverse
Bias Test
TA=100°C for 1000 Hours at VR=80%
Rated VR
MIL-STD-750D
METHOD-1038.4
6
Forward Operation Life Test
TA=25°C Rated Average Rectified
Current
MIL-STD-750D
METHOD-1027.3
7
Intermittent Operation Life
Test
On state: 5 min with rated IRMS Power
Off state: 5 min with Cool Forced Air.
On and off for 1000 cycles.
MIL-STD-750D
METHOD-1036.3
8
Pressure Cooker Test
15 PSIG, TA=121°C, 4 hours
MIL-S-19500
APPENOIXC
9
Temperature Cycling Test
-55°C~+125°C; 30 Minutes For Dwelled
Time 5 minutes for transferred time.
Total: 10 cycles.
MIL-STD-750D
METHOD-1051.7
10
Thermal Shock Test
0°C for 5 minutes., 100°C for 5minutes,
Total: 10 cycles
MIL-STD-750D
METHOD-1056.7
11
Forward Surge Test
8.3ms Single Sale Sine-wave One Surge.
MIL-STD-750D
METHOD-4066.4
12
Humidity Test
TA=65°C, RH=98% for 1000 hours.
MIL-STD-750D
METHOD-1021.3
13
High Temperature Storage
life Test
150°C for 1000 Hours
MIL-STD-750D
METHOD-1031.5
PART CODE:
DO411N4007A10A
RATINGS AND CHARACTERISTIC CURVES (For Reference Only)
PART CODE:
DO411N4007A10A
AMMO BOX (Unit: mm)
• All Devices are packed in accordance with EIA standard RS-296-D and specifications.
• Each component lead shall be sandwiched between taps for A minimum of 3.2 mm (-.126”)
Item
Symbol
DO-41
Uni(mm)
DO-41
Unit (Inch)
Component Alignment
Z
1.2 Max.
0.048 Max.
Tape Width
T
6.0 +/- 0.4
0.236 +/- 0.016
Exposed Adhesive
E
0.8 Max.
0.032 Max.
Body Eccentricity
L1 – L2
1.0 Max.
0.040 Max.
Component Pitch A
(2.0mm/20 pitch)
A
5.0
0.197
Component Pitch B
(2.0mm/20 pitch)
B
26.0
1.023
Component Pitch A
(2.0mm/10 pitch)
A
5.0
0.197
Component Pitch B
(2.0mm/10 pitch)
B
52.4
2.063
Box Length
L
255.0 +/- 5.0
10.04 +/- 0.197
Box Width
W
78.0 +/- 5.0
3.07 +/- 0.197
Box Height
H
150.0 +/- 5.0
5.91 +/- 0.197
PART CODE:
DO411N4007A10A
AMMO PACK IN TAPE/BOX (Unit: mm)
Case
Code
DO-41
Qty.
Per Reel
(pcs)
Component
Space
(mm)
Tape
Space
(mm)
Inner Box
L*W*H
(mm)
Carton size
L*W*H
(mm)
Qty.
Per Carton
(pcs)
G. W
5000
5.0
52.4
198*86*21
450*215*250
50,000
12.45
(kg)
DISCLAIMER
NextGen Component, Inc. reserves the right to make changes to the product(s) and or information contained herein
without notice. No liability is assumed as a result of their use or application. No rights under any patent accompany
the sale of any such product(s) or information
很抱歉,暂时无法提供与“1N4007-T/B”相匹配的价格&库存,您可以联系我们找货
