PRELIMINARY
CSD20030
ZERO RECOVERYTM RECTIFIER
Features
Benefits
_________
• 300 Volt Schottky Rectifier
• Replace Bipolar with Unipolar Rectifiers
• Zero Reverse Recovery
• Essentially No Switching Losses
• Zero Forward Recovery
• Higher Efficiency
• High Frequency Operation
• Reduction Of Heat Sink Requirements
• Temperature Independent Switching Behavior
• Parallel Devices without Thermal Runaway
• Extremely Fast Switching
• Positive Temperature Coefficient on VF
Applications
Switch Mode Power Supplies
Power Factor Correction
Motor Drives
Output Rectification
Package
_____________
Maximum Ratings
Parameter
Symbol
Value
Unit
Repetitive Peak Reverse Voltage
VRRM
300
V
Surge Peak Reverse Voltage
VRSM
300
V
DC Blocking Voltage
VDC
300
V
IF(AV)
A
Repetitive Peak Forward Surge Current (Per Leg)
TC=25°C, tP=8.3ms, Half Sine Wave
IFRM
40
A
Non-Repetitive Peak Forward Surge Current (Per Leg)
TC=25°C, tP=10µs, Pulse
IFSM
200
A
Power Dissipation (Per Leg)
TC = 25°C
Ptot
79
W
TJ , Tstg
-55 to +175
°C
Average Forward Current
TC=150°C
(Per Device)
(Per Leg)
Operating Junction and Storage Temperature
Page 1 • CSD20030, Rev A
PRELIMINARY
CSD20030
ELECTRICAL CHARACTERISTICS (PER LEG)
Parameter
Symbol
Forward Voltage
IF = 10A TJ=25°C
IF = 10A TJ=175°C
Reverse Current
VR = 300V TJ=25°C
VR = 300V TJ=175°C
Total Capacitive Charge
VR = 300V,IF = 10A, di/dt = 500 A/µs, TJ = 25°C
Total Capacitance
VR = 0V, TJ = 25°C, f =1MHz
VR = 150V, TJ = 25°C, f =1MHz
VR = 300V, TJ = 25°C, f =1MHz
Min
VF
IR
Typ
Max
Units
1.2
1.4
1.4
1.8
50
200
1000
2000
V
µA
QC
11.5
nC
C
660
62
58
pF
NOTE:
1. This is a majority carrier diode, so there is no reverse recovery charge.
THERMAL CHARACTERISTICS
Characteristic
Symbol
Thermal Resistance from Junction to Case
Min
Typ
Max
Units
Per Leg
RθJC
1.9
°C/W
Per Device
RθJC
0.95
°C/W
Typical Performance (Per Leg)
Figure 2. Reverse Characteristics
18
900
16
800
14
IR Reverse Current (uA)
IF FORWARD CURRENT (A)
Figure 1. Forward Characteristics
T J = 25 °C
T J = 75 °C
T J = 125 °C
T J = 175 °C
12
10
8
6
700
TJ = 25 C
TJ = 750 C
TJ = 1250 C
TJ = 1500 C
TJ = 1750 C
600
500
400
300
4
200
2
100
0.5
1.0
1.5
VF FORWARD VOLTAGE (V)
Page 2 • CSD20030, Rev A
2.0
2.5
200
300
400
VR Reverse Voltage (V)
500
600
PRELIMINARY
Figure 3. Current Derating
CSD20030
Figure 4. Capacitance vs. Reverse Voltage
30
500
450
400
350
Capacitance (pF)
IF(AV) Forward Current (A)
25
15
10
300
250
200
150
100
5
50
50
75
100
125
150
175
200
1
10
100
1000
TC Case Temperture (°°C)
Figure 5. Transient Thermal Impedance
1.00E+01
Zth [°C/W]
1.00E+00
1.00E-01
1.00E-02
1.00E-03
1.00E-07 1.00E-06 1.00E-05 1.00E-04 1.00E-03 1.00E-02 1.00E-01 1.00E+00
time [s]
Page 3 • CSD20030, Rev A
PRELIMINARY
CSD20030
Package Dimensions
Package TO-247-3
A
V
H
J
K
POS
L
B
S
T
U
N
M
C
R
D
P
E
F
A
B
C
D
E
F
G
H
J
K
L
M
N
P
Q
R
S
T
U
V
Inches
Min
Max
.621
.631
.820
.830
.789
.799
.120
.126
.047
.052
.075
.084
.215 TYP
.193
.203
.075
.081
19°
21°
4°
6°
2°
4°
2°
4°
.093
.097
.024
.030
9°
11°
9°
11°
2°
4°
2°
4°
.140
.144
Millimeters
Min
Max
15.773 16.027
20.823 21.077
20.053 20.307
3.044 3.196
1.200 1.327
1.903 2.132
5.450 TYP
4.903 5.157
1.904 2.056
19°
21°
4°
6°
2°
4°
2°
4°
2.349 2.451
.600
.752
9°
11°
9°
11°
2°
4°
2°
4°
3.560 3.660
Q
G
PIN 1
PIN 2
CASE
PIN 3
Part Number
CSD20030D
Package
TO-247-3
Marking
CSD20030
This product has not been designed or tested for
use in, and is not intended for use in, applications
implanted into the human body nor in applications
in which failure of the product could lead to death,
personal injury or property damage, including but
not limited to equipment used in the operation of
nuclear facilities, life-support machines, cardiac
defibrillators or similar emergency medical
equipment, aircraft navigation or communication or
control systems, air traffic control systems, or
weapons systems.
Copyright © 2001-2004 Cree, Inc. All rights
reserved. Permission is given to reproduce this
document provided the entire document (including
this copyright notice) is duplicated.
The information in this document is subject to
change without notice.
Cree and the Cree logo are trademarks of Cree,
Inc.
Cree, Inc.
Power Products
4600 Silicon Drive • Durham, NC 27703 • USA
Tel: 919-313-5300 • Fax: 919-313-5451
www.cree.com
Page 4 • CSD20030, Rev A
很抱歉,暂时无法提供与“CSD20030D”相匹配的价格&库存,您可以联系我们找货
