UGF10L08G C0G
UGF10L08G C0G
    TAIWANSEMICONDUCTOR(台湾半导体)
    TO-220-3
    DIODE ARRAY GP 600V ITO-220AB
UGF10L08G C0G 数据手册
UGF10L08G Taiwan Semiconductor CREAT BY ART 10A, 600V Isolated Ultra Fast Rectifier FEATURES - High efficiency, low VF - High current capability - High reliability - High surge current capability - Compliant to RoHS Directive 2011/65/EU and in accordance to WEEE 2002/96/EC - Halogen-free according to IEC 61249-2-21 MECHANICAL DATA ITO-220AB Case: ITO-220AB Molding compound: UL flammability classification rating 94V-0 en de d Packing code with suffix "G" means green compound (halogen-free) Terminal: Matte tin plated leads, solderable per JESD22-B102 Meet JESD 201 class 2 whisker test Polarity: As marked Mounting torque: 0.56 Nm max. Weight: 1.7 g (approximately) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS (TA=25°C unless otherwise noted) Maximum repetitive peak reverse voltage Maximum RMS voltage Maximum DC blocking voltage UGF10L08G UNIT VRRM 600 V VRMS 420 V VDC 600 V IF(AV) 10 A IFSM 70 A VF 1.7 V eco Maximum average forward rectified current SYMBOL mm PARAMETER Peak forward surge current, 8.3 ms single half sine-wave superimposed on rated load tR Maximum instantaneous forward voltage (Note 1) IF= 5 A Maximum reverse current @ rated VR TJ=25°C TJ=125°C Maximum reverse recovery time (Note 2) No Typical thermal resistance Operating junction temperature range Storage temperature range IR 10 100 μA trr 25 ns RθJC 4 °C/W TJ - 55 to +150 °C TSTG - 55 to +150 °C Note 1: Pulse test with PW=300μs, 1% duty cycle Note 2: Test conditions: IF=0.5A, IR=1.0A, IRR=0.25A Version: A1601 UGF10L08G Taiwan Semiconductor ORDERING INFORMATION PART NO. PACKING CODE UGF10L08G (Note 1) C0 PACKING CODE SUFFIX G PACKAGE PACKING ITO-220AB 50 / Tube Note 1: Whole series with green compound EXAMPLE EXAMPLE P/N PART NO. PACKING CODE UGF10L08G C0G UGF10L08G C0 PACKING CODE DESCRIPTION SUFFIX G Green compound RATINGS AND CHARACTERISTICS CURVES d (TA=25°C unless otherwise noted) FIG.1 FORWARD CURRENT DERATING CURVE 10 INSTANTANEOUS REVERSE CURRENT (μA) en 10 6 4 Resistive or inductive load with heat sink 2 0 0 25 50 75 100 125 150 FIG. 3 MAXIMUM NON-REPETITIVE FORWARD SURGE CURRENT 40 20 8.3ms single half sine wave 0 1 10 NUMBER OF CYCLES AT 60 Hz TJ=25°C 0.001 0 20 40 60 80 100 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) 100 100 INSTANTANEOUS FORWARD CURRENT (A) 60 0.01 FIG. 4 TYPICAL FORWARD CHARACTERISTICS No 80 0.1 (°C) tR CASE TEMPERATURE 100 TJ=125°C mm 8 1 e co AVERAGE FORWARD CURRENT (A) 12 PEAK FORWARD SURGE CURRENT (A) de FIG. 2 TYPICAL REVERSE CHARACTERISTICS 10 TJ=125°C TJ=25°C 1 0.1 0 0.2 0.4 0.6 0.8 1 1.2 1.4 1.6 1.8 2 2.2 2.4 FORWARD VOLTAGE (V) Version: A1601 UGF10L08G Taiwan Semiconductor FIG. 5 TYPICAL JUNCTION CAPACITANCE CAPACITANCE (pF) 100 10 f=1.0MHz Vsig=50mVp-p 1 0.1 1 10 100 REVERSE VOLTAGE (V) d PACKAGE OUTLINE DIMENSIONS Unit (mm) Min Max Min Max 4.30 4.70 0.169 0.185 A 2.50 3.16 0.098 0.124 C 2.30 2.96 0.091 0.117 D 0.46 0.76 0.018 0.030 mm B 6.30 6.90 0.248 0.272 F 9.60 10.30 0.378 0.406 G 3.00 3.40 0.118 0.134 H 0.95 1.45 0.037 0.057 I 0.50 0.90 0.020 0.035 J 2.40 3.20 0.094 0.126 K 14.80 15.50 0.583 0.610 L - 4.10 - 0.161 M 12.60 13.80 0.496 0.543 N - 1.80 - 0.071 O 2.41 2.67 0.095 0.105 e co E No tR Unit (inch) en DIM. de ITO-220AB MARKING DIAGRAM P/N = Specific Device Code G = Green Compound YWW = Date Code F = Factory Code Version: A1601 UGF10L08G Taiwan Semiconductor No tR e co mm en de d CREAT BY ART Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC's terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. Version: A1601
UGF10L08G C0G
物料型号:UGF10L08G
器件简介:10A, 600V隔离超快整流器,具有高效率、低正向电压降(VF)、高电流承载能力、高可靠性、高浪涌电流能力,符合RoHS指令2011/65/EU和WEEE 2002/96/EC,无铅和无卤素。
引脚分配:ITO-220AB封装,具体引脚分配未在文档中明确说明。
参数特性: - 最大重复峰值反向电压(VRRM):600V - 最大有效值电压(VRMS):420V - 最大直流阻断电压:600V - 最大平均正向整流电流:10A - 峰值正向浪涌电流:70A(8.3ms单半正弦波) - 最大瞬态正向电压(在5A电流下):1.7V - 最大反向电流(在额定VRRM下):10μA(25°C时)/ 100μA(125°C时) - 最大反向恢复时间:25ns - 典型热阻:4°C/W - 工作结温范围:-55°C至+150°C - 存储温度范围:-55°C至+150°C
功能详解:文档中未提供详细的功能解释,但从参数特性可以推断,该器件适用于需要高电流和高电压整流的应用场景。
应用信息:文档中未明确提供应用信息,但根据其高电流和高电压特性,可能适用于电源转换、电机驱动等工业应用。
封装信息:ITO-220AB封装,采用UL94V-0阻燃等级的绿色化合物(无卤素),引脚为镀锡,可焊性符合JESD22-B102标准,并通过JESD201的2级须晶测试。
UGF10L08G C0G 价格&库存
很抱歉,暂时无法提供与“UGF10L08G C0G”相匹配的价格&库存,您可以联系我们找货
