SK2S160-100
SK2S160-100
    SMCDIODESOLUTIONS(桑德斯)
    SOT-227
SK2S160-100 数据手册
SK2S160-100 Technical Data Data Sheet N1624, Rev A SK2S160-100 Power Schottky Rectifier Features        SOT-227 Circuit Diagram International standard package SOT-227 Very low VF Extremely low switching losses Low IRM -values This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request Applications    Rectifiers in switch mode power Supplies(SMPS) Insulated package(VISO=2500VRMS) Free wheeling diode in low voltage Converters Maximum Ratings: Characteristics Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage Average Rectified Forward Current Peak One Cycle Non-Repetitive Surge Current (Per Leg) Non-Repetitive Avalanche Energy(Per Leg) Total Power Dissipation Repetitive Avalanche Current (Per Leg) Symbol VRRM VRWM VR Condition - IF(AV) 50% duty cycle @TC =105°C, rectangular wave form IFSM 8.3 ms, half Sine pulse EAS P tot IAR TJ=25℃,IAS=12A,L=180H non repetitive T C =25℃ Current decaying linearly to zero in 1 μsec Frequency limited by TJ max.VA=1.5×VR typical Max. Units 100 V 80(Per Leg) 160(Per Device) A 1000 A 16 mJ 150 W 1.2 A  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  SK2S160-100 Technical Data Data Sheet N1624, Rev A Electrical Characteristics: Characteristics Symbol Forward Voltage Drop(Per Leg)* VF1 Voltage Rate of Change Typ. - IR1 IR2 @VR = rated VR, TJ = 125 C VF2 Reverse Current(Per Leg)* Condition @ 80A, Pulse, TJ = 25 C @ 80A, Pulse, TJ = 125 C @ 160A, Pulse, TJ = 125 C @VR = rated VR, TJ = 25 C dv/dt - Max. Units 0.80 0.70 0.95 V - 2 mA - 20 mA - 5000 V/s - V * Pulse width < 300 µs, duty cycle < 2% Thermal-Mechanical Specifications: Characteristics Junction Temperature Storage Temperature Typical Thermal Resistance Junction to Case(Per Leg) Thermal Resistance Junction to Case(Peg Device) Mounting torque(M4) Terminal connection torque(M4) Typical Approximate Weight Symbol TJ Tstg SK2S160-100 Package SOT-227 (Pb-Free) Specification Units -40 to +150 -40 to +150 C C RJC DC operation 0.9 C/W RJC DC operation 0.5 C/W 1.1-1.5/9-13 1.1-1.5/9-13 30 Nm/ lb.in. g MD - wt - Ordering Information Device Condition - Marking Diagram Shipping 36pcs /BULK For information on tape and reel specifications, including part orientation and tape sizes, please refer to our tape and reel packaging specification. S K 2 S 160 100 = SMC's Power Module = SOT-227 Package = Circuit Configuration = Schottky Rectifier = Forward Current (160A) = Reverse Voltage (100V)  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  SK2S160-100 Technical Data Data Sheet N1624, Rev A Mechanical Dimensions SOT-227(Millimeters) 38.0± 0.2 31.5± 0.1 ± 0.3 12.0 9.5± 0.1 4 2 30.2± 0.1 15.0 4-M4 4.2+0.2 -0 8± 0.2  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  25MAX 4.2 4.5± 0.3 R2.1 12.7 ∮4.2 SK2S160-100 Technical Data Data Sheet N1624, Rev A DISCLAIMER: 1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product characteristics. Before ordering, purchasers are advised to contact the SMC Diode Solutions sales department for the latest version of the datasheet(s). 2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment, medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by means of users’ fail-safe precautions or other arrangement . 3- In no event shall SMC Diode Solutions be liable for any damages that may result from an accident or any other cause during operation of the user’s units according to the datasheet(s). SMC Diode Solution assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information, products or circuits described in the datasheets. 4- In no event shall SMC Diode Solutions be liable for any failure in a semiconductor device or any secondary damage resulting from use at a value exceeding the absolute maximum rating. 5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC Diode Solutions. 6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC Diode Solutions. 7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and regulations..  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com 
SK2S160-100 价格&库存
很抱歉,暂时无法提供与“SK2S160-100”相匹配的价格&库存,您可以联系我们找货
